7 Replies Latest reply on May 9, 2017 10:38 AM by KrisHunt
    JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
    FrmBldrRookie
      I am building a simple form to have employees submit their weekly "Photo Reports" from the field.
      I have set up a large button (space large enough for the JPEG) using the following JavaScript: event.target.buttonImportIcon();
      When the form is blank, I am able to click on the big gray box (button) to have a prompt appear that says "Select Icon".
      From there, I am able to "Browse..." and select a JPEG from my files.
      I click "Open" followed by "Okay".
      The picture proportionally fills the space that I want the JPEG to be in the form.
      This is exactly what I want.
      However, once that JPEG is in its location, I cannot delete it.
      I can click on it and the "Select Icon" prompt appears; I can select a different photo.
      But I cannot easily clear the photo without editing the form.
      I want the end-user to be able to clear the pictures in the form the same way that text can be cleared.
      I have very very little experience with all of this.
      Any direction would be best received in a "step-by-step" format.
      Overall Goal:
      -- Build a button that clears a single photo
      and/or
      -- Build a button that clears all the photos that are added to the form.
        • 1. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
          Joel_Geraci Adobe Community Professional
          The easiest way to do this is to create another button, probably hidden, that contains a placeholder image... which could be all gray... and then use JavaScript to get that icon and use it to set the icon of the button you want to clear.
          this.getField("MyNormalButton").setIcon(this.getField("ButtonWithMyPlaceHolder").getIcon() );
          You could create an array of field names and put that code in a loop to clear all the fields in the array.
          J-
          • 2. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
            Karl Heinz Kremer Adobe Community Professional
            Joel gave you the key to solving this, but there are a few things you can do to make this a bit easier on you.
            First, you need to use a hierarchical name for your image buttons (e.g. "Img.1", "Img.2", and so on). Then, create individual buttons to clear a single image using a similar naming convention (e.g. "ImgBtn.1" to clear "Img.1", "ImgBtn.2" to clear "Img.2" and so on). Now you can determine the index (the numeric part of the button name) when a button is clicked, and then use that to dynamically create the associated image field ("ImgBtn.1" -> "Img.1"). And finally, you call the code from Joel's reply to copy the image from a hidden and read-only placeholder button (which I call "blank"):
            // get the button index
            var pos = event.target.name.lastIndexOf(".");
            var myIdx = event.target.name.substring(pos+1);
            // get the associated image field
            var f = this.getField("Img." + myIdx);
            // get the blank image and set it's icon to the associated image field
            f.buttonSetIcon(this.getField("blank").buttonGetIcon());
            Because you've used a hierarchical naming convention for your image fields, you can now also used a shortcut to dynamically loop over all image fields without having to know how many there are, or what their full names are by using the following script:
            var f = this.getField("Img");
            var ar = f.getArray();
            for (var i=0; i<ar.length; i++) {
                f = ar[i];
                ar[i].buttonSetIcon(this.getField("blank").buttonGetIcon());
            It should be obvious, but I'll state it again: Don't copy any code that you don't fully understand. Otherwise you will not be able to make the adjustments necessary to make this work in your document. If you need help understanding what these lines do, consult the Acrobat JavaScript SDK documentation, and/or ask here. You can find the documentation here:
            Acrobat DC SDK Documentation
            • 3. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
              Ack! My code above should have been...
                  this.getField("MyNormalButton").buttonSetIcon(this.getField("ButtonWithMyPlaceHolder").bu ttonGetIcon() );
              But Karl's answer is better.
              • 4. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
                FrmBldrRookie Level 1
                Okay. First, thank you for the quick and detailed reply.
                I need the answer broken down a little bit more.
                For the image button ("Img.1"), in the button properties > Actions > "Run a JavaScript" > Edit:
                What should the language be here? event.target.buttonImportIcon();  ???
                Then for the clear button ("ImgBtn.1") in the button properties > Actions > "Run a JavaScript" > Edit:
                Does there need to be a third button?
                Where does the blank image actually come from?
                Sorry, I really am a rookie at all this.
                • 5. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
                  JR_Boulay Adobe Community Professional
                  Hi.
                  Instead of importing a fake gray image, you can target a button without an icon… and import it.
                  So, this will delete the current icon.
                  In this script "Button1" is the button without icon (that can be hidden), and "Button2" is the button to reset:
                  var oIconClear = this.getField("Button1").buttonGetIcon({nFace: 0});
                  this.getField("Button2").buttonSetIcon({oIcon: oIconClear, nFace: 0});
                  • 6. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
                    That is correct, this will ask the user to select a file (keep in mind that this will only work for image files when the form is opened in Adobe Acrobat, with the free Adobe Reader you can only import PDF files).
                    This is where you use my first script. The important thing here is that both the image button (Img.1) and the "clear the image" button (ImgBtn.1) need to have the same numeric "extension". Otherwise this button cannot find the associated image button.
                    The third button is to clear all image fields (if you have more than one). If I remember correctly, this is something you asked for in your original question. You would use my second script from above for that.
                    You create a button that you call "blank" (that's what is used in my script). You then set the button properties so that it is hidden and read-only:
                    You do not have to assign an image to this button, by default, it uses a blank icon that you can actually retrieve and assign to your own button (which is what you are doing with the scripts I've shown).
                    This should do the trick.
                    • 7. Re: JavaScript for Clearing JPEGs out of a Form??? (Adobe Acrobat Pro DC)
                      KrisHunt Level 4
                      Karl, can you explain how your second script works? I'm stuck on the first line, where f is set to the value of the field called "Img", because if all your image fields are named with an index number, then it seems like there wouldn't be any field exactly named "Img". My understanding of how getField() actually works is probably wrong, but it seems to be such a basic method, I can't even find an explanation of it anywhere. When I search for "getField" in the SDK, I get 41 results that only refer to getField, but don't explain it. Does it return the value of the field with the name "Img", or does it return all the values of any field that contains "Img"?
