10 Replies Latest reply on Dec 14, 2016 6:58 PM by Mohit Goyal
    LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
    Teri Bloom Level 1
      When I synch multiple files in develop mode, and sometimes when I try to export from library mode -- LR crashes and I get a request to send the crash report to Apple.  Specs are LR v. 6.7 and Mac El Capitan v. 10.12.1
      Also today there was an icon on my photos today that said "Metadata has been changed by both LR and another application.  Should LR import settings from disk or overwrite disk settings with those from the catalog".  So perhaps there is a software conflict with another application which is interfering with the metadata?
      Is there any information on this situation and crashes that others are having?
      thanks so much, Teri
        • 1. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
          Mohit Goyal Adobe Employee (Admin)
          Hi TeriBloom,
          Please update the Lightroom to its latest update and check if that helps, refer: Lightroom CC 2015.8 now available
          Regards,
          Mohit
          • 2. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
            Teri Bloom Level 1
            Thank you so very much Mohit -- will do this now.  FYI, aside from LR, the only other open applications I was running at the same time were Mac Mail and Safari.  I will try using LR with these applications closed once I launch this new version to see if that prevents the crashes.  Thank you so very much and will keep you posted, Teri
            • 3. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
              Teri Bloom Level 1
              Hi Mohit,
              Thanks for your help.  LR is still crashing even after this upgrade.
              I turned off all my Mac applications except for LR.  I'm on El Capitan OS 10.12.1
              LR crashed as a tried so synch about 30-40 files in develop mode.
              I sent the crash report to Tina Carter and tried to CC you on the email so you can see the crash report.  Will attempt to paste the crash report below that I will send to Apple.
              Any other ideas?
              Process:               Adobe Lightroom [1325]
              Path:                  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
              Identifier:            com.adobe.Lightroom6
              Version:               Adobe Lightroom [1099473] (6.8)
              Code Type:             X86-64 (Native)
              Parent Process:        ??? [1]
              Responsible:           Adobe Lightroom [1325]
              User ID:               501
              Date/Time:             2016-12-13 15:37:30.124 -0500
              OS Version:            Mac OS X 10.12.1 (16B2555)
              Report Version:        12
              Anonymous UUID:        9180ABFE-5120-BEC5-2C00-619C6C57699E
              Sleep/Wake UUID:       95E4FE48-40C1-4FE3-B911-ADE2C8F614DD
              Time Awake Since Boot: 14000 seconds
              Time Since Wake:       4200 seconds
              System Integrity Protection: enabled
              Crashed Thread:        0  Dispatch queue: com.apple.main-thread
              Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
              Exception Codes:       KERN_INVALID_ADDRESS at 0x000041561374bec0
              Exception Note:        EXC_CORPSE_NOTIFY
              Termination Signal:    Segmentation fault: 11
              Termination Reason:    Namespace SIGNAL, Code 0xb
              Terminating Process:   exc handler [0]
              VM Regions Near 0x41561374bec0:
                  Image IO               000000029e066000-000000029e110000 [  680K] rw-/rwx SM=PRV
                  MALLOC_NANO            0000600000000000-000060000c000000 [192.0M] rw-/rwx SM=PRV
              Application Specific Information:
              objc_msgSend() selector name: objectForKey:
              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
              0   libobjc.A.dylib               0x00007fff979f8b5d objc_msgSend + 29
              1   com.apple.Foundation           0x00007fff84d76de6 __98-[NSObject(NSKeyValueObservingPrivate) _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:]_block_invoke.158 + 39
              2   com.apple.CoreFoundation       0x00007fff833223cc ____NSDictionaryEnumerate_block_invoke.431 + 28
              3   com.apple.CoreFoundation       0x00007fff831d505a CFBasicHashApply + 122
              4   com.apple.CoreFoundation       0x00007fff83218460 __NSDictionaryEnumerate + 288
              5   com.apple.Foundation           0x00007fff84d76bc2 -[NSObject(NSKeyValueObservingPrivate) _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:] + 703
              6   com.apple.CoreFoundation       0x00007fff832fc64a forEachObserver + 298
              7   com.apple.CoreFoundation       0x00007fff832fc868 -[CFPrefsSource _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:] + 72
              8   com.apple.CoreFoundation       0x00007fff8334a044 -[CFPrefsSearchListSource alreadylocked_setValues:forKeys:count:] + 1268
              9   com.apple.CoreFoundation       0x00007fff832fc356 -[CFPrefsSource setValues:forKeys:count:removeValuesForKeys:count:] + 262
              10  com.apple.CoreFoundation       0x00007fff831dcc40 -[CFPrefsSource setValues:forKeys:count:] + 32
              11  com.apple.CoreFoundation       0x00007fff832275ea -[CFPrefsSource setValue:forKey:] + 58
              12  com.apple.CoreFoundation       0x00007fff8334ba12 __108-[_CFXPreferences(SearchListAdditions) withSearchListForIdentifier:container:cloudConfigurationURL:perform:]_block_invoke + 290
              13  com.apple.CoreFoundation       0x00007fff8334b889 -[_CFXPreferences(SearchListAdditions) withSearchListForIdentifier:container:cloudConfigurationURL:perform:] + 345
              14  com.apple.CoreFoundation       0x00007fff83378125 -[_CFXPreferences setValue:forKey:appIdentifier:container:configurationURL:] + 261
              15  com.apple.CoreFoundation       0x00007fff83227534 _CFPreferencesSetAppValueWithContainer + 68
              16  com.apple.Foundation           0x00007fff84c2ebbf -[NSUserDefaults(NSUserDefaults) setObject:forKey:] + 55
              17  com.adobe.ag.substrate         0x0000000106e9547b AgPreferences_storeValue(NSString*, objc_object*) + 215
              18  com.adobe.ag.substrate         0x0000000106e9539d 0x106e7e000 + 95133
              19  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              20  com.adobe.ag.kernel           0x0000000106d520d0 0x106d48000 + 41168
              21  com.adobe.ag.kernel           0x0000000106d60c03 0x106d48000 + 101379
              22  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              23  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              24  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              25  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              26  com.adobe.ag.kernel           0x0000000106d4bec6 0x106d48000 + 16070
              27  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              28  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              29  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              30  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              31  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              32  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              33  com.adobe.ag.kernel           0x0000000106d4bec6 0x106d48000 + 16070
              34  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              35  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              36  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              37  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              38  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              39  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              40  com.adobe.ag.substrate         0x0000000106e91ad9 0x106e7e000 + 80601
              41  com.apple.Foundation           0x00007fff84c66f2a __NSThreadPerformPerform + 326
              42  com.apple.CoreFoundation       0x00007fff8323a4b1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
              43  com.apple.CoreFoundation       0x00007fff8321b61d __CFRunLoopDoSources0 + 557
              44  com.apple.CoreFoundation       0x00007fff8321ab16 __CFRunLoopRun + 934
              45  com.apple.CoreFoundation       0x00007fff8321a514 CFRunLoopRunSpecific + 420
              46  com.apple.HIToolbox           0x00007fff827b7fbc RunCurrentEventLoopInMode + 240
              47  com.apple.HIToolbox           0x00007fff827b7cf9 ReceiveNextEventCommon + 184
              48  com.apple.HIToolbox           0x00007fff827b7c26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
              49  com.apple.AppKit               0x00007fff80ea1b79 _DPSNextEvent + 1093
              50  com.apple.AppKit               0x00007fff815b71c3 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
              51  com.apple.AppKit               0x00007fff80e9653d -[NSApplication run] + 926
              52  com.apple.AppKit               0x00007fff80e611ad NSApplicationMain + 1237
              53  com.adobe.Lightroom6           0x0000000106b8cb97 main + 1095
              54  libdyld.dylib                 0x00007fff982e5255 start + 1
              Thread 1:: Worker Thread Dispatcher
              0   libsystem_kernel.dylib         0x00007fff98413c8a __psynch_cvwait + 10
              1   libsystem_pthread.dylib       0x00007fff984fd96a _pthread_cond_wait + 712
              2   com.adobe.ag.kernel           0x0000000106d6edd4 AgConditionLock_wait + 38
              3   com.adobe.ag.kernel           0x0000000106d68857 AgTransitQueue_dequeueToLuaState + 91
              4   com.adobe.ag.kernel           0x0000000106d692f9 0x106d48000 + 135929
              5   com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              6   com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              7   com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              8   com.adobe.ag.kernel           0x0000000106d4a0f1 lua_call + 37
              9   com.adobe.ag.substrate         0x0000000106e9e02d AgLua_callWithAutoReleasePool + 85
              10  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              11  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              12  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              13  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              14  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              15  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              16  com.adobe.ag.substrate         0x0000000106e915cb 0x106e7e000 + 79307
              17  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
              18  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              19  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              20  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 2:: cr_scratch
              2   com.adobe.ag.AgImageIO         0x0000000109a831cb 0x1098ee000 + 1659339
              3   com.adobe.ag.AgImageIO         0x0000000109c9734b 0x1098ee000 + 3838795
              4   com.adobe.ag.AgImageIO         0x0000000109a4aa41 0x1098ee000 + 1428033
              5   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              6   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              7   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 3:: Queue Processor - AgPhotoAvailability
              6   com.adobe.ag.kernel           0x0000000106d520d0 0x106d48000 + 41168
              7   com.adobe.ag.kernel           0x0000000106d4a0f1 lua_call + 37
              8   com.adobe.ag.substrate         0x0000000106e9e02d AgLua_callWithAutoReleasePool + 85
              10  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              11  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              12  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              13  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              14  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              15  com.adobe.ag.kernel           0x0000000106d4bec6 0x106d48000 + 16070
              16  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              17  com.adobe.ag.kernel           0x0000000106d520d0 0x106d48000 + 41168
              18  com.adobe.ag.kernel           0x0000000106d4a0f1 lua_call + 37
              19  com.adobe.ag.substrate         0x0000000106e9e02d AgLua_callWithAutoReleasePool + 85
              20  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              21  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              26  com.adobe.ag.substrate         0x0000000106e915cb 0x106e7e000 + 79307
              27  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
              28  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              29  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              30  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 4:: AsyncDataServer
              2   com.adobe.ag.kernel           0x0000000106d6ee68 AgConditionLock_wait + 186
              Thread 5:: com.apple.NSURLConnectionLoader
              0   libsystem_kernel.dylib         0x00007fff9840c41a mach_msg_trap + 10
              1   libsystem_kernel.dylib         0x00007fff9840b867 mach_msg + 55
              2   com.apple.CoreFoundation       0x00007fff8321b834 __CFRunLoopServiceMachPort + 212
              3   com.apple.CoreFoundation       0x00007fff8321acc1 __CFRunLoopRun + 1361
              4   com.apple.CoreFoundation       0x00007fff8321a514 CFRunLoopRunSpecific + 420
              5   com.apple.CFNetwork           0x00007fff823eb334 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
              6   com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
              7   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              8   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              9   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 6:: com.apple.CFSocket.private
              0   libsystem_kernel.dylib         0x00007fff98413f4e __select + 10
              1   com.apple.CoreFoundation       0x00007fff8325668a __CFSocketManager + 682
              2   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              3   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              4   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 7:: com.apple.NSEventThread
              5   com.apple.AppKit               0x00007fff80fee5a0 _NSEventThread + 205
              6   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              7   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              8   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 8:: Preview Server
              Thread 9:: Queue Processor - PreviewFileStore
              Thread 10:
              2   com.adobe.headlights.LogSessionFramework 0x000000012a058ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
              3   com.adobe.headlights.LogSessionFramework 0x000000012a0575ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
              4   com.adobe.headlights.LogSessionFramework 0x000000012a005059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
              5   com.adobe.headlights.LogSessionFramework 0x0000000129fd3cfb RealTimeProcessor::WorkerThread(int, int) + 3633
              6   com.adobe.headlights.LogSessionFramework 0x000000012a056969 boost::(anonymous namespace)::thread_proxy(void*) + 185
              Thread 11:: Queue Processor - NegativeQueue
              Thread 12:: Queue Processor - HistogramQueue
              Thread 13:: Queue Processor - RenderQueue_Render
              Thread 14:: Queue Processor - RenderQueue_ReadPreview
              Thread 15:: Queue Processor - RenderQueue_Video
              Thread 16:: Queue Processor - RenderQueue_Face
              Thread 17:: Worker Thread
              8   com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              9   com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              10  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              11  com.adobe.ag.kernel           0x0000000106d4bec6 0x106d48000 + 16070
              12  com.adobe.ag.kernel           0x0000000106d51e15 0x106d48000 + 40469
              13  com.adobe.ag.kernel           0x0000000106d520d0 0x106d48000 + 41168
              14  com.adobe.ag.kernel           0x0000000106d4a0f1 lua_call + 37
              15  com.adobe.ag.substrate         0x0000000106e9e02d AgLua_callWithAutoReleasePool + 85
              17  com.adobe.ag.kernel           0x0000000106d6055d 0x106d48000 + 99677
              18  com.adobe.ag.kernel           0x0000000106d520e1 0x106d48000 + 41185
              19  com.adobe.ag.kernel           0x0000000106d5177e 0x106d48000 + 38782
              20  com.adobe.ag.kernel           0x0000000106d5233d 0x106d48000 + 41789
              21  com.adobe.ag.kernel           0x0000000106d4a172 lua_pcall + 100
              22  com.adobe.ag.substrate         0x0000000106e915cb 0x106e7e000 + 79307
              23  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
              24  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              25  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              26  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 18:: Worker Thread
              Thread 19:
              0   libsystem_kernel.dylib         0x00007fff98413e8e __recvfrom + 10
              1   VulcanMessage5.dylib           0x000000012d56a386 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
              2   VulcanMessage5.dylib           0x000000012d5695fd vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
              3   VulcanMessage5.dylib           0x000000012d5689b8 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
              4   VulcanMessage5.dylib           0x000000012d5688ee vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
              5   VulcanMessage5.dylib           0x000000012d563498 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
              6   VulcanMessage5.dylib           0x000000012d563936 vcfoundation::io::Serializer::InternalDeserialize() + 30
              7   VulcanMessage5.dylib           0x000000012d5638dd vcfoundation::io::Serializer::Deserialize() + 9
              8   VulcanMessage5.dylib           0x000000012d567762 vcfoundation::ncomm::Connection::ReadIn() + 22
              9   VulcanMessage5.dylib           0x000000012d567489 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
              10  VulcanMessage5.dylib           0x000000012d56710a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
              11  VulcanMessage5.dylib           0x000000012d56705d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
              12  VulcanMessage5.dylib           0x000000012d559e66 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
              13  VulcanMessage5.dylib           0x000000012d55a91f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
              14  VulcanMessage5.dylib           0x000000012d568288 vcfoundation::thread::AbstractThread::Run() + 50
              15  VulcanMessage5.dylib           0x000000012d569da9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
              16  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              17  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              18  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 20:: Worker Thread
              Thread 21:
              2   com.apple.CoreServices.CarbonCore 0x00007fff8413c7b1 TSWaitOnCondition + 108
              3   com.apple.CoreServices.CarbonCore 0x00007fff8413c9b0 TSWaitOnConditionTimedRelative + 171
              4   com.apple.CoreServices.CarbonCore 0x00007fff84115b60 MPWaitOnQueue + 192
              5   com.adobe.dvacore.framework   0x0000000115cd0698 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
              6   com.adobe.dvacore.framework   0x0000000115ccd9f8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
              7   com.adobe.dvacore.framework   0x0000000115cca3c6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
              8   com.adobe.boost_threads.framework 0x0000000110cfd7c5 boost::(anonymous namespace)::thread_proxy(void*) + 133
              9   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
              10  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
              11  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
              Thread 22:
              0   libsystem_kernel.dylib         0x00007fff98414e2e kevent + 10
              1   com.adobe.dvatransport.framework 0x0000000111b97111 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 241
              2   com.adobe.dvatransport.framework 0x0000000111b96cec boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
              3   com.adobe.dvatransport.framework 0x0000000111b96858 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
              4   com.adobe.dvatransport.framework 0x0000000111b85332 SkyConnectionEnv::MainLoop() + 162
              5   com.adobe.dvatransport.framework 0x0000000111b84cc9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
              6   com.adobe.boost_threads.framework 0x0000000110cfd7c5 boost::(anonymous namespace)::thread_proxy(void*) + 133
              Thread 23:
              2   com.adobe.dvatransport.framework 0x0000000111b96d8b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
              4   com.adobe.dvatransport.framework 0x0000000111b965fa boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
              5   com.adobe.dvatransport.framework 0x0000000111b97863 boost_asio_detail_posix_thread_function + 19
              Thread 24:
              Thread 25:
              Thread 26:
              Thread 27:: Dispatch queue: NSUserDefaults/CFPreferences Reloading Data in Response to KVO Notifications
              0   com.apple.CoreFoundation       0x00007fff8319bab4 CFBasicHashAddValue + 2068
              1   com.apple.CoreFoundation       0x00007fff831d517d CFDictionaryAddValue + 221
              2   com.apple.CoreFoundation       0x00007fff831d5096 __CFDictionaryApplyFunction_block_invoke + 22
              4   com.apple.CoreFoundation       0x00007fff831d4f99 CFDictionaryApplyFunction + 185
              5   com.apple.CoreFoundation       0x00007fff831d4d78 -[CFPrefsPlistSource mergeIntoDictionary:] + 728
              6   com.apple.CoreFoundation       0x00007fff831ceadf -[CFPrefsSearchListSource alreadylocked_copyDictionary] + 511
              7   com.apple.CoreFoundation       0x00007fff831d6d4f -[CFPrefsSource copyDictionary] + 47
              8   com.apple.CoreFoundation       0x00007fff8334afb9 -[CFPrefsSearchListSource generationCount] + 41
              9   com.apple.CoreFoundation       0x00007fff8334af7b reloadSearchListCallback + 27
              10  libdispatch.dylib             0x00007fff982af128 _dispatch_client_callout + 8
              11  libdispatch.dylib             0x00007fff982c5b97 _dispatch_queue_serial_drain + 896
              12  libdispatch.dylib             0x00007fff982b7d41 _dispatch_queue_invoke + 1046
              13  libdispatch.dylib             0x00007fff982be158 _dispatch_queue_override_invoke + 369
              14  libdispatch.dylib             0x00007fff982b0ee0 _dispatch_root_queue_drain + 476
              15  libdispatch.dylib             0x00007fff982b0cb7 _dispatch_worker_thread3 + 99
              16  libsystem_pthread.dylib       0x00007fff984fc736 _pthread_wqthread + 1299
              17  libsystem_pthread.dylib       0x00007fff984fc211 start_wqthread + 13
              Thread 28:
              0   libsystem_pthread.dylib       0x00007fff984fc204 start_wqthread + 0
              1   ???                           0x697265740000000a 0 + 7598247070218059786
              Thread 29:
              0   libsystem_kernel.dylib         0x00007fff984144e6 __workq_kernreturn + 10
              1   libsystem_pthread.dylib       0x00007fff984fc7b5 _pthread_wqthread + 1426
              2   libsystem_pthread.dylib       0x00007fff984fc211 start_wqthread + 13
              Thread 30:
              1   libsystem_pthread.dylib       0x00007fff984fc622 _pthread_wqthread + 1023
              Thread 31:
              Thread 32:
              Thread 33:
              Thread 34:
              Thread 35:: Queue Processor - AgAsyncRenderingQueue
              Thread 36:: Queue Processor - OpenNegativesForDevelop
              Thread 37:
              Thread 0 crashed with X86 Thread State (64-bit):
                rax: 0x00007fff590725e8  rbx: 0x00007fff590728a8  rcx: 0x00007fff5907273f  rdx: 0x000060000564fdb0
                rdi: 0x0000600008872c80  rsi: 0x00007fff819e05e0  rbp: 0x00007fff59072590  rsp: 0x00007fff59072568
                 r8: 0x0000600008872c80   r9: 0x0000000000000300  r10: 0x000041561374bea8  r11: 0x00007fff819e05e0
                r12: 0x0000000000000af3  r13: 0x0000000000000398  r14: 0x000060000564fdb0  r15: 0x00007fff9dafa5d8
                rip: 0x00007fff979f8b5d  rfl: 0x0000000000010202  cr2: 0x000041561374bec0
              Logical CPU:     6
              Error Code:      0x00000004
              Trap Number:     14
              Binary Images:
                     0x106b8b000 -        0x106ba6ff7 +com.adobe.Lightroom6 (Adobe Lightroom [1099473] - 6.8) <D8B226C8-8626-3216-9470-6BF8F057CF4E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                     0x106bba000 -        0x106d14feb +ZXPSignLib-minimal-dylib.dylib (0) <C7407AC6-367A-3281-81F8-B49A3484014C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                     0x106d48000 -        0x106d7dff7 +com.adobe.ag.kernel (AgKernel Version 1.0 - 1.0) <A160885A-AC78-3C55-A849-6801B2CEB2CC> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                     0x106d8e000 -        0x106e37fff +com.adobe.ag.ui (views version 0.0.1d1 - 0) <FE173000-1F8A-342C-9A04-55A148CE14DD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgUI.framework/Versions/A/AgUI
                     0x106e7e000 -        0x106eb7fff +com.adobe.ag.substrate (com.adobe.ag.substrate 6.8 - 1.0) <40AE7192-620E-37D8-8DCC-BA159B70BFDB> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgSubstrate.framework/Versions/A/AgSubstrate
                     0x106ee2000 -        0x106fe5fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                     0x106ffe000 -        0x10723cfff +com.adobe.wichitafoundation (com.adobe.wichitafoundation 6.8 - 1.0) <A99508D9-9ADF-33D9-9864-45303EE450F8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/WichitaFoundatio n
                     0x108c4f000 -        0x108c4ffff +com.adobe.lightroom.AdobeCrashReporter (1.0) <7AAFE1B2-F362-3E7F-B0E3-28EDC8E5076D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Adobe Crash Reporter.bundle/Contents/MacOS/Adobe Crash Reporter
                     0x108c54000 -        0x108c57fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashRepor ter
                     0x108c9e000 -        0x108de9fff +IMSLib.dylib (10.0.0.7 - 10.0.0.7) <1DD294BF-3FEB-3BBF-A27C-94D2445CB4B4> /Library/Application Support/Adobe/*/IMSLib.dylib
                     0x108e18000 -        0x108e5bff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifi cations
                     0x1098ee000 -        0x10c759ff7 +com.adobe.ag.AgImageIO (com.adobe.ag.AgImageIO 6.8 - 1.0.0d1) <1654FD7A-D9D5-32B6-8275-FBCFC5903CD5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CameraRaw.lrtoolkit/CameraRaw
                     0x10d09c000 -        0x10d09dff7 +com.adobe.ag.xml (com.adobe.ag.xml 6.8 - 1.0) <BC62F95B-8E5D-31C8-8FFC-C44E1FE40534> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/XML.agtoolkit/Contents/MacOS/XML
                     0x10d18c000 -        0x10d1c9287  dyld (421.2) <13A9466A-2576-3ABB-AD9D-D6BC16439B8F> /usr/lib/dyld
                     0x10ead0000 -        0x10eb92fff  com.apple.AMDRadeonX4000GLDriver (1.46.22 - 1.4.6) <DEF17B2F-758C-36C1-85C8-22BB4E135BD3> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
                     0x10ebab000 -        0x10f060ff7  ATIRadeonX4000SCLib.dylib (1.46.22) <9638B1B1-4253-3EB2-86B9-D3581DDADFCC> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCL ib.dylib
                     0x1106a6000 -        0x1106b1fff +com.adobe.ag.video-toolkit (com.adobe.ag.video_toolkit 6.8 - 1) <49A9882E-9894-347A-9C42-734174D724BE> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/video_toolkit.agtoolkit/Contents/MacOS/video_toolkit
                     0x11070e000 -        0x11074dffb  com.apple.glut (3.6.8 - GLUT-3.6.8) <E8DEAF6F-C152-3AE4-9EAF-5787FB2F4055> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                     0x1107c2000 -        0x110803ff7 +com.adobe.ag.bridgetalk (com.adobe.ag.bridgetalk 6.8 - 1.0) <4717BFA1-E637-3AD7-93BA-854F1DB3EAB1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/BridgeTalk.agtoolkit/Contents/MacOS/BridgeTalk
                     0x11082f000 -        0x110890ff7 +com.adobe.ag.imageanalysis (com.adobe.ag.imageanalysis 6.8 - 1.0) <4B9E07A6-DC57-3094-9905-9A0CEFB9D371> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ImageAnalysis.agtoolkit/Contents/MacOS/ImageAnalysis
                     0x11089e000 -        0x110960ff7 +com.adobe.CIT (2.4.0.1 - 2.4.0.1) <A47A6903-F975-3CFC-85B1-B70D00CEB3A1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CIT.framework/Versions/A/CIT
                     0x11099e000 -        0x1109a1fff +com.adobe.CITThreading (2.4.0.1 - 2.4.0.1) <39504412-313C-360F-9E36-1CC9ECA7F013> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
                     0x110ab2000 -        0x110ab7ff7 +com.adobe.lightroom.import (com.adobe.ag.import 6.8 - 1.0) <283428A1-4385-342A-8F01-A2DB5E4AF1DB> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Import.lrmodule/Contents/MacOS/Import
                     0x110b6e000 -        0x110b8dfff +com.adobe.dvaunittesting.framework (10.0.0 - 10.0.0.0) <8870DA93-DED0-3A8B-ADC3-1A3E6ACFFE1E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                     0x110ba9000 -        0x110c53fff +com.adobe.dvaaudiodevice.framework (10.0.0 - 10.0.0.0) <4B9990E0-16CB-310D-93FE-149CC41AFAA3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                     0x110ccb000 -        0x110cd7fff +com.adobe.boost_signals.framework (10.0.0 - 10.0.0.0) <1474269C-5284-3F30-8201-DA41CA4E2A11> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                     0x110ce5000 -        0x110ce6ff7 +com.adobe.boost_system.framework (10.0.0 - 10.0.0.0) <98844C30-9C85-3F4A-8D13-C7CFC17B7DB1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                     0x110cec000 -        0x110cf1ff7 +com.adobe.boost_date_time.framework (10.0.0 - 10.0.0.0) <F14E6E9E-A697-367E-951B-65546506E5FF> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                     0x110cfc000 -        0x110d0bfff +com.adobe.boost_threads.framework (10.0.0 - 10.0.0.0) <EDECEA79-FB6C-3D5F-A343-E6C87E3463F2> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                     0x110d1c000 -        0x110d2aff7 +com.adobe.boost_filesystem.framework (10.0.0 - 10.0.0.0) <1E799366-C8C8-3BA2-977C-82AF91971D0D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                     0x110d36000 -        0x110d61fff +com.adobe.dvamarshal.framework (10.0.0 - 10.0.0.0) <90A6AB5B-6D39-36FB-AB79-776761384263> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                     0x110d86000 -        0x110d87fff  com.apple.ICALogging (1.0 - 1) <89185BC7-B151-3C98-85C7-A4A83F080F18> /System/Library/PrivateFrameworks/ICALogging.framework/ICALogging
                     0x110e29000 -        0x110eefff7 +com.adobe.dvaplayer.framework (10.0.0 - 10.0.0.0) <6AF3D151-951F-31A4-9242-2BB9A8C69A0F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                     0x110faa000 -        0x110febfff +com.adobe.dvamediatypes.framework (10.0.0 - 10.0.0.0) <DD99EDBD-5CAF-3493-9F5A-8D828F8C5C18> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                     0x1110c5000 -        0x11136bfff +com.adobe.dynamiclink.framework (10.0.0 - 10.0.0.0) <DA4F9A10-D323-355B-9422-0533075C391F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                     0x111b6b000 -        0x111bd7ff7 +com.adobe.dvatransport.framework (10.0.0 - 10.0.0.0) <11CEACAC-8A44-319E-81D9-15459B4082C8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                     0x111cc2000 -        0x111cdbffb  libexpat.1.dylib (15) <617B8B7A-A0AB-37D6-AFCA-F90F7F14E455> /usr/lib/libexpat.1.dylib
                     0x115665000 -        0x1159aaff7 +com.adobe.mediacoreif.framework (10.0.0 - 10.0.0.0) <82D0D38F-9997-3186-B90A-A60E33B51908> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                     0x115b9e000 -        0x115ea8ff7 +com.adobe.dvacore.framework (10.0.0 - 10.0.0.0) <545C09D5-FAD3-3B0B-B145-2D5342FEB57D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                     0x116138000 -        0x11617fff7 +com.adobe.ag.cef-toolkit (com.adobe.ag.cef_toolkit 6.8 - 1.0) <BE9CF3C3-70BA-3FD6-AC7A-C13033696757> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/cef_toolkit.agtoolkit/Contents/MacOS/cef_toolkit
                     0x11619b000 -        0x1161d9fff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <E57FE5B1-72E1-3606-8895-65E4C7880FA3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                     0x116202000 -        0x11627bfff  com.apple.xquery (1.3.1 - 30) <9BBE7704-B310-31C7-85F6-BA033714B482> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                     0x117b90000 -        0x117ba8fff +com.adobe.ag.help (com.adobe.ag.help 6.8 - 1.0) <2299D896-D4B6-358C-ABB8-067533FD8514> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHelpClient.lrmodule/Contents/MacOS/AdobeHelpClient
                     0x117bb2000 -        0x117bb5fff +com.adobe.ag.headlights (com.adobe.ag.Headlights 6.8 - 1.0) <17D88CE5-2894-389F-B917-B9F1FD648AF1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHeadlights.lrmodule/Contents/MacOS/AdobeHeadlights
                     0x117bbc000 -        0x117beeff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                     0x117bfa000 -        0x117c23fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                     0x117cc8000 -        0x117ccbff7 +com.adobe.ag.discburning (com.adobe.ag.discburning 6.8 - 1.0) <837DDC0B-77EE-3091-BEEB-5FAF8AEEA475> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/DiscBurning.agtoolkit/Contents/MacOS/DiscBurning
                     0x11f7a7000 -        0x123334f1f +libcef.dylib (31523.6.11) <7E427337-65A2-3B49-AD70-9C9BE02F4C01> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/libcef.dylib
                     0x129f00000 -        0x12a09afff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/LogSession
                     0x12a17c000 -        0x12a1a1fff  com.apple.DiscRecordingUI (9.0.3 - 9030.4.5) <178BB77B-D4EB-3B45-A560-D24B4F6E7102> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
                     0x12a1c3000 -        0x12a1c8ff7 +com.adobe.ag.email (com.adobe.ag.email 6.8 - 1.0) <D39FD838-D682-3F0F-A462-7B87EBC28100> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Email.lrmodule/Contents/MacOS/Email
                     0x12a376000 -        0x12a8a3fff +com.adobe.ag.coretech-toolkit (com.adobe.ag.coretech_toolkit 6.8 - 1.0) <AD810484-2C43-38BC-B0A3-5BE22AA1AA52> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CoreTechToolkit.agtoolkit/Contents/MacOS/CoreTechToolki t
                     0x12aac1000 -        0x12ad7dff3 +com.adobe.AGM (AdobeAGM 4.30.60.36125 - 4.30.60.36125) <74D5A66E-A468-3B49-9E4F-F8B580F32BF8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                     0x12adec000 -        0x12ae08ffb +com.adobe.BIB (AdobeBIB 1.2.03.36125 - 1.2.03.36125) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                     0x12ae11000 -        0x12ae34ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                     0x12ae3d000 -        0x12b12bffb +com.adobe.CoolType (AdobeCoolType 5.15.00.36125 - 5.15.00.36125) <C7B78AC8-5659-3CD0-9483-29F9628C0C61> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                     0x12b175000 -        0x12b2baff3 +com.adobe.ACE (AdobeACE 2.20.02.36125 - 2.20.02.36125) <833F0706-F228-39B7-BCAF-9989A47E4D55> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                     0x12b2d0000 -        0x12b3fefff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                     0x12b45b000 -        0x12b526ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.36125 - 3.8.0.36125) <14364CB3-3364-3045-9BA6-B44516BA9D63> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                     0x12b581000 -        0x12b581fff +com.adobe.ag.catalogconverters (com.adobe.ag.catalogconverters 6.8 - 1.0) <D16492C2-689B-3C6D-9EF0-125F2A9388C3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CatalogConverters.agtoolkit/Contents/MacOS/CatalogConve rters
                     0x12d51a000 -        0x12d528ff7 +com.adobe.ag.AgNetClient (com.adobe.ag.AgNetClient 6.8 - 1.0.0d1) <4540B8FC-D531-3BB0-BF73-EA1A4076F532> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgNetClient.agtoolkit/AgNetClient
                     0x12d542000 -        0x12d544ff7 +com.adobe.ag.vulcan (com.adobe.ag.vulcan 6.8 - 1.0) <ABE8F1C9-34DA-3010-AB9A-C75802860CD5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Vulcan.agtoolkit/Contents/MacOS/Vulcan
                     0x12d54c000 -        0x12d584ff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/VulcanMessaging.framework/Versions/A/VulcanMessage5.dyl ib
                     0x145dc5000 -        0x145dc6fed +cl_kernels (???) <AA298745-517E-4FE2-9C4F-D930AA035ABB> cl_kernels
                  0x7fff7e02d000 -     0x7fff7e365fff  com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x7fff7e366000 -     0x7fff7e48dff3  com.apple.AMDMTLBronzeDriver (1.46.22 - 1.4.6) <5F462A40-03D7-34AD-9DBF-AD0A266792B9> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
                  0x7fff7fb8a000 -     0x7fff7fd48ff7  com.apple.avfoundation (2.0 - 1183.4) <CF8F272A-5046-389C-A89F-0C71CF700415> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                  0x7fff7fd49000 -     0x7fff7fdecff7  com.apple.audio.AVFAudio (1.0 - ???) <F340B5A9-80C4-39C2-952A-51F84681103F> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                  0x7fff7fe81000 -     0x7fff7fe81fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <97EF9FB3-581F-3F19-84D0-E9262559A454> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x7fff7fe82000 -     0x7fff7fe99ffb  libCGInterfaces.dylib (331.5) <5796C169-B449-33C8-B471-BD711BDCB898> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                  0x7fff7fe9a000 -     0x7fff803b3feb  com.apple.vImage (8.1 - ???) <A5DBF800-F768-3A61-8575-9B45FC32FEAB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x7fff803b4000 -     0x7fff80524ff3  libBLAS.dylib (1185) <C7E42BBE-2337-3AEF-9C45-A2F2CB1A5B3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x7fff80525000 -     0x7fff80539ffb  libBNNS.dylib (14) <CFDEE88D-E002-347C-BC68-83099651585B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                  0x7fff8053a000 -     0x7fff80930fef  libLAPACK.dylib (1185) <2E8201CB-9A41-3D65-853E-841917FCE77B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x7fff80931000 -     0x7fff80947fff  libLinearAlgebra.dylib (1185) <8CC29DE1-A231-3D5E-B5F1-DCC309036FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                  0x7fff80948000 -     0x7fff8094efff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                  0x7fff8094f000 -     0x7fff80963ff7  libSparseBLAS.dylib (1185) <C35235B7-CFA6-39A7-BD6E-79F4D9CAFD36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                  0x7fff80964000 -     0x7fff80aebfe7  libvDSP.dylib (600) <DF2860D3-1B2E-3DE0-8D8D-F567374398CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x7fff80aec000 -     0x7fff80b9effb  libvMisc.dylib (600) <5E006F98-FB5C-3AC4-B8B9-6D267B22AA72> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x7fff80b9f000 -     0x7fff80b9ffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A395B521-8E54-30F2-B4FE-355D68900DAF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x7fff80e5b000 -     0x7fff81b3bff3  com.apple.AppKit (6.9 - 1504.60) <5DA1E013-575C-34D5-A028-1639EB7B0040> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff81b4d000 -     0x7fff81b4dfff  com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x7fff81b4e000 -     0x7fff81bbcff7  com.apple.ApplicationServices.ATS (377 - 422.1) <FF4D9FCA-D799-3ED1-B5F8-3D81C29342D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x7fff81c56000 -     0x7fff81d84ff7  libFontParser.dylib (194.2) <E29F233F-773A-3070-874A-83799BDF0B5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x7fff81d85000 -     0x7fff81dcffff  libFontRegistry.dylib (196.2) <8AEE7F4E-60F0-33BB-99E4-5381EF1FEC6F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x7fff81e2c000 -     0x7fff81e5efff  libTrueTypeScaler.dylib (194.2) <A8520109-5F65-3144-ABF7-E22B98A74287> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x7fff81eca000 -     0x7fff81f74ff7  com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                  0x7fff81f75000 -     0x7fff81fc5fff  com.apple.HIServices (1.22 - 590) <109A9893-313B-3467-9892-062F49D1FF0D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x7fff81fc6000 -     0x7fff81fd5ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x7fff81fd6000 -     0x7fff82023fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x7fff82024000 -     0x7fff8205ffff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x7fff82060000 -     0x7fff8206bff7  com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x7fff8206c000 -     0x7fff8227aff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <BA73DBAD-A9D2-3BA7-BCDB-4790D6C8B460> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x7fff8227b000 -     0x7fff8227bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <C49668FF-2971-3E30-92BB-09E0720E74A5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                  0x7fff823e4000 -     0x7fff82768ff7  com.apple.CFNetwork (807.1.3 - 807.1.3) <336BFAD9-1BAE-368E-8C48-B9F1CC251C67> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x7fff82782000 -     0x7fff82782fff  com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x7fff82783000 -     0x7fff82786fff  com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                  0x7fff82787000 -     0x7fff82a8bfff  com.apple.HIToolbox (2.1.1 - 856.6) <DAF74CE6-8B6B-3347-B299-FE860B517D38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x7fff82a8c000 -     0x7fff82a8fff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                  0x7fff82a90000 -     0x7fff82a95fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                  0x7fff82a96000 -     0x7fff82b2dff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                  0x7fff82b2e000 -     0x7fff82b48fff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                  0x7fff82b49000 -     0x7fff82b4aff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                  0x7fff82b4b000 -     0x7fff82b4dff7  com.apple.securityhi (9.0 - 55006) <FFB3F28C-B982-34EF-8510-8D6D10975404> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                  0x7fff82b4e000 -     0x7fff82b54ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                  0x7fff82b55000 -     0x7fff82c33fff  com.apple.cloudkit.CloudKit (639.2.1 - 639.2.1) <9F6CFA9A-3109-30C5-B3AB-4745489E7EBD> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                  0x7fff82c34000 -     0x7fff82c34fff  com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x7fff82d6a000 -     0x7fff82dfaff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <4082E8CC-568A-364A-9AF0-92F30F067D42> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                  0x7fff82dfb000 -     0x7fff82e0eff3  com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                  0x7fff82e0f000 -     0x7fff83105ffb  com.apple.CoreData (120 - 752.2) <CCDCE896-CD36-3483-8E04-C513433BDDC5> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                  0x7fff83106000 -     0x7fff83192fff  com.apple.CoreDisplay (1.0 - 1) <ACA3B0B8-6900-3445-B202-C5C312421E44> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                  0x7fff83193000 -     0x7fff8362cff7  com.apple.CoreFoundation (6.9 - 1348.15) <C25C6FB8-E934-349C-952C-26CF913BAC33> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff8362d000 -     0x7fff83cabfff  com.apple.CoreGraphics (2.0 - 1070.8) <3F5B7647-8006-3738-9A5A-1AD2DF570992> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                  0x7fff83cac000 -     0x7fff83eebff7  com.apple.CoreImage (12.0.0 - 451) <4A79760F-FD23-3055-9569-5F038818993F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                  0x7fff83eec000 -     0x7fff83f48ff7  com.apple.corelocation (2100.3.14.4) <40B8B610-F93C-3708-B61D-E840E5708AC0> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                  0x7fff83f49000 -     0x7fff83ff9ff7  com.apple.CoreMedia (1.0 - 1903.11) <34BC19CF-0203-315F-A75D-1E4237BF3FF4> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                  0x7fff83ffa000 -     0x7fff84045ff7  com.apple.CoreMediaIO (803.0 - 4927) <C237F327-930D-30E7-A100-D60F28911154> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                  0x7fff84046000 -     0x7fff84046fff  com.apple.CoreServices (775.8.2 - 775.8.2) <FE7B0765-C41F-3FD9-8FD7-094466AAD0EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                  0x7fff84047000 -     0x7fff84098ff7  com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                  0x7fff84099000 -     0x7fff84374fff  com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                  0x7fff84375000 -     0x7fff843a8fff  com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                  0x7fff843a9000 -     0x7fff843b1ffb  com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                  0x7fff843b2000 -     0x7fff8451dfff  com.apple.LaunchServices (775.8.2 - 775.8.2) <7389590A-0E30-3294-B39C-F179D237F6C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                  0x7fff8451e000 -     0x7fff845ceffb  com.apple.Metadata (10.7.0 - 1075.17) <40F7E6E2-B58B-34E1-B97B-26756ECDB947> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                  0x7fff845cf000 -     0x7fff8462efff  com.apple.CoreServices.OSServices (775.8.2 - 775.8.2) <C949CF81-3510-3987-AEB4-9A961B738DA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                  0x7fff8462f000 -     0x7fff8469ffff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                  0x7fff846a0000 -     0x7fff846e6ff7  com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                  0x7fff84773000 -     0x7fff848beffb  com.apple.CoreText (352.0 - 544.1) <3229A726-303B-3B09-A014-8708C3BEF2D1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                  0x7fff848bf000 -     0x7fff848f4fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                  0x7fff848f5000 -     0x7fff84966ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <0425CA71-50D9-32DC-8693-CAE6CB3B799D> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                  0x7fff849a2000 -     0x7fff84a60ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <BB73A94D-1A40-3F62-9BD9-82DEE9DB8FE9> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                  0x7fff84a61000 -     0x7fff84a66fff  com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                  0x7fff84bf5000 -     0x7fff84f9cffb  com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x7fff84fc8000 -     0x7fff84ff9fff  com.apple.GSS (4.0 - 2.0) <4F3C9982-457C-3731-85DB-8CE1A72621B0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                  0x7fff850ad000 -     0x7fff85150fff  com.apple.Bluetooth (5.0.1 - 5.0.1f7) <406E3901-F5D3-3996-84F7-32975EBE8F86> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                  0x7fff85151000 -     0x7fff851e6ff7  com.apple.framework.IOKit (2.0.2 - 1324.21.1) <EEFE7FF0-CE41-326A-A571-8AA0B2E89271> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x7fff851e7000 -     0x7fff851edffb  com.apple.IOSurface (153.1 - 153.1) <849B0928-3D37-3977-9670-19979DB4EE4D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                  0x7fff851ee000 -     0x7fff85240ffb  com.apple.ImageCaptureCore (7.0 - 7.0) <B12559B1-A73A-301C-9628-27F4A765C6DF> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                  0x7fff85241000 -     0x7fff85397fef  com.apple.ImageIO.framework (3.3.0 - 1570.2) <1133B1CE-C702-3D66-80F3-6BB40D5D1178> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                  0x7fff85398000 -     0x7fff8539cfff  libGIF.dylib (1570.2) <4AE8D51B-E26A-3CB0-9D53-58112F94E3CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                  0x7fff8539d000 -     0x7fff8548dfff  libJP2.dylib (1570.2) <9F56888C-28CD-3ED0-B7BB-FFB775EF9DE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                  0x7fff8548e000 -     0x7fff854b1ffb  libJPEG.dylib (1570.2) <BE6386AF-E7F7-3C26-8B9E-7682DA38F496> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                  0x7fff854b2000 -     0x7fff854d9ff7  libPng.dylib (1570.2) <2BC453BB-5E15-3031-AFAE-912025F2674A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                  0x7fff854da000 -     0x7fff854dcff3  libRadiance.dylib (1570.2) <0F2C81F9-2D74-36A6-BCC0-2366E60410C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                  0x7fff854dd000 -     0x7fff85536ff3  libTIFF.dylib (1570.2) <897EB69A-1C96-3BC2-A458-A21652249E71> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                  0x7fff85656000 -     0x7fff860f7ff7  com.apple.JavaScriptCore (12602 - 12602.2.14.0.5) <A9839022-B3BE-38E2-8956-B5ED9BE145FD> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                  0x7fff860f8000 -     0x7fff86111ff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                  0x7fff8638c000 -     0x7fff86392fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <EE1825C7-3B58-32F8-9F5F-B7172452BB01> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                  0x7fff863a8000 -     0x7fff868f7ff7  com.apple.MediaToolbox (1.0 - 1903.11) <9855FD27-8435-3CB5-8C81-342D3BED69DE> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                  0x7fff868f8000 -     0x7fff8694fff7  com.apple.Metal (85.85 - 85.85) <EF221C0E-9638-312B-9455-FF3C69180C45> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                  0x7fff87065000 -     0x7fff8706dfff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                  0x7fff87241000 -     0x7fff87249ff7  libcldcpuengine.dylib (2.8.4) <B43FD148-4550-3EB1-9971-F5EFC0456CCE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                  0x7fff8724a000 -     0x7fff87330fff  unorm8_bgra.dylib (2.8.4) <59487A57-1575-33DB-8F65-D55E8DD75CF4> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                  0x7fff87331000 -     0x7fff87411fe7  unorm8_rgba.dylib (2.8.4) <1A461BEE-4D8E-3F85-8FA9-2C145899C7E5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                  0x7fff87412000 -     0x7fff87460ff3  com.apple.opencl (2.8.6 - 2.8.6) <819DE36A-893E-3100-8430-EEB9D7023672> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                  0x7fff87461000 -     0x7fff8747affb  com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                  0x7fff8747b000 -     0x7fff87486ff7  com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                  0x7fff87487000 -     0x7fff87489fff  libCVMSPluginSupport.dylib (12.4.5) <AF349AF5-ACC9-32C8-98BE-1DC9523156C5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                  0x7fff8748a000 -     0x7fff8748dff7  libCoreFSCache.dylib (150) <991F00EB-B1B4-3351-9D83-C11E4920C360> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                  0x7fff8748e000 -     0x7fff87491fff  libCoreVMClient.dylib (150) <06276E05-1FB2-3748-A236-1F66468A1755> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                  0x7fff87492000 -     0x7fff8749affb  libGFXShared.dylib (12.4.5) <67ABA30E-DA8A-336C-8137-11CD0D455741> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                  0x7fff8749b000 -     0x7fff874a6fff  libGL.dylib (12.4.5) <920D2CC5-D64F-35A5-8C54-4A5731AEC552> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                  0x7fff874a7000 -     0x7fff874e3ff7  libGLImage.dylib (12.4.5) <BEDFA6BF-0D9C-35ED-9DDD-FDBB1F6AAF95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                  0x7fff874e4000 -     0x7fff8765affb  libGLProgrammability.dylib (12.4.5) <6F6A4BA1-2DB2-3D22-9BEE-E45F6455BAE1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                  0x7fff8765b000 -     0x7fff8769bff3  libGLU.dylib (12.4.5) <79C811DC-7904-3A7D-A983-B3E8D5439336> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                  0x7fff88003000 -     0x7fff88011fff  com.apple.opengl (12.4.5 - 12.4.5) <B33F90DE-B86B-38E3-BCDB-5C8B4952D84B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                  0x7fff88012000 -     0x7fff881b8fff  GLEngine (12.4.5) <A4E7F3A2-5025-3C7D-AAF5-6187601A8C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                  0x7fff881b9000 -     0x7fff881e3ffb  GLRendererFloat (12.4.5) <9C53418B-2B6F-3B16-AA50-EF8CD632B05F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                  0x7fff8827a000 -     0x7fff883c1ff7  com.apple.QTKit (7.7.3 - 2978) <BA342B9F-7675-3A1D-B384-BB0B78F3F207> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                  0x7fff883c2000 -     0x7fff8862dfff  com.apple.imageKit (3.0 - 1016) <A3D24043-95CD-3A40-9850-83E02BDF56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                  0x7fff8862e000 -     0x7fff886e8ff7  com.apple.PDFKit (1.0 - 1) <C9AB4AB5-A2E4-344E-B898-097B86DD38D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                  0x7fff886e9000 -     0x7fff88c0ffff  com.apple.QuartzComposer (5.1 - 351) <10A260C7-A44C-3C64-BF68-FC0FCCD08489> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                  0x7fff88c10000 -     0x7fff88c33ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <9ECD9812-151A-300D-8F37-F7FEBE67B8BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                  0x7fff88c34000 -     0x7fff88d21ff7  com.apple.QuickLookUIFramework (5.0 - 720.1) <6967F937-2BDC-397A-A377-5C52899FF97A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                  0x7fff88d22000 -     0x7fff88d22fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                  0x7fff88d23000 -     0x7fff88f1dfff  com.apple.QuartzCore (1.11 - 449.39.5) <B1815529-31B4-3FD0-923D-C3E964F844FF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                  0x7fff88f1e000 -     0x7fff88f73fff  com.apple.QuickLookFramework (5.0 - 720.1) <FF21C563-BCEB-390B-8120-FE5FE788DBDF> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                  0x7fff88f74000 -     0x7fff88f87ff7  com.apple.SafariServices.framework (12602 - 12602.2.14.0.7) <2F16B32F-D006-31EA-9CB9-299264C17E30> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                  0x7fff89483000 -     0x7fff8979eff7  com.apple.security (7.0 - 57740.20.22) <7E95D13A-0D52-36A9-A1C4-C21EE26AB2AB> /System/Library/Frameworks/Security.framework/Versions/A/Security
                  0x7fff8979f000 -     0x7fff89815ff7  com.apple.securityfoundation (6.0 - 55132.20.1) <8DDEA805-C6F7-3EF9-990F-136617DB942D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                  0x7fff8983f000 -     0x7fff89842ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <A88DACDF-71A9-3974-8D8D-DAA2B64F2CA5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                  0x7fff89bc7000 -     0x7fff89c38ff7  com.apple.SystemConfiguration (1.14 - 1.14) <013957CA-2708-31F0-845D-11E271C96B94> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                  0x7fff89c39000 -     0x7fff89fe4ff7  com.apple.VideoToolbox (1.0 - 1903.11) <E59DEC1D-6E7D-39BB-A589-9166C3C79221> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                  0x7fff8c250000 -     0x7fff8c26bff3  com.apple.AppContainer (4.0 - 307.20.1) <AE48030D-760D-3C46-A5EB-FD09B42543ED> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                  0x7fff8c26c000 -     0x7fff8c279ff3  com.apple.AppSandbox (4.0 - 307.20.1) <6BCD6C7F-470A-3C6A-9A24-3F26037AD6F7> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                  0x7fff8c27a000 -     0x7fff8c29cffb  com.apple.framework.Apple80211 (12.0 - 1200.37) <25299C0F-7A30-3BAA-9945-DB1515F68A2C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                  0x7fff8c29d000 -     0x7fff8c2acfdb  com.apple.AppleFSCompression (88 - 1.0) <D3A6F5F9-2132-34B5-933F-DF5D6733DE8B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                  0x7fff8c395000 -     0x7fff8c42097f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                  0x7fff8c459000 -     0x7fff8c45cff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                  0x7fff8c45d000 -     0x7fff8c4affff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <42A46C0E-877D-349C-A30A-5CA29896391B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                  0x7fff8c4b8000 -     0x7fff8c4bfffb  com.apple.AssetCacheServices (31 - 31) <13E874CA-86AB-33E7-A4D8-544D3B8157CD> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                  0x7fff8c83c000 -     0x7fff8c8baff7  com.apple.backup.framework (1.8.1 - 1.8.1) <792B4983-DE9A-377D-8338-93719706D12F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                  0x7fff8d4d8000 -     0x7fff8d4ffffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                  0x7fff8d500000 -     0x7fff8d592ffb  com.apple.CloudDocs (1.0 - 483.3) <35F99B99-6F99-37F2-B347-8B8E86D83878> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                  0x7fff8de26000 -     0x7fff8de2fffb  com.apple.CommonAuth (4.0 - 2.0) <D561391D-80B8-35F8-9EFF-1ACC89895E38> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                  0x7fff8dfb0000 -     0x7fff8e38dfe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                  0x7fff8e38e000 -     0x7fff8e3befff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                  0x7fff8e54b000 -     0x7fff8e55cff7  com.apple.CoreEmoji (1.0 - 39.1) <54432658-8481-3F33-ADED-B60684311E11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                  0x7fff8e611000 -     0x7fff8e627fff  com.apple.CoreMediaAuthoring (2.2 - 955) <0D83B2A2-E541-3FFB-ACEC-E848F9C847E7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                  0x7fff8e62e000 -     0x7fff8e6beffb  com.apple.CorePDF (4.0 - 4) <42FD0781-A19C-3E36-BFDA-DAEAFB3A3115> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                  0x7fff8e83e000 -     0x7fff8e86eff3  com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                  0x7fff8eaf7000 -     0x7fff8eb81fff  com.apple.CoreSymbolication (61050) <15C4AF49-2F85-3265-B53F-4925616C746E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                  0x7fff8eb82000 -     0x7fff8ecc0fcf  com.apple.coreui (2.1 - 426.9.1) <A7672B5D-9972-34B8-968A-188D422083AE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                  0x7fff8ecc1000 -     0x7fff8ed60ffb  com.apple.CoreUtils (4.3 - 430.70) <946F5089-9F8D-3595-8208-AD945B26D267> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                  0x7fff8edb0000 -     0x7fff8ee15ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <8DAD3903-9A77-3E50-99C4-3C5708FB25B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                  0x7fff8ee16000 -     0x7fff8ee23fff  com.apple.CrashReporterSupport (10.12 - 816) <BF292E0C-6CDB-3149-8177-4EF5DD72D544> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                  0x7fff8eec9000 -     0x7fff8ef40ff3  com.apple.datadetectorscore (7.0 - 539) <AA02538E-706E-305B-AABA-FA9A6F4C1B8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                  0x7fff8ef7a000 -     0x7fff8efb9fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                  0x7fff8efba000 -     0x7fff8f0cbfff  com.apple.desktopservices (1.11.1 - 1.11.1) <03518A59-79B1-3B16-B923-52D6EFF04ADB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                  0x7fff8f20a000 -     0x7fff8f214ff7  com.apple.DisplayServicesFW (3.1 - 380) <6E891145-62C3-35B9-90A5-21BC0CACDEDB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                  0x7fff8f397000 -     0x7fff8f7c8ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                  0x7fff90b03000 -     0x7fff90b03fff  libmetal_timestamp.dylib (600.0.48.26) <681B9F09-0673-3C38-B636-9D77D338D1AF> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                  0x7fff90b10000 -     0x7fff90b1bff3  libGPUSupportMercury.dylib (12.4.5) <A08E7321-32C4-3008-97C3-870B6AB1E63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                  0x7fff90dcd000 -     0x7fff90de9ff7  com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                  0x7fff90e01000 -     0x7fff91499ff7  com.apple.GeoServices (1.0 - 1228.21.7.28.8) <E45ACAE1-FBF1-3275-A6DD-6D5092FD6EFC> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                  0x7fff914df000 -     0x7fff91555ffb  com.apple.Heimdal (4.0 - 2.0) <418DD668-7288-3D33-BAFE-959DB96D0351> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                  0x7fff91b5d000 -     0x7fff91b67fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <5415DC87-6388-3571-8A55-7720D1FE08EE> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInf o
                  0x7fff91b68000 -     0x7fff91b6fffb  com.apple.IOAccelerator (288.15 - 288.15) <DE5BC493-2F4E-3388-A887-DA5AD7BAD3F4> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                  0x7fff91b71000 -     0x7fff91b85ff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                  0x7fff91b86000 -     0x7fff91ba8ff7  com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                  0x7fff91c43000 -     0x7fff91c53ff3  com.apple.IntlPreferences (2.0 - 216) <5E2D8D16-DBB9-3389-9CEA-1E4094C34A92> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                  0x7fff91c8a000 -     0x7fff91e3efff  com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                  0x7fff91f19000 -     0x7fff91feaff3  com.apple.MMCS (1.3 - 379) <14867D2F-6E87-351E-AB4B-9BD759364DFD> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                  0x7fff92484000 -     0x7fff92487fff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                  0x7fff926ea000 -     0x7fff92762fef  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <EDE6F9AA-B863-3936-BA54-177B769080FD> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
                  0x7fff928c8000 -     0x7fff928d3ff7  com.apple.MobileKeyBag (2.0 - 1.0) <9E2D377E-C3D5-326F-B559-787AFCBA6728> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                  0x7fff928e4000 -     0x7fff9290cfff  com.apple.MultitouchSupport.framework (368.4 - 368.4) <18778258-70B1-31BF-845D-1FACBF280108> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                  0x7fff929b9000 -     0x7fff929c3fff  com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                  0x7fff9319f000 -     0x7fff931e0ff7  com.apple.PerformanceAnalysis (1.145 - 145) <73A73364-EFB6-3D0A-A7EA-7F924359B3C9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                  0x7fff93846000 -     0x7fff93871ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <614C38AC-9D97-30D8-A196-02688634B584> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                  0x7fff93872000 -     0x7fff9388cfff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                  0x7fff9388d000 -     0x7fff9389dffb  com.apple.QuickLookThumbnailing (1.0 - 1) <DD5F14E6-A8A8-3EA8-96A3-4C84092BC18F> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                  0x7fff938a6000 -     0x7fff938c9ff3  com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                  0x7fff944fc000 -     0x7fff944fffff  com.apple.SecCodeWrapper (4.0 - 307.20.1) <2BBC8E7C-7B28-39D2-8273-2BA5ED7DAC45> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                  0x7fff9458d000 -     0x7fff94609fff  com.apple.Sharing (671.15 - 671.15) <37C29D52-CA6E-3E30-9CCF-F7B4A8DE6B9B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                  0x7fff9462a000 -     0x7fff9487cfef  com.apple.SkyLight (1.600.0 - 108.11) <5D0C258E-0816-3FF2-AA3C-A7B9F2DEC19C> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                  0x7fff94a56000 -     0x7fff94a62fff  com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                  0x7fff95146000 -     0x7fff951b2ff3  com.apple.Symbolication (61080.2) <8AB6B520-E8DE-392F-8B86-52098D2A2BA2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                  0x7fff955a9000 -     0x7fff955afff7  com.apple.TCC (1.0 - 1) <787E8FD8-21A7-39E6-87D4-6AD09156C5A0> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                  0x7fff9563b000 -     0x7fff957fcff3  com.apple.TextureIO (1.35 - 1.35) <63D75E50-F3C2-3E8E-A49B-F53531C24C54> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                  0x7fff95870000 -     0x7fff95871fff  com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                  0x7fff95872000 -     0x7fff95a01ffb  com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                  0x7fff96452000 -     0x7fff96501ff7  com.apple.ViewBridge (276 - 276) <55494F8D-A20F-3D64-826F-E136D77AFC9D> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                  0x7fff96929000 -     0x7fff9692ffff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                  0x7fff96a00000 -     0x7fff96a02ffb  com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                  0x7fff96a57000 -     0x7fff96a72ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
                  0x7fff96a73000 -     0x7fff96a7efff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
                  0x7fff96b10000 -     0x7fff96b11ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
                  0x7fff96b12000 -     0x7fff96d25fff  libFosl_dynamic.dylib (16.37) <D5551823-1E3D-3BDE-968C-BF022EE4958D> /usr/lib/libFosl_dynamic.dylib
                  0x7fff96d41000 -     0x7fff96d48fff  libMatch.1.dylib (27) <15FC6217-23E1-3DF0-A5F5-E4C67AED70B5> /usr/lib/libMatch.1.dylib
                  0x7fff96d49000 -     0x7fff96d49fff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
                  0x7fff96d4a000 -     0x7fff96d4dffb  libScreenReader.dylib (477.10.20) <B48924E9-5301-3141-9D62-ADA2852D5BAA> /usr/lib/libScreenReader.dylib
                  0x7fff96d4e000 -     0x7fff96d4fff3  libSystem.B.dylib (1238) <CFC3669C-FB44-3A51-8815-1E84A168F3C5> /usr/lib/libSystem.B.dylib
                  0x7fff96dbb000 -     0x7fff96de6ffb  libarchive.2.dylib (41.20.1) <FC116AC3-EB4A-3252-821C-4E1703879C82> /usr/lib/libarchive.2.dylib
                  0x7fff96de7000 -     0x7fff96e5bfff  libate.dylib (1.12.12) <DD989482-B873-3094-97BB-2B5AE8D3B544> /usr/lib/libate.dylib
                  0x7fff96e5f000 -     0x7fff96e5fff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
                  0x7fff96e60000 -     0x7fff96e70ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
                  0x7fff96e71000 -     0x7fff96e7fff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
                  0x7fff96e80000 -     0x7fff96ed6ff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
                  0x7fff96ed7000 -     0x7fff96f01fff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
                  0x7fff96f02000 -     0x7fff96f12ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
                  0x7fff96f13000 -     0x7fff96f28fc3  libcompression.dylib (34) <1691D6F2-46CD-3DA6-B44F-24CDD9BD0E4E> /usr/lib/libcompression.dylib
                  0x7fff96f29000 -     0x7fff96f29ff7  libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
                  0x7fff96f2a000 -     0x7fff96f2bffb  libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
                  0x7fff96fe5000 -     0x7fff970c9ff3  libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
                  0x7fff97267000 -     0x7fff972baff7  libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
                  0x7fff9730b000 -     0x7fff97312ff3  libdscsym.dylib (145) <A130C01E-AC0A-3733-B34C-71741DFFCC7E> /usr/lib/libdscsym.dylib
                  0x7fff97334000 -     0x7fff97334fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
                  0x7fff97344000 -     0x7fff97349ff7  libheimdal-asn1.dylib (498.20.2) <C9B5464F-4A2E-3E3F-B514-B0911B5CB0DA> /usr/lib/libheimdal-asn1.dylib
                  0x7fff9734a000 -     0x7fff9743cff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
                  0x7fff9743d000 -     0x7fff97662fff  libicucore.A.dylib (57132.0.1) <C8176937-9271-3F0E-829D-F3BBB9DD44B5> /usr/lib/libicucore.A.dylib
                  0x7fff97668000 -     0x7fff97669fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
                  0x7fff9766a000 -     0x7fff97683ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
                  0x7fff97684000 -     0x7fff9769aff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
                  0x7fff9769b000 -     0x7fff97945fff  libmecabra.dylib (744.2.2) <C6C3EA2C-1DC7-3DCB-8A20-C645E38524AB> /usr/lib/libmecabra.dylib
                  0x7fff97978000 -     0x7fff979f1ff3  libnetwork.dylib (856.20.4) <5012EFF3-8FF4-317D-B328-AB21E3B5CA8C> /usr/lib/libnetwork.dylib
                  0x7fff979f2000 -     0x7fff97dc2d97  libobjc.A.dylib (706) <F9AFE665-A3A2-3285-9495-19803A565861> /usr/lib/libobjc.A.dylib
                  0x7fff97dc5000 -     0x7fff97dc9fff  libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
                  0x7fff97dca000 -     0x7fff97dfaff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
                  0x7fff97e18000 -     0x7fff97e34ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
                  0x7fff97e35000 -     0x7fff97e6eff3  libsandbox.1.dylib (592.21.2) <7A698C92-CD5C-3BFF-A215-2BE2DE31F88E> /usr/lib/libsandbox.1.dylib
                  0x7fff97e82000 -     0x7fff97e83ff3  libspindump.dylib (229) <322AE558-5040-3F9A-8203-F64D8B0B507A> /usr/lib/libspindump.dylib
                  0x7fff97e84000 -     0x7fff97fccfff  libsqlite3.dylib (252) <FCA29CD2-E8E4-3324-8E2C-19BDC11F0338> /usr/lib/libsqlite3.dylib
                  0x7fff98028000 -     0x7fff98078fff  libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
                  0x7fff980be000 -     0x7fff980cbfff  libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
                  0x7fff980cf000 -     0x7fff981beffb  libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
                  0x7fff981bf000 -     0x7fff981e8fff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
                  0x7fff981e9000 -     0x7fff981faff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
                  0x7fff98209000 -     0x7fff9820dff7  libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
                  0x7fff9820e000 -     0x7fff98218fff  libcommonCrypto.dylib (60092.20.1) <31040F10-5E57-3B9C-8D5B-33AD87D1BEE8> /usr/lib/system/libcommonCrypto.dylib
                  0x7fff98219000 -     0x7fff98220fff  libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
                  0x7fff98221000 -     0x7fff98229fff  libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
                  0x7fff9822a000 -     0x7fff982acfdb  libcorecrypto.dylib (442.20.2) <2684CC01-087E-33E2-8219-AAA3BBD9BFD7> /usr/lib/system/libcorecrypto.dylib
                  0x7fff982ad000 -     0x7fff982dffff  libdispatch.dylib (703.20.1) <877B505D-826C-3246-84F7-0F850636039E> /usr/lib/system/libdispatch.dylib
                  0x7fff982e0000 -     0x7fff982e5ff3  libdyld.dylib (421.2) <7BFA3476-6210-3BCB-8CE8-9B952F87BD84> /usr/lib/system/libdyld.dylib
                  0x7fff982e6000 -     0x7fff982e6ffb  libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
                  0x7fff982e7000 -     0x7fff982f3ffb  libkxld.dylib (3789.21.3) <F12B5274-44AD-3268-A793-31EF351A4BD9> /usr/lib/system/libkxld.dylib
                  0x7fff982f4000 -     0x7fff982f4fff  liblaunch.dylib (972.20.3) <7AB2E2EA-8B47-3420-87CE-5EE18A4EEE49> /usr/lib/system/liblaunch.dylib
                  0x7fff982f5000 -     0x7fff982fafff  libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
                  0x7fff982fb000 -     0x7fff982fdff3  libquarantine.dylib (85) <F3E47D7C-8776-327C-9426-DD7DEB30DBDD> /usr/lib/system/libquarantine.dylib
                  0x7fff982fe000 -     0x7fff982ffffb  libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
                  0x7fff98300000 -     0x7fff98318ff7  libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
                  0x7fff98319000 -     0x7fff98319ff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
                  0x7fff9831a000 -     0x7fff983a7fef  libsystem_c.dylib (1158.20.4) <5F9531F5-EDA3-3D25-A827-3E0FD6B392BA> /usr/lib/system/libsystem_c.dylib
                  0x7fff983a8000 -     0x7fff983abffb  libsystem_configuration.dylib (888.20.5) <CDC55FCB-C1FC-350D-A919-5DBCFC835B63> /usr/lib/system/libsystem_configuration.dylib
                  0x7fff983ac000 -     0x7fff983affff  libsystem_coreservices.dylib (41.2) <5DE691C6-7EE6-3210-895D-9EA3ECBC09B4> /usr/lib/system/libsystem_coreservices.dylib
                  0x7fff983b0000 -     0x7fff983c8ffb  libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
                  0x7fff983c9000 -     0x7fff983cffff  libsystem_dnssd.dylib (765.20.4) <28E52C39-DF10-340F-A3EC-C0119AF6361F> /usr/lib/system/libsystem_dnssd.dylib
                  0x7fff983d0000 -     0x7fff983f9fff  libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
                  0x7fff983fa000 -     0x7fff9841cff7  libsystem_kernel.dylib (3789.21.3) <EC53F92A-0DFA-3027-A220-414A01F17B2E> /usr/lib/system/libsystem_kernel.dylib
                  0x7fff9841d000 -     0x7fff98464fe7  libsystem_m.dylib (3121.4) <7F86C291-B105-31C1-9923-90EBAB22B73F> /usr/lib/system/libsystem_m.dylib
                  0x7fff98465000 -     0x7fff98483ff7  libsystem_malloc.dylib (116) <F9840080-4C2C-3F3B-8087-7C738F12A1C7> /usr/lib/system/libsystem_malloc.dylib
                  0x7fff98484000 -     0x7fff984dbff3  libsystem_network.dylib (856.20.4) <2BAFB24F-999C-3148-BDD8-F28E05F716F7> /usr/lib/system/libsystem_network.dylib
                  0x7fff984dc000 -     0x7fff984e5ff3  libsystem_networkextension.dylib (563.20.3) <971DD3AD-D17A-32FF-95DE-0A5A979E68AE> /usr/lib/system/libsystem_networkextension.dylib
                  0x7fff984e6000 -     0x7fff984efff3  libsystem_notify.dylib (165.20.1) <EAD023A2-AD3F-31C8-9489-274B9A42DA61> /usr/lib/system/libsystem_notify.dylib
                  0x7fff984f0000 -     0x7fff984f8fe7  libsystem_platform.dylib (126.1.2) <2F2D6A81-C36C-353D-B27B-A6643A32375E> /usr/lib/system/libsystem_platform.dylib
                  0x7fff984f9000 -     0x7fff98503ff7  libsystem_pthread.dylib (218.20.1) <46375095-4731-3034-9D87-396DE95FC697> /usr/lib/system/libsystem_pthread.dylib
                  0x7fff98504000 -     0x7fff98507ff7  libsystem_sandbox.dylib (592.21.2) <2D42A2BF-A7AF-352A-A821-D8F6E85A63AC> /usr/lib/system/libsystem_sandbox.dylib
                  0x7fff98508000 -     0x7fff98509fff  libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
                  0x7fff9850a000 -     0x7fff98511fff  libsystem_symptoms.dylib (532.1.1) <8FB7CA37-79EF-3651-B5B9-B5E1E0947067> /usr/lib/system/libsystem_symptoms.dylib
                  0x7fff98512000 -     0x7fff98532ff7  libsystem_trace.dylib (518.20.8) <C029B910-A65F-35F6-B194-B933B454EAB4> /usr/lib/system/libsystem_trace.dylib
                  0x7fff98533000 -     0x7fff98538ffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
                  0x7fff98539000 -     0x7fff98562ff7  libxpc.dylib (972.20.3) <85EB25FD-218F-38EE-9E69-391CC8EBE6C5> /usr/lib/system/libxpc.dylib
              External Modification Summary:
                Calls made by other processes targeting this process:
                  task_for_pid: 2
                  thread_create: 0
                  thread_set_state: 0
                Calls made by this process:
                  task_for_pid: 0
                  thread_create: 0
                  thread_set_state: 0
                Calls made by all processes on this machine:
                  task_for_pid: 6622
                  thread_create: 0
                  thread_set_state: 0
              VM Region Summary:
              ReadOnly portion of Libraries: Total=459.2M resident=0K(0%) swapped_out_or_unallocated=459.2M(100%)
              Writable regions: Total=4.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.1G(100%)
                                              VIRTUAL   REGION
              REGION TYPE                        SIZE    COUNT (non-coalesced)
              Accelerate framework              1280K        9
              Activity Tracing                   256K        2
              CG backing stores                237.8M       24
              CG image                          19.5M      160
              CoreAnimation                      600K       15
              CoreUI image data                 2832K       21
              CoreUI image file                  156K        4
              Foundation                           4K        2
              Image IO                         142.5M      329
              Kernel Alloc Once                    8K        2
              MALLOC                             3.7G     2098
              MALLOC guard page                   48K       10
              MALLOC_LARGE (reserved)           36.6M       28         reserved VM address space (unallocated)
              Memory Tag 242                      12K        2
              OpenCL                              16K        3
              OpenGL GLSL                        256K        4
              SQLite page cache                   64K        2
              STACK GUARD                       56.1M       39
              Stack                             26.8M       42
              VM_ALLOCATE                       1468K       47
              __DATA                            35.5M      341
              __GLSLBUILTINS                    2588K        2
              __IMAGE                            528K        2
              __LINKEDIT                       124.4M       66
              __TEXT                           334.7M      324
              __UNICODE                          556K        2
              mapped file                       63.0M      272
              shared memory                     16.4M       17
              TOTAL                              4.7G     3841
              TOTAL, minus reserved VM space     4.7G     3841
              Model: iMac17,1, BootROM IM171.0105.B09, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.34f2
              Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe, 2048 MB
              Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
              Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
              Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
              Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.21.171.47.1a8)
              Bluetooth: Version 5.0.1f7, 3 services, 17 devices, 1 incoming serial ports
              Network Service: Ethernet, Ethernet, en0
              Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
              Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
              USB Device: USB 3.0 Bus
              USB Device: LRW400
              USB Device: Keyboard Hub
              USB Device: Apple Optical USB Mouse
              USB Device: Apple Keyboard
              USB Device: Bluetooth USB Host Controller
              USB Device: FaceTime HD Camera (Built-in)
              USB Device: USB2.0 Hub
              USB Device: HP LaserJet 1200
              Thunderbolt Bus: iMac, Apple Inc., 28.1
              • 4. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                Teri Bloom Level 1
                crash upon batch export, exporting about 25 RAWs:
                Process:               Adobe Lightroom [1585]
                Path:                  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                Identifier:            com.adobe.Lightroom6
                Version:               Adobe Lightroom [1099473] (6.8)
                Code Type:             X86-64 (Native)
                Parent Process:        ??? [1]
                Responsible:           Adobe Lightroom [1585]
                User ID:               501
                Date/Time:             2016-12-13 16:16:10.054 -0500
                OS Version:            Mac OS X 10.12.1 (16B2555)
                Report Version:        12
                Anonymous UUID:        9180ABFE-5120-BEC5-2C00-619C6C57699E
                Sleep/Wake UUID:       95E4FE48-40C1-4FE3-B911-ADE2C8F614DD
                Time Awake Since Boot: 16000 seconds
                Time Since Wake:       6500 seconds
                System Integrity Protection: enabled
                Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
                Exception Codes:       KERN_INVALID_ADDRESS at 0x000058a96884bec0
                Exception Note:        EXC_CORPSE_NOTIFY
                Termination Signal:    Segmentation fault: 11
                Termination Reason:    Namespace SIGNAL, Code 0xb
                Terminating Process:   exc handler [0]
                VM Regions Near 0x58a96884bec0:
                    Image IO               00000002451d8000-0000000245480000 [ 2720K] rw-/rwx SM=PRV
                    MALLOC_NANO            0000600000000000-0000600008600000 [134.0M] rw-/rwx SM=PRV
                Application Specific Information:
                objc_msgSend() selector name: objectForKey:
                Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                0   libobjc.A.dylib               0x00007fff979f8b5d objc_msgSend + 29
                1   com.apple.Foundation           0x00007fff84d76de6 __98-[NSObject(NSKeyValueObservingPrivate) _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:]_block_invoke.158 + 39
                2   com.apple.CoreFoundation       0x00007fff833223cc ____NSDictionaryEnumerate_block_invoke.431 + 28
                3   com.apple.CoreFoundation       0x00007fff831d505a CFBasicHashApply + 122
                4   com.apple.CoreFoundation       0x00007fff83218460 __NSDictionaryEnumerate + 288
                5   com.apple.Foundation           0x00007fff84d76bc2 -[NSObject(NSKeyValueObservingPrivate) _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:] + 703
                6   com.apple.CoreFoundation       0x00007fff832fc64a forEachObserver + 298
                7   com.apple.CoreFoundation       0x00007fff832fc868 -[CFPrefsSource _notifyObserversOfChangeFromValuesForKeys:toValuesForKeys:] + 72
                8   com.apple.CoreFoundation       0x00007fff8334a044 -[CFPrefsSearchListSource alreadylocked_setValues:forKeys:count:] + 1268
                9   com.apple.CoreFoundation       0x00007fff832fc356 -[CFPrefsSource setValues:forKeys:count:removeValuesForKeys:count:] + 262
                10  com.apple.CoreFoundation       0x00007fff831dcc40 -[CFPrefsSource setValues:forKeys:count:] + 32
                11  com.apple.CoreFoundation       0x00007fff832275ea -[CFPrefsSource setValue:forKey:] + 58
                12  com.apple.CoreFoundation       0x00007fff8334ba12 __108-[_CFXPreferences(SearchListAdditions) withSearchListForIdentifier:container:cloudConfigurationURL:perform:]_block_invoke + 290
                13  com.apple.CoreFoundation       0x00007fff8334b889 -[_CFXPreferences(SearchListAdditions) withSearchListForIdentifier:container:cloudConfigurationURL:perform:] + 345
                14  com.apple.CoreFoundation       0x00007fff83378125 -[_CFXPreferences setValue:forKey:appIdentifier:container:configurationURL:] + 261
                15  com.apple.CoreFoundation       0x00007fff83227534 _CFPreferencesSetAppValueWithContainer + 68
                16  com.apple.Foundation           0x00007fff84c2ebbf -[NSUserDefaults(NSUserDefaults) setObject:forKey:] + 55
                17  com.adobe.ag.substrate         0x000000010add7435 AgPreferences_storeValue(NSString*, objc_object*) + 145
                18  com.adobe.ag.substrate         0x000000010add739d 0x10adc0000 + 95133
                19  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                20  com.adobe.ag.kernel           0x000000010ac910d0 0x10ac87000 + 41168
                21  com.adobe.ag.kernel           0x000000010ac9fc03 0x10ac87000 + 101379
                22  com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                23  com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                24  com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                25  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                26  com.adobe.ag.kernel           0x000000010ac8aec6 0x10ac87000 + 16070
                27  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                28  com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                29  com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                30  com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                31  com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                32  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                33  com.adobe.ag.ui               0x000000010acffd7a 0x10acce000 + 204154
                34  libsystem_trace.dylib         0x00007fff98517c41 _os_activity_initiate + 61
                35  com.apple.AppKit               0x00007fff815b8d8e -[NSApplication(NSResponder) sendAction:to:from:] + 456
                36  com.apple.AppKit               0x00007fff811035c4 -[NSControl sendAction:to:] + 86
                37  com.apple.AppKit               0x00007fff811034ec __26-[NSCell _sendActionFrom:]_block_invoke + 136
                38  libsystem_trace.dylib         0x00007fff98517c41 _os_activity_initiate + 61
                39  com.apple.AppKit               0x00007fff81103444 -[NSCell _sendActionFrom:] + 128
                40  com.apple.AppKit               0x00007fff81145d6c -[NSButtonCell _sendActionFrom:] + 98
                41  libsystem_trace.dylib         0x00007fff98517c41 _os_activity_initiate + 61
                42  com.apple.AppKit               0x00007fff81101d2b -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2481
                43  com.apple.AppKit               0x00007fff81145aa6 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 798
                44  com.apple.AppKit               0x00007fff811006e3 -[NSControl mouseDown:] + 832
                45  com.apple.AppKit               0x00007fff817196f3 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
                46  com.apple.AppKit               0x00007fff81715f10 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
                47  com.apple.AppKit               0x00007fff817153ae -[NSWindow(NSEventRouting) sendEvent:] + 541
                48  com.adobe.ag.ui               0x000000010acf7edb 0x10acce000 + 171739
                49  com.apple.AppKit               0x00007fff815b54cd -[NSApplication(NSEvent) sendEvent:] + 1145
                50  com.adobe.ag.ui               0x000000010ad42ec4 0x10acce000 + 478916
                51  com.apple.AppKit               0x00007fff80e96589 -[NSApplication run] + 1002
                52  com.apple.AppKit               0x00007fff80e611ad NSApplicationMain + 1237
                53  com.adobe.Lightroom6           0x000000010aac9b97 main + 1095
                54  libdyld.dylib                 0x00007fff982e5255 start + 1
                Thread 1:: Worker Thread Dispatcher
                0   libsystem_kernel.dylib         0x00007fff98413c8a __psynch_cvwait + 10
                1   libsystem_pthread.dylib       0x00007fff984fd96a _pthread_cond_wait + 712
                2   com.adobe.ag.kernel           0x000000010acaddd4 AgConditionLock_wait + 38
                3   com.adobe.ag.kernel           0x000000010aca7857 AgTransitQueue_dequeueToLuaState + 91
                4   com.adobe.ag.kernel           0x000000010aca82f9 0x10ac87000 + 135929
                5   com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                6   com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                7   com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                8   com.adobe.ag.kernel           0x000000010ac890f1 lua_call + 37
                9   com.adobe.ag.substrate         0x000000010ade002d AgLua_callWithAutoReleasePool + 85
                10  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                11  com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                12  com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                13  com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                14  com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                15  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                16  com.adobe.ag.substrate         0x000000010add35cb 0x10adc0000 + 79307
                17  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
                18  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                19  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                20  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 2:: cr_scratch
                2   com.adobe.ag.AgImageIO         0x000000010d9c01cb 0x10d82b000 + 1659339
                3   com.adobe.ag.AgImageIO         0x000000010dbd434b 0x10d82b000 + 3838795
                4   com.adobe.ag.AgImageIO         0x000000010d987a41 0x10d82b000 + 1428033
                5   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                6   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                7   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 3:: Queue Processor - AgPhotoAvailability
                6   com.adobe.ag.kernel           0x000000010ac910d0 0x10ac87000 + 41168
                7   com.adobe.ag.kernel           0x000000010ac890f1 lua_call + 37
                8   com.adobe.ag.substrate         0x000000010ade002d AgLua_callWithAutoReleasePool + 85
                10  com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                11  com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                12  com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                13  com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                14  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                15  com.adobe.ag.kernel           0x000000010ac8aec6 0x10ac87000 + 16070
                16  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                17  com.adobe.ag.kernel           0x000000010ac910d0 0x10ac87000 + 41168
                18  com.adobe.ag.kernel           0x000000010ac890f1 lua_call + 37
                19  com.adobe.ag.substrate         0x000000010ade002d AgLua_callWithAutoReleasePool + 85
                20  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                21  com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                26  com.adobe.ag.substrate         0x000000010add35cb 0x10adc0000 + 79307
                27  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
                28  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                29  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                30  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 4:: AsyncDataServer
                2   com.adobe.ag.kernel           0x000000010acade68 AgConditionLock_wait + 186
                Thread 5:: com.apple.NSURLConnectionLoader
                0   libsystem_kernel.dylib         0x00007fff9840c41a mach_msg_trap + 10
                1   libsystem_kernel.dylib         0x00007fff9840b867 mach_msg + 55
                2   com.apple.CoreFoundation       0x00007fff8321b834 __CFRunLoopServiceMachPort + 212
                3   com.apple.CoreFoundation       0x00007fff8321acc1 __CFRunLoopRun + 1361
                4   com.apple.CoreFoundation       0x00007fff8321a514 CFRunLoopRunSpecific + 420
                5   com.apple.CFNetwork           0x00007fff823eb334 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
                6   com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
                7   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                8   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                9   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 6:: com.apple.CFSocket.private
                0   libsystem_kernel.dylib         0x00007fff98413f4e __select + 10
                1   com.apple.CoreFoundation       0x00007fff8325668a __CFSocketManager + 682
                2   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                3   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                4   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 7:: com.apple.NSEventThread
                5   com.apple.AppKit               0x00007fff80fee5a0 _NSEventThread + 205
                6   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                7   libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                8   libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 8:: Preview Server
                Thread 9:: Queue Processor - PreviewFileStore
                Thread 10:
                2   com.adobe.headlights.LogSessionFramework 0x000000011ac5cccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                3   com.adobe.headlights.LogSessionFramework 0x000000011ac5b5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
                4   com.adobe.headlights.LogSessionFramework 0x000000011ac09059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
                5   com.adobe.headlights.LogSessionFramework 0x000000011abd7cfb RealTimeProcessor::WorkerThread(int, int) + 3633
                6   com.adobe.headlights.LogSessionFramework 0x000000011ac5a969 boost::(anonymous namespace)::thread_proxy(void*) + 185
                Thread 11:: Queue Processor - NegativeQueue
                Thread 12:: Queue Processor - HistogramQueue
                Thread 13:: Queue Processor - RenderQueue_Render
                Thread 14:: Queue Processor - RenderQueue_ReadPreview
                Thread 15:: Queue Processor - RenderQueue_Video
                Thread 16:: Queue Processor - RenderQueue_Face
                Thread 17:: Worker Thread
                8   com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                9   com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                10  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                11  com.adobe.ag.kernel           0x000000010ac8aec6 0x10ac87000 + 16070
                12  com.adobe.ag.kernel           0x000000010ac90e15 0x10ac87000 + 40469
                13  com.adobe.ag.kernel           0x000000010ac910d0 0x10ac87000 + 41168
                14  com.adobe.ag.kernel           0x000000010ac890f1 lua_call + 37
                15  com.adobe.ag.substrate         0x000000010ade002d AgLua_callWithAutoReleasePool + 85
                17  com.adobe.ag.kernel           0x000000010ac9f55d 0x10ac87000 + 99677
                18  com.adobe.ag.kernel           0x000000010ac910e1 0x10ac87000 + 41185
                19  com.adobe.ag.kernel           0x000000010ac9077e 0x10ac87000 + 38782
                20  com.adobe.ag.kernel           0x000000010ac9133d 0x10ac87000 + 41789
                21  com.adobe.ag.kernel           0x000000010ac89172 lua_pcall + 100
                22  com.adobe.ag.substrate         0x000000010add35cb 0x10adc0000 + 79307
                23  com.apple.Foundation           0x00007fff84c2830d __NSThread__start__ + 1243
                24  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                25  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                26  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 18:: Worker Thread
                Thread 19:
                0   libsystem_kernel.dylib         0x00007fff98413e8e __recvfrom + 10
                1   VulcanMessage5.dylib           0x00000001317a1386 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
                2   VulcanMessage5.dylib           0x00000001317a05fd vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
                3   VulcanMessage5.dylib           0x000000013179f9b8 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
                4   VulcanMessage5.dylib           0x000000013179f8ee vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
                5   VulcanMessage5.dylib           0x000000013179a498 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
                6   VulcanMessage5.dylib           0x000000013179a936 vcfoundation::io::Serializer::InternalDeserialize() + 30
                7   VulcanMessage5.dylib           0x000000013179a8dd vcfoundation::io::Serializer::Deserialize() + 9
                8   VulcanMessage5.dylib           0x000000013179e762 vcfoundation::ncomm::Connection::ReadIn() + 22
                9   VulcanMessage5.dylib           0x000000013179e489 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
                10  VulcanMessage5.dylib           0x000000013179e10a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
                11  VulcanMessage5.dylib           0x000000013179e05d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
                12  VulcanMessage5.dylib           0x0000000131790e66 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
                13  VulcanMessage5.dylib           0x000000013179191f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
                14  VulcanMessage5.dylib           0x000000013179f288 vcfoundation::thread::AbstractThread::Run() + 50
                15  VulcanMessage5.dylib           0x00000001317a0da9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
                16  libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                17  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                18  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 20:: Worker Thread
                Thread 21:: Queue Processor - AgAsyncRenderingQueue
                Thread 22:: Queue Processor - OpenNegativesForDevelop
                Thread 23:
                2   com.apple.CoreServices.CarbonCore 0x00007fff8413c7b1 TSWaitOnCondition + 108
                3   com.apple.CoreServices.CarbonCore 0x00007fff8413c9b0 TSWaitOnConditionTimedRelative + 171
                4   com.apple.CoreServices.CarbonCore 0x00007fff84115b60 MPWaitOnQueue + 192
                5   com.adobe.dvacore.framework   0x0000000119c05698 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
                6   com.adobe.dvacore.framework   0x0000000119c029f8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
                7   com.adobe.dvacore.framework   0x0000000119bff3c6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
                8   com.adobe.boost_threads.framework 0x0000000114c3a7c5 boost::(anonymous namespace)::thread_proxy(void*) + 133
                9   libsystem_pthread.dylib       0x00007fff984fcaab _pthread_body + 180
                10  libsystem_pthread.dylib       0x00007fff984fc9f7 _pthread_start + 286
                11  libsystem_pthread.dylib       0x00007fff984fc221 thread_start + 13
                Thread 24:
                0   libsystem_kernel.dylib         0x00007fff98414e2e kevent + 10
                1   com.adobe.dvatransport.framework 0x0000000115ad4111 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 241
                2   com.adobe.dvatransport.framework 0x0000000115ad3cec boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
                3   com.adobe.dvatransport.framework 0x0000000115ad3858 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
                4   com.adobe.dvatransport.framework 0x0000000115ac2332 SkyConnectionEnv::MainLoop() + 162
                5   com.adobe.dvatransport.framework 0x0000000115ac1cc9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                6   com.adobe.boost_threads.framework 0x0000000114c3a7c5 boost::(anonymous namespace)::thread_proxy(void*) + 133
                Thread 25:
                2   com.adobe.dvatransport.framework 0x0000000115ad3d8b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
                4   com.adobe.dvatransport.framework 0x0000000115ad35fa boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
                5   com.adobe.dvatransport.framework 0x0000000115ad4863 boost_asio_detail_posix_thread_function + 19
                Thread 26:
                Thread 27:
                Thread 28:
                Thread 29:
                0   libsystem_pthread.dylib       0x00007fff984fc204 start_wqthread + 0
                1   ???                           0x00007fc9b8290810 0 + 140504354850832
                Thread 30:
                0   libsystem_kernel.dylib         0x00007fff984144e6 __workq_kernreturn + 10
                1   libsystem_pthread.dylib       0x00007fff984fc622 _pthread_wqthread + 1023
                2   libsystem_pthread.dylib       0x00007fff984fc211 start_wqthread + 13
                Thread 31:
                1   libsystem_pthread.dylib       0x00007fff984fc7b5 _pthread_wqthread + 1426
                Thread 32:: Dispatch queue: NSUserDefaults/CFPreferences Reloading Data in Response to KVO Notifications
                0   com.apple.CoreFoundation       0x00007fff8319c3f8 __CFStringHash + 200
                1   com.apple.CoreFoundation       0x00007fff8319b38a CFBasicHashAddValue + 234
                2   com.apple.CoreFoundation       0x00007fff831d517d CFDictionaryAddValue + 221
                3   com.apple.CoreFoundation       0x00007fff831d5096 __CFDictionaryApplyFunction_block_invoke + 22
                4   com.apple.CoreFoundation       0x00007fff831d505a CFBasicHashApply + 122
                5   com.apple.CoreFoundation       0x00007fff831d4f99 CFDictionaryApplyFunction + 185
                6   com.apple.CoreFoundation       0x00007fff831d4d78 -[CFPrefsPlistSource mergeIntoDictionary:] + 728
                7   com.apple.CoreFoundation       0x00007fff831ceadf -[CFPrefsSearchListSource alreadylocked_copyDictionary] + 511
                8   com.apple.CoreFoundation       0x00007fff831d6d4f -[CFPrefsSource copyDictionary] + 47
                9   com.apple.CoreFoundation       0x00007fff8334afb9 -[CFPrefsSearchListSource generationCount] + 41
                10  com.apple.CoreFoundation       0x00007fff8334af7b reloadSearchListCallback + 27
                11  libdispatch.dylib             0x00007fff982af128 _dispatch_client_callout + 8
                12  libdispatch.dylib             0x00007fff982c5b97 _dispatch_queue_serial_drain + 896
                13  libdispatch.dylib             0x00007fff982b7d41 _dispatch_queue_invoke + 1046
                14  libdispatch.dylib             0x00007fff982be158 _dispatch_queue_override_invoke + 369
                15  libdispatch.dylib             0x00007fff982b0ee0 _dispatch_root_queue_drain + 476
                16  libdispatch.dylib             0x00007fff982b0cb7 _dispatch_worker_thread3 + 99
                17  libsystem_pthread.dylib       0x00007fff984fc736 _pthread_wqthread + 1299
                18  libsystem_pthread.dylib       0x00007fff984fc211 start_wqthread + 13
                Thread 33:
                Thread 34:
                1   ???                           0x000000000001a4ab 0 + 107691
                Thread 0 crashed with X86 Thread State (64-bit):
                  rax: 0x000058a96884bea8  rbx: 0x00007fff55136128  rcx: 0x00007fff9daf8198  rdx: 0x0000618009e4e700
                  rdi: 0x00006080062675c0  rsi: 0x00007fff819e05e0  rbp: 0x00007fff55135e10  rsp: 0x00007fff55135de8
                   r8: 0x00006080062675c0   r9: 0x0000000000000300  r10: 0x000058a96884bea8  r11: 0x00007fff819e05e0
                  r12: 0x0000000000000af3  r13: 0x0000000000000448  r14: 0x0000618009e4e700  r15: 0x0018010828810885
                  rip: 0x00007fff979f8b5d  rfl: 0x0000000000010202  cr2: 0x000058a96884bec0
                Logical CPU:     4
                Error Code:      0x00000004
                Trap Number:     14
                Binary Images:
                       0x10aac8000 -        0x10aae3ff7 +com.adobe.Lightroom6 (Adobe Lightroom [1099473] - 6.8) <D8B226C8-8626-3216-9470-6BF8F057CF4E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                       0x10aafa000 -        0x10ac54feb +ZXPSignLib-minimal-dylib.dylib (0) <C7407AC6-367A-3281-81F8-B49A3484014C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                       0x10ac87000 -        0x10acbcff7 +com.adobe.ag.kernel (AgKernel Version 1.0 - 1.0) <A160885A-AC78-3C55-A849-6801B2CEB2CC> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                       0x10acce000 -        0x10ad77fff +com.adobe.ag.ui (views version 0.0.1d1 - 0) <FE173000-1F8A-342C-9A04-55A148CE14DD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgUI.framework/Versions/A/AgUI
                       0x10adc0000 -        0x10adf9fff +com.adobe.ag.substrate (com.adobe.ag.substrate 6.8 - 1.0) <40AE7192-620E-37D8-8DCC-BA159B70BFDB> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgSubstrate.framework/Versions/A/AgSubstrate
                       0x10ae1f000 -        0x10af22fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                       0x10af3b000 -        0x10b179fff +com.adobe.wichitafoundation (com.adobe.wichitafoundation 6.8 - 1.0) <A99508D9-9ADF-33D9-9864-45303EE450F8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/WichitaFoundatio n
                       0x10cb8c000 -        0x10cb8cfff +com.adobe.lightroom.AdobeCrashReporter (1.0) <7AAFE1B2-F362-3E7F-B0E3-28EDC8E5076D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Adobe Crash Reporter.bundle/Contents/MacOS/Adobe Crash Reporter
                       0x10cb91000 -        0x10cb94fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashRepor ter
                       0x10cbdb000 -        0x10cd26fff +IMSLib.dylib (10.0.0.7 - 10.0.0.7) <1DD294BF-3FEB-3BBF-A27C-94D2445CB4B4> /Library/Application Support/Adobe/*/IMSLib.dylib
                       0x10cd55000 -        0x10cd98ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifi cations
                       0x10d82b000 -        0x110696ff7 +com.adobe.ag.AgImageIO (com.adobe.ag.AgImageIO 6.8 - 1.0.0d1) <1654FD7A-D9D5-32B6-8275-FBCFC5903CD5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CameraRaw.lrtoolkit/CameraRaw
                       0x111d4d000 -        0x111d4eff7 +com.adobe.ag.xml (com.adobe.ag.xml 6.8 - 1.0) <BC62F95B-8E5D-31C8-8FFC-C44E1FE40534> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/XML.agtoolkit/Contents/MacOS/XML
                       0x111d60000 -        0x111d9d287  dyld (421.2) <13A9466A-2576-3ABB-AD9D-D6BC16439B8F> /usr/lib/dyld
                       0x112985000 -        0x112a47fff  com.apple.AMDRadeonX4000GLDriver (1.46.22 - 1.4.6) <DEF17B2F-758C-36C1-85C8-22BB4E135BD3> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
                       0x112a60000 -        0x112f15ff7  ATIRadeonX4000SCLib.dylib (1.46.22) <9638B1B1-4253-3EB2-86B9-D3581DDADFCC> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCL ib.dylib
                       0x1145e3000 -        0x1145eefff +com.adobe.ag.video-toolkit (com.adobe.ag.video_toolkit 6.8 - 1) <49A9882E-9894-347A-9C42-734174D724BE> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/video_toolkit.agtoolkit/Contents/MacOS/video_toolkit
                       0x11464b000 -        0x11468affb  com.apple.glut (3.6.8 - GLUT-3.6.8) <E8DEAF6F-C152-3AE4-9EAF-5787FB2F4055> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                       0x1146ff000 -        0x114740ff7 +com.adobe.ag.bridgetalk (com.adobe.ag.bridgetalk 6.8 - 1.0) <4717BFA1-E637-3AD7-93BA-854F1DB3EAB1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/BridgeTalk.agtoolkit/Contents/MacOS/BridgeTalk
                       0x11476c000 -        0x1147cdff7 +com.adobe.ag.imageanalysis (com.adobe.ag.imageanalysis 6.8 - 1.0) <4B9E07A6-DC57-3094-9905-9A0CEFB9D371> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ImageAnalysis.agtoolkit/Contents/MacOS/ImageAnalysis
                       0x1147db000 -        0x11489dff7 +com.adobe.CIT (2.4.0.1 - 2.4.0.1) <A47A6903-F975-3CFC-85B1-B70D00CEB3A1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CIT.framework/Versions/A/CIT
                       0x1148db000 -        0x1148defff +com.adobe.CITThreading (2.4.0.1 - 2.4.0.1) <39504412-313C-360F-9E36-1CC9ECA7F013> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
                       0x1149ef000 -        0x1149f4ff7 +com.adobe.lightroom.import (com.adobe.ag.import 6.8 - 1.0) <283428A1-4385-342A-8F01-A2DB5E4AF1DB> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Import.lrmodule/Contents/MacOS/Import
                       0x114aab000 -        0x114acafff +com.adobe.dvaunittesting.framework (10.0.0 - 10.0.0.0) <8870DA93-DED0-3A8B-ADC3-1A3E6ACFFE1E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                       0x114ae6000 -        0x114b90fff +com.adobe.dvaaudiodevice.framework (10.0.0 - 10.0.0.0) <4B9990E0-16CB-310D-93FE-149CC41AFAA3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                       0x114c08000 -        0x114c14fff +com.adobe.boost_signals.framework (10.0.0 - 10.0.0.0) <1474269C-5284-3F30-8201-DA41CA4E2A11> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                       0x114c22000 -        0x114c23ff7 +com.adobe.boost_system.framework (10.0.0 - 10.0.0.0) <98844C30-9C85-3F4A-8D13-C7CFC17B7DB1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                       0x114c29000 -        0x114c2eff7 +com.adobe.boost_date_time.framework (10.0.0 - 10.0.0.0) <F14E6E9E-A697-367E-951B-65546506E5FF> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                       0x114c39000 -        0x114c48fff +com.adobe.boost_threads.framework (10.0.0 - 10.0.0.0) <EDECEA79-FB6C-3D5F-A343-E6C87E3463F2> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                       0x114c59000 -        0x114c67ff7 +com.adobe.boost_filesystem.framework (10.0.0 - 10.0.0.0) <1E799366-C8C8-3BA2-977C-82AF91971D0D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                       0x114c73000 -        0x114c9efff +com.adobe.dvamarshal.framework (10.0.0 - 10.0.0.0) <90A6AB5B-6D39-36FB-AB79-776761384263> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                       0x114cc3000 -        0x114cc4fff  com.apple.ICALogging (1.0 - 1) <89185BC7-B151-3C98-85C7-A4A83F080F18> /System/Library/PrivateFrameworks/ICALogging.framework/ICALogging
                       0x114d66000 -        0x114e2cff7 +com.adobe.dvaplayer.framework (10.0.0 - 10.0.0.0) <6AF3D151-951F-31A4-9242-2BB9A8C69A0F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                       0x114ee7000 -        0x114f28fff +com.adobe.dvamediatypes.framework (10.0.0 - 10.0.0.0) <DD99EDBD-5CAF-3493-9F5A-8D828F8C5C18> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                       0x115002000 -        0x1152a8fff +com.adobe.dynamiclink.framework (10.0.0 - 10.0.0.0) <DA4F9A10-D323-355B-9422-0533075C391F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                       0x115aa8000 -        0x115b14ff7 +com.adobe.dvatransport.framework (10.0.0 - 10.0.0.0) <11CEACAC-8A44-319E-81D9-15459B4082C8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                       0x115bff000 -        0x115c18ffb  libexpat.1.dylib (15) <617B8B7A-A0AB-37D6-AFCA-F90F7F14E455> /usr/lib/libexpat.1.dylib
                       0x11959a000 -        0x1198dfff7 +com.adobe.mediacoreif.framework (10.0.0 - 10.0.0.0) <82D0D38F-9997-3186-B90A-A60E33B51908> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                       0x119ad3000 -        0x119dddff7 +com.adobe.dvacore.framework (10.0.0 - 10.0.0.0) <545C09D5-FAD3-3B0B-B145-2D5342FEB57D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                       0x11a06d000 -        0x11a0b4ff7 +com.adobe.ag.cef-toolkit (com.adobe.ag.cef_toolkit 6.8 - 1.0) <BE9CF3C3-70BA-3FD6-AC7A-C13033696757> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/cef_toolkit.agtoolkit/Contents/MacOS/cef_toolkit
                       0x11a0d0000 -        0x11a10efff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <E57FE5B1-72E1-3606-8895-65E4C7880FA3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                       0x11a137000 -        0x11a1b0fff  com.apple.xquery (1.3.1 - 30) <9BBE7704-B310-31C7-85F6-BA033714B482> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                       0x11aa9a000 -        0x11aab2fff +com.adobe.ag.help (com.adobe.ag.help 6.8 - 1.0) <2299D896-D4B6-358C-ABB8-067533FD8514> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHelpClient.lrmodule/Contents/MacOS/AdobeHelpClient
                       0x11aabc000 -        0x11aabffff +com.adobe.ag.headlights (com.adobe.ag.Headlights 6.8 - 1.0) <17D88CE5-2894-389F-B917-B9F1FD648AF1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHeadlights.lrmodule/Contents/MacOS/AdobeHeadlights
                       0x11aac6000 -        0x11aaf8ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                       0x11ab04000 -        0x11ac9efff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/LogSession
                       0x11ad58000 -        0x11ad81fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                       0x11adfe000 -        0x11ae01ff7 +com.adobe.ag.discburning (com.adobe.ag.discburning 6.8 - 1.0) <837DDC0B-77EE-3091-BEEB-5FAF8AEEA475> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/DiscBurning.agtoolkit/Contents/MacOS/DiscBurning
                       0x11ae08000 -        0x11ae2dfff  com.apple.DiscRecordingUI (9.0.3 - 9030.4.5) <178BB77B-D4EB-3B45-A560-D24B4F6E7102> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
                       0x11ae4f000 -        0x11ae54ff7 +com.adobe.ag.email (com.adobe.ag.email 6.8 - 1.0) <D39FD838-D682-3F0F-A462-7B87EBC28100> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Email.lrmodule/Contents/MacOS/Email
                       0x11ae8c000 -        0x11b3b9fff +com.adobe.ag.coretech-toolkit (com.adobe.ag.coretech_toolkit 6.8 - 1.0) <AD810484-2C43-38BC-B0A3-5BE22AA1AA52> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CoreTechToolkit.agtoolkit/Contents/MacOS/CoreTechToolki t
                       0x11b5d7000 -        0x11b893ff3 +com.adobe.AGM (AdobeAGM 4.30.60.36125 - 4.30.60.36125) <74D5A66E-A468-3B49-9E4F-F8B580F32BF8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                       0x11b902000 -        0x11b91effb +com.adobe.BIB (AdobeBIB 1.2.03.36125 - 1.2.03.36125) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                       0x11b928000 -        0x11b94bff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                       0x11b954000 -        0x11ba99ff3 +com.adobe.ACE (AdobeACE 2.20.02.36125 - 2.20.02.36125) <833F0706-F228-39B7-BCAF-9989A47E4D55> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                       0x11bab7000 -        0x11bab7fff +com.adobe.ag.catalogconverters (com.adobe.ag.catalogconverters 6.8 - 1.0) <D16492C2-689B-3C6D-9EF0-125F2A9388C3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CatalogConverters.agtoolkit/Contents/MacOS/CatalogConve rters
                       0x11babc000 -        0x11bb87ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.36125 - 3.8.0.36125) <14364CB3-3364-3045-9BA6-B44516BA9D63> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                       0x1236dc000 -        0x127269f1f +libcef.dylib (31523.6.11) <7E427337-65A2-3B49-AD70-9C9BE02F4C01> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/libcef.dylib
                       0x12ee68000 -        0x12f156ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.36125 - 5.15.00.36125) <C7B78AC8-5659-3CD0-9483-29F9628C0C61> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                       0x12f1a0000 -        0x12f2cefff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                       0x13174d000 -        0x13175bff7 +com.adobe.ag.AgNetClient (com.adobe.ag.AgNetClient 6.8 - 1.0.0d1) <4540B8FC-D531-3BB0-BF73-EA1A4076F532> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgNetClient.agtoolkit/AgNetClient
                       0x131779000 -        0x13177bff7 +com.adobe.ag.vulcan (com.adobe.ag.vulcan 6.8 - 1.0) <ABE8F1C9-34DA-3010-AB9A-C75802860CD5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Vulcan.agtoolkit/Contents/MacOS/Vulcan
                       0x131783000 -        0x1317bbff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/VulcanMessaging.framework/Versions/A/VulcanMessage5.dyl ib
                       0x144377000 -        0x144397ff7  com.apple.CoreNLP (1.0 - 78) <3D2A949C-DE66-34F4-9A97-9817C8054CC9> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
                    0x7fff7e02d000 -     0x7fff7e365fff  com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                    0x7fff7e366000 -     0x7fff7e48dff3  com.apple.AMDMTLBronzeDriver (1.46.22 - 1.4.6) <5F462A40-03D7-34AD-9DBF-AD0A266792B9> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
                    0x7fff7fb8a000 -     0x7fff7fd48ff7  com.apple.avfoundation (2.0 - 1183.4) <CF8F272A-5046-389C-A89F-0C71CF700415> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                    0x7fff7fd49000 -     0x7fff7fdecff7  com.apple.audio.AVFAudio (1.0 - ???) <F340B5A9-80C4-39C2-952A-51F84681103F> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                    0x7fff7fe81000 -     0x7fff7fe81fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <97EF9FB3-581F-3F19-84D0-E9262559A454> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                    0x7fff7fe82000 -     0x7fff7fe99ffb  libCGInterfaces.dylib (331.5) <5796C169-B449-33C8-B471-BD711BDCB898> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                    0x7fff7fe9a000 -     0x7fff803b3feb  com.apple.vImage (8.1 - ???) <A5DBF800-F768-3A61-8575-9B45FC32FEAB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                    0x7fff803b4000 -     0x7fff80524ff3  libBLAS.dylib (1185) <C7E42BBE-2337-3AEF-9C45-A2F2CB1A5B3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                    0x7fff80525000 -     0x7fff80539ffb  libBNNS.dylib (14) <CFDEE88D-E002-347C-BC68-83099651585B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                    0x7fff8053a000 -     0x7fff80930fef  libLAPACK.dylib (1185) <2E8201CB-9A41-3D65-853E-841917FCE77B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                    0x7fff80931000 -     0x7fff80947fff  libLinearAlgebra.dylib (1185) <8CC29DE1-A231-3D5E-B5F1-DCC309036FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                    0x7fff80948000 -     0x7fff8094efff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                    0x7fff8094f000 -     0x7fff80963ff7  libSparseBLAS.dylib (1185) <C35235B7-CFA6-39A7-BD6E-79F4D9CAFD36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                    0x7fff80964000 -     0x7fff80aebfe7  libvDSP.dylib (600) <DF2860D3-1B2E-3DE0-8D8D-F567374398CB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                    0x7fff80aec000 -     0x7fff80b9effb  libvMisc.dylib (600) <5E006F98-FB5C-3AC4-B8B9-6D267B22AA72> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                    0x7fff80b9f000 -     0x7fff80b9ffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A395B521-8E54-30F2-B4FE-355D68900DAF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                    0x7fff80ba0000 -     0x7fff80be0ffb  com.apple.Accounts (113 - 113) <5EB6A20D-5A7C-321D-B3DB-FFE90D834578> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
                    0x7fff80be1000 -     0x7fff80e5aff3  com.apple.AddressBook.framework (10.0 - 1756.9) <56BAE45E-071C-3F32-8668-37E9E40A593C> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                    0x7fff80e5b000 -     0x7fff81b3bff3  com.apple.AppKit (6.9 - 1504.60) <5DA1E013-575C-34D5-A028-1639EB7B0040> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff81b4d000 -     0x7fff81b4dfff  com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                    0x7fff81b4e000 -     0x7fff81bbcff7  com.apple.ApplicationServices.ATS (377 - 422.1) <FF4D9FCA-D799-3ED1-B5F8-3D81C29342D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                    0x7fff81c56000 -     0x7fff81d84ff7  libFontParser.dylib (194.2) <E29F233F-773A-3070-874A-83799BDF0B5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                    0x7fff81d85000 -     0x7fff81dcffff  libFontRegistry.dylib (196.2) <8AEE7F4E-60F0-33BB-99E4-5381EF1FEC6F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                    0x7fff81e2c000 -     0x7fff81e5efff  libTrueTypeScaler.dylib (194.2) <A8520109-5F65-3144-ABF7-E22B98A74287> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                    0x7fff81eca000 -     0x7fff81f74ff7  com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                    0x7fff81f75000 -     0x7fff81fc5fff  com.apple.HIServices (1.22 - 590) <109A9893-313B-3467-9892-062F49D1FF0D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x7fff81fc6000 -     0x7fff81fd5ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                    0x7fff81fd6000 -     0x7fff82023fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                    0x7fff82024000 -     0x7fff8205ffff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                    0x7fff82060000 -     0x7fff8206bff7  com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                    0x7fff8206c000 -     0x7fff8227aff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <BA73DBAD-A9D2-3BA7-BCDB-4790D6C8B460> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                    0x7fff8227b000 -     0x7fff8227bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <C49668FF-2971-3E30-92BB-09E0720E74A5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                    0x7fff823e4000 -     0x7fff82768ff7  com.apple.CFNetwork (807.1.3 - 807.1.3) <336BFAD9-1BAE-368E-8C48-B9F1CC251C67> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                    0x7fff82782000 -     0x7fff82782fff  com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                    0x7fff82783000 -     0x7fff82786fff  com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                    0x7fff82787000 -     0x7fff82a8bfff  com.apple.HIToolbox (2.1.1 - 856.6) <DAF74CE6-8B6B-3347-B299-FE860B517D38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff82a8c000 -     0x7fff82a8fff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                    0x7fff82a90000 -     0x7fff82a95fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                    0x7fff82a96000 -     0x7fff82b2dff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                    0x7fff82b2e000 -     0x7fff82b48fff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                    0x7fff82b49000 -     0x7fff82b4aff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                    0x7fff82b4b000 -     0x7fff82b4dff7  com.apple.securityhi (9.0 - 55006) <FFB3F28C-B982-34EF-8510-8D6D10975404> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                    0x7fff82b4e000 -     0x7fff82b54ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                    0x7fff82b55000 -     0x7fff82c33fff  com.apple.cloudkit.CloudKit (639.2.1 - 639.2.1) <9F6CFA9A-3109-30C5-B3AB-4745489E7EBD> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                    0x7fff82c34000 -     0x7fff82c34fff  com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                    0x7fff82d6a000 -     0x7fff82dfaff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <4082E8CC-568A-364A-9AF0-92F30F067D42> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                    0x7fff82dfb000 -     0x7fff82e0eff3  com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                    0x7fff82e0f000 -     0x7fff83105ffb  com.apple.CoreData (120 - 752.2) <CCDCE896-CD36-3483-8E04-C513433BDDC5> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                    0x7fff83106000 -     0x7fff83192fff  com.apple.CoreDisplay (1.0 - 1) <ACA3B0B8-6900-3445-B202-C5C312421E44> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                    0x7fff83193000 -     0x7fff8362cff7  com.apple.CoreFoundation (6.9 - 1348.15) <C25C6FB8-E934-349C-952C-26CF913BAC33> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                    0x7fff8362d000 -     0x7fff83cabfff  com.apple.CoreGraphics (2.0 - 1070.8) <3F5B7647-8006-3738-9A5A-1AD2DF570992> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                    0x7fff83cac000 -     0x7fff83eebff7  com.apple.CoreImage (12.0.0 - 451) <4A79760F-FD23-3055-9569-5F038818993F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                    0x7fff83eec000 -     0x7fff83f48ff7  com.apple.corelocation (2100.3.14.4) <40B8B610-F93C-3708-B61D-E840E5708AC0> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                    0x7fff83f49000 -     0x7fff83ff9ff7  com.apple.CoreMedia (1.0 - 1903.11) <34BC19CF-0203-315F-A75D-1E4237BF3FF4> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                    0x7fff83ffa000 -     0x7fff84045ff7  com.apple.CoreMediaIO (803.0 - 4927) <C237F327-930D-30E7-A100-D60F28911154> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                    0x7fff84046000 -     0x7fff84046fff  com.apple.CoreServices (775.8.2 - 775.8.2) <FE7B0765-C41F-3FD9-8FD7-094466AAD0EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                    0x7fff84047000 -     0x7fff84098ff7  com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                    0x7fff84099000 -     0x7fff84374fff  com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                    0x7fff84375000 -     0x7fff843a8fff  com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                    0x7fff843a9000 -     0x7fff843b1ffb  com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                    0x7fff843b2000 -     0x7fff8451dfff  com.apple.LaunchServices (775.8.2 - 775.8.2) <7389590A-0E30-3294-B39C-F179D237F6C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                    0x7fff8451e000 -     0x7fff845ceffb  com.apple.Metadata (10.7.0 - 1075.17) <40F7E6E2-B58B-34E1-B97B-26756ECDB947> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                    0x7fff845cf000 -     0x7fff8462efff  com.apple.CoreServices.OSServices (775.8.2 - 775.8.2) <C949CF81-3510-3987-AEB4-9A961B738DA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                    0x7fff8462f000 -     0x7fff8469ffff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                    0x7fff846a0000 -     0x7fff846e6ff7  com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                    0x7fff84773000 -     0x7fff848beffb  com.apple.CoreText (352.0 - 544.1) <3229A726-303B-3B09-A014-8708C3BEF2D1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                    0x7fff848bf000 -     0x7fff848f4fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                    0x7fff848f5000 -     0x7fff84966ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <0425CA71-50D9-32DC-8693-CAE6CB3B799D> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                    0x7fff84996000 -     0x7fff849a1ff3  com.apple.DirectoryService.Framework (10.12 - 194) <829AFAAD-5742-332D-B84D-AF161FB57660> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                    0x7fff849a2000 -     0x7fff84a60ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <BB73A94D-1A40-3F62-9BD9-82DEE9DB8FE9> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                    0x7fff84a61000 -     0x7fff84a66fff  com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                    0x7fff84bf5000 -     0x7fff84f9cffb  com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                    0x7fff84fc8000 -     0x7fff84ff9fff  com.apple.GSS (4.0 - 2.0) <4F3C9982-457C-3731-85DB-8CE1A72621B0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                    0x7fff850ad000 -     0x7fff85150fff  com.apple.Bluetooth (5.0.1 - 5.0.1f7) <406E3901-F5D3-3996-84F7-32975EBE8F86> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                    0x7fff85151000 -     0x7fff851e6ff7  com.apple.framework.IOKit (2.0.2 - 1324.21.1) <EEFE7FF0-CE41-326A-A571-8AA0B2E89271> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                    0x7fff851e7000 -     0x7fff851edffb  com.apple.IOSurface (153.1 - 153.1) <849B0928-3D37-3977-9670-19979DB4EE4D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                    0x7fff851ee000 -     0x7fff85240ffb  com.apple.ImageCaptureCore (7.0 - 7.0) <B12559B1-A73A-301C-9628-27F4A765C6DF> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                    0x7fff85241000 -     0x7fff85397fef  com.apple.ImageIO.framework (3.3.0 - 1570.2) <1133B1CE-C702-3D66-80F3-6BB40D5D1178> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                    0x7fff85398000 -     0x7fff8539cfff  libGIF.dylib (1570.2) <4AE8D51B-E26A-3CB0-9D53-58112F94E3CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                    0x7fff8539d000 -     0x7fff8548dfff  libJP2.dylib (1570.2) <9F56888C-28CD-3ED0-B7BB-FFB775EF9DE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                    0x7fff8548e000 -     0x7fff854b1ffb  libJPEG.dylib (1570.2) <BE6386AF-E7F7-3C26-8B9E-7682DA38F496> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                    0x7fff854b2000 -     0x7fff854d9ff7  libPng.dylib (1570.2) <2BC453BB-5E15-3031-AFAE-912025F2674A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                    0x7fff854da000 -     0x7fff854dcff3  libRadiance.dylib (1570.2) <0F2C81F9-2D74-36A6-BCC0-2366E60410C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                    0x7fff854dd000 -     0x7fff85536ff3  libTIFF.dylib (1570.2) <897EB69A-1C96-3BC2-A458-A21652249E71> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                    0x7fff85656000 -     0x7fff860f7ff7  com.apple.JavaScriptCore (12602 - 12602.2.14.0.5) <A9839022-B3BE-38E2-8956-B5ED9BE145FD> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                    0x7fff860f8000 -     0x7fff86111ff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                    0x7fff86112000 -     0x7fff86148fff  com.apple.LDAPFramework (2.4.28 - 194.5) <850BB4C5-2548-33A5-B00C-0600CA59EE59> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                    0x7fff8638c000 -     0x7fff86392fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <EE1825C7-3B58-32F8-9F5F-B7172452BB01> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                    0x7fff863a8000 -     0x7fff868f7ff7  com.apple.MediaToolbox (1.0 - 1903.11) <9855FD27-8435-3CB5-8C81-342D3BED69DE> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                    0x7fff868f8000 -     0x7fff8694fff7  com.apple.Metal (85.85 - 85.85) <EF221C0E-9638-312B-9455-FF3C69180C45> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                    0x7fff87065000 -     0x7fff8706dfff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                    0x7fff87241000 -     0x7fff87249ff7  libcldcpuengine.dylib (2.8.4) <B43FD148-4550-3EB1-9971-F5EFC0456CCE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                    0x7fff87412000 -     0x7fff87460ff3  com.apple.opencl (2.8.6 - 2.8.6) <819DE36A-893E-3100-8430-EEB9D7023672> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                    0x7fff87461000 -     0x7fff8747affb  com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                    0x7fff8747b000 -     0x7fff87486ff7  com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                    0x7fff87487000 -     0x7fff87489fff  libCVMSPluginSupport.dylib (12.4.5) <AF349AF5-ACC9-32C8-98BE-1DC9523156C5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                    0x7fff8748a000 -     0x7fff8748dff7  libCoreFSCache.dylib (150) <991F00EB-B1B4-3351-9D83-C11E4920C360> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                    0x7fff8748e000 -     0x7fff87491fff  libCoreVMClient.dylib (150) <06276E05-1FB2-3748-A236-1F66468A1755> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                    0x7fff87492000 -     0x7fff8749affb  libGFXShared.dylib (12.4.5) <67ABA30E-DA8A-336C-8137-11CD0D455741> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                    0x7fff8749b000 -     0x7fff874a6fff  libGL.dylib (12.4.5) <920D2CC5-D64F-35A5-8C54-4A5731AEC552> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                    0x7fff874a7000 -     0x7fff874e3ff7  libGLImage.dylib (12.4.5) <BEDFA6BF-0D9C-35ED-9DDD-FDBB1F6AAF95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                    0x7fff874e4000 -     0x7fff8765affb  libGLProgrammability.dylib (12.4.5) <6F6A4BA1-2DB2-3D22-9BEE-E45F6455BAE1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                    0x7fff8765b000 -     0x7fff8769bff3  libGLU.dylib (12.4.5) <79C811DC-7904-3A7D-A983-B3E8D5439336> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                    0x7fff88003000 -     0x7fff88011fff  com.apple.opengl (12.4.5 - 12.4.5) <B33F90DE-B86B-38E3-BCDB-5C8B4952D84B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                    0x7fff88012000 -     0x7fff881b8fff  GLEngine (12.4.5) <A4E7F3A2-5025-3C7D-AAF5-6187601A8C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                    0x7fff881b9000 -     0x7fff881e3ffb  GLRendererFloat (12.4.5) <9C53418B-2B6F-3B16-AA50-EF8CD632B05F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                    0x7fff8827a000 -     0x7fff883c1ff7  com.apple.QTKit (7.7.3 - 2978) <BA342B9F-7675-3A1D-B384-BB0B78F3F207> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                    0x7fff883c2000 -     0x7fff8862dfff  com.apple.imageKit (3.0 - 1016) <A3D24043-95CD-3A40-9850-83E02BDF56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                    0x7fff8862e000 -     0x7fff886e8ff7  com.apple.PDFKit (1.0 - 1) <C9AB4AB5-A2E4-344E-B898-097B86DD38D6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                    0x7fff886e9000 -     0x7fff88c0ffff  com.apple.QuartzComposer (5.1 - 351) <10A260C7-A44C-3C64-BF68-FC0FCCD08489> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                    0x7fff88c10000 -     0x7fff88c33ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <9ECD9812-151A-300D-8F37-F7FEBE67B8BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                    0x7fff88c34000 -     0x7fff88d21ff7  com.apple.QuickLookUIFramework (5.0 - 720.1) <6967F937-2BDC-397A-A377-5C52899FF97A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                    0x7fff88d22000 -     0x7fff88d22fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                    0x7fff88d23000 -     0x7fff88f1dfff  com.apple.QuartzCore (1.11 - 449.39.5) <B1815529-31B4-3FD0-923D-C3E964F844FF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x7fff88f1e000 -     0x7fff88f73fff  com.apple.QuickLookFramework (5.0 - 720.1) <FF21C563-BCEB-390B-8120-FE5FE788DBDF> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                    0x7fff88f74000 -     0x7fff88f87ff7  com.apple.SafariServices.framework (12602 - 12602.2.14.0.7) <2F16B32F-D006-31EA-9CB9-299264C17E30> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                    0x7fff89483000 -     0x7fff8979eff7  com.apple.security (7.0 - 57740.20.22) <7E95D13A-0D52-36A9-A1C4-C21EE26AB2AB> /System/Library/Frameworks/Security.framework/Versions/A/Security
                    0x7fff8979f000 -     0x7fff89815ff7  com.apple.securityfoundation (6.0 - 55132.20.1) <8DDEA805-C6F7-3EF9-990F-136617DB942D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                    0x7fff89816000 -     0x7fff8983efff  com.apple.securityinterface (10.0 - 55079.1.1) <F6B71377-6CF3-3E55-B20F-77F3C76FC9A4> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                    0x7fff8983f000 -     0x7fff89842ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <A88DACDF-71A9-3974-8D8D-DAA2B64F2CA5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                    0x7fff89bc7000 -     0x7fff89c38ff7  com.apple.SystemConfiguration (1.14 - 1.14) <013957CA-2708-31F0-845D-11E271C96B94> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                    0x7fff89c39000 -     0x7fff89fe4ff7  com.apple.VideoToolbox (1.0 - 1903.11) <E59DEC1D-6E7D-39BB-A589-9166C3C79221> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                    0x7fff89fe5000 -     0x7fff8b219ff3  com.apple.WebCore (12602 - 12602.2.14.0.5) <AA349DE2-73A3-32B2-8A1D-FEFFC468B87D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                    0x7fff8b21a000 -     0x7fff8b37ffff  com.apple.WebKitLegacy (12602 - 12602.2.14.0.7) <3D4BAC77-370A-3D55-AD1A-68D4C489DAF1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                    0x7fff8b380000 -     0x7fff8b6ebff7  com.apple.WebKit (12602 - 12602.2.14.0.7) <847FBE4F-06E5-315F-80FA-A58180B74608> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                    0x7fff8c250000 -     0x7fff8c26bff3  com.apple.AppContainer (4.0 - 307.20.1) <AE48030D-760D-3C46-A5EB-FD09B42543ED> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                    0x7fff8c26c000 -     0x7fff8c279ff3  com.apple.AppSandbox (4.0 - 307.20.1) <6BCD6C7F-470A-3C6A-9A24-3F26037AD6F7> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                    0x7fff8c27a000 -     0x7fff8c29cffb  com.apple.framework.Apple80211 (12.0 - 1200.37) <25299C0F-7A30-3BAA-9945-DB1515F68A2C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                    0x7fff8c29d000 -     0x7fff8c2acfdb  com.apple.AppleFSCompression (88 - 1.0) <D3A6F5F9-2132-34B5-933F-DF5D6733DE8B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                    0x7fff8c395000 -     0x7fff8c42097f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                    0x7fff8c434000 -     0x7fff8c44ffff  com.apple.aps.framework (4.0 - 4.0) <37A4B7F9-4F43-3A23-B4FC-E7656B5BC73F> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                    0x7fff8c450000 -     0x7fff8c458ffb  com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                    0x7fff8c459000 -     0x7fff8c45cff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                    0x7fff8c45d000 -     0x7fff8c4affff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <42A46C0E-877D-349C-A30A-5CA29896391B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                    0x7fff8c4b8000 -     0x7fff8c4bfffb  com.apple.AssetCacheServices (31 - 31) <13E874CA-86AB-33E7-A4D8-544D3B8157CD> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                    0x7fff8c83c000 -     0x7fff8c8baff7  com.apple.backup.framework (1.8.1 - 1.8.1) <792B4983-DE9A-377D-8338-93719706D12F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                    0x7fff8cf2a000 -     0x7fff8cf51fff  com.apple.CalendarAgentLink (8.0 - 250) <26CB59F5-7D23-312B-9B1E-EB47D6490A16> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLin k
                    0x7fff8d4d8000 -     0x7fff8d4ffffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                    0x7fff8d500000 -     0x7fff8d592ffb  com.apple.CloudDocs (1.0 - 483.3) <35F99B99-6F99-37F2-B347-8B8E86D83878> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                    0x7fff8de26000 -     0x7fff8de2fffb  com.apple.CommonAuth (4.0 - 2.0) <D561391D-80B8-35F8-9EFF-1ACC89895E38> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                    0x7fff8def5000 -     0x7fff8df43fff  com.apple.AddressBook.ContactsFoundation (8.0 - 2250) <5588F340-F4A8-3806-8642-08A106421B60> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                    0x7fff8df44000 -     0x7fff8df66fff  com.apple.contacts.ContactsPersistence (1.0 - 2250) <524C9EEC-D186-30B2-8A55-CC11A48CC44C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                    0x7fff8dfb0000 -     0x7fff8e38dfe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                    0x7fff8e38e000 -     0x7fff8e3befff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                    0x7fff8e433000 -     0x7fff8e43bffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                    0x7fff8e54b000 -     0x7fff8e55cff7  com.apple.CoreEmoji (1.0 - 39.1) <54432658-8481-3F33-ADED-B60684311E11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                    0x7fff8e611000 -     0x7fff8e627fff  com.apple.CoreMediaAuthoring (2.2 - 955) <0D83B2A2-E541-3FFB-ACEC-E848F9C847E7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                    0x7fff8e62e000 -     0x7fff8e6beffb  com.apple.CorePDF (4.0 - 4) <42FD0781-A19C-3E36-BFDA-DAEAFB3A3115> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                    0x7fff8e83e000 -     0x7fff8e86eff3  com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                    0x7fff8eaf7000 -     0x7fff8eb81fff  com.apple.CoreSymbolication (61050) <15C4AF49-2F85-3265-B53F-4925616C746E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                    0x7fff8eb82000 -     0x7fff8ecc0fcf  com.apple.coreui (2.1 - 426.9.1) <A7672B5D-9972-34B8-968A-188D422083AE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                    0x7fff8ecc1000 -     0x7fff8ed60ffb  com.apple.CoreUtils (4.3 - 430.70) <946F5089-9F8D-3595-8208-AD945B26D267> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                    0x7fff8edb0000 -     0x7fff8ee15ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <8DAD3903-9A77-3E50-99C4-3C5708FB25B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                    0x7fff8ee16000 -     0x7fff8ee23fff  com.apple.CrashReporterSupport (10.12 - 816) <BF292E0C-6CDB-3149-8177-4EF5DD72D544> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                    0x7fff8ee95000 -     0x7fff8eec8ff7  com.apple.datadetectors (5.0 - 348) <018E6565-860F-39E2-9C2E-D730668CE326> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                    0x7fff8eec9000 -     0x7fff8ef40ff3  com.apple.datadetectorscore (7.0 - 539) <AA02538E-706E-305B-AABA-FA9A6F4C1B8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                    0x7fff8ef7a000 -     0x7fff8efb9fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                    0x7fff8efba000 -     0x7fff8f0cbfff  com.apple.desktopservices (1.11.1 - 1.11.1) <03518A59-79B1-3B16-B923-52D6EFF04ADB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x7fff8f20a000 -     0x7fff8f214ff7  com.apple.DisplayServicesFW (3.1 - 380) <6E891145-62C3-35B9-90A5-21BC0CACDEDB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                    0x7fff8f397000 -     0x7fff8f7c8ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                    0x7fff90b03000 -     0x7fff90b03fff  libmetal_timestamp.dylib (600.0.48.26) <681B9F09-0673-3C38-B636-9D77D338D1AF> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                    0x7fff90b10000 -     0x7fff90b1bff3  libGPUSupportMercury.dylib (12.4.5) <A08E7321-32C4-3008-97C3-870B6AB1E63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                    0x7fff90dcd000 -     0x7fff90de9ff7  com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                    0x7fff90e01000 -     0x7fff91499ff7  com.apple.GeoServices (1.0 - 1228.21.7.28.8) <E45ACAE1-FBF1-3275-A6DD-6D5092FD6EFC> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                    0x7fff914df000 -     0x7fff91555ffb  com.apple.Heimdal (4.0 - 2.0) <418DD668-7288-3D33-BAFE-959DB96D0351> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                    0x7fff91556000 -     0x7fff91567fff  com.apple.HelpData (2.1.10 - 100) <BD5AC3F0-9619-3D1C-B96D-6BFCAD1C0245> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                    0x7fff91b5d000 -     0x7fff91b67fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <5415DC87-6388-3571-8A55-7720D1FE08EE> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInf o
                    0x7fff91b68000 -     0x7fff91b6fffb  com.apple.IOAccelerator (288.15 - 288.15) <DE5BC493-2F4E-3388-A887-DA5AD7BAD3F4> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                    0x7fff91b71000 -     0x7fff91b85ff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                    0x7fff91b86000 -     0x7fff91ba8ff7  com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                    0x7fff91c43000 -     0x7fff91c53ff3  com.apple.IntlPreferences (2.0 - 216) <5E2D8D16-DBB9-3389-9CEA-1E4094C34A92> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                    0x7fff91c8a000 -     0x7fff91e3efff  com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                    0x7fff91f19000 -     0x7fff91feaff3  com.apple.MMCS (1.3 - 379) <14867D2F-6E87-351E-AB4B-9BD759364DFD> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                    0x7fff92484000 -     0x7fff92487fff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                    0x7fff926ea000 -     0x7fff92762fef  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <EDE6F9AA-B863-3936-BA54-177B769080FD> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
                    0x7fff928c8000 -     0x7fff928d3ff7  com.apple.MobileKeyBag (2.0 - 1.0) <9E2D377E-C3D5-326F-B559-787AFCBA6728> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                    0x7fff928e4000 -     0x7fff9290cfff  com.apple.MultitouchSupport.framework (368.4 - 368.4) <18778258-70B1-31BF-845D-1FACBF280108> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                    0x7fff929b9000 -     0x7fff929c3fff  com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                    0x7fff92db8000 -     0x7fff92dbafff  com.apple.OAuth (25 - 25) <1A29AF10-4AFE-32A2-9CA9-A98BACA2CE8D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
                    0x7fff9319f000 -     0x7fff931e0ff7  com.apple.PerformanceAnalysis (1.145 - 145) <73A73364-EFB6-3D0A-A7EA-7F924359B3C9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                    0x7fff93224000 -     0x7fff9322bff3  com.apple.phonenumbers (1.1.1 - 105) <14003B00-D2DA-3732-A1AC-A71763EC3556> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                    0x7fff93846000 -     0x7fff93871ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <614C38AC-9D97-30D8-A196-02688634B584> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                    0x7fff93872000 -     0x7fff9388cfff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                    0x7fff9388d000 -     0x7fff9389dffb  com.apple.QuickLookThumbnailing (1.0 - 1) <DD5F14E6-A8A8-3EA8-96A3-4C84092BC18F> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                    0x7fff938a6000 -     0x7fff938c9ff3  com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                    0x7fff944fc000 -     0x7fff944fffff  com.apple.SecCodeWrapper (4.0 - 307.20.1) <2BBC8E7C-7B28-39D2-8273-2BA5ED7DAC45> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                    0x7fff9458d000 -     0x7fff94609fff  com.apple.Sharing (671.15 - 671.15) <37C29D52-CA6E-3E30-9CCF-F7B4A8DE6B9B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                    0x7fff9460a000 -     0x7fff94629ff7  com.apple.shortcut (2.16 - 98) <AC3AFB42-F3F7-3E71-8DAF-AA4ACF3021F7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                    0x7fff9462a000 -     0x7fff9487cfef  com.apple.SkyLight (1.600.0 - 108.11) <5D0C258E-0816-3FF2-AA3C-A7B9F2DEC19C> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                    0x7fff94a56000 -     0x7fff94a62fff  com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                    0x7fff95146000 -     0x7fff951b2ff3  com.apple.Symbolication (61080.2) <8AB6B520-E8DE-392F-8B86-52098D2A2BA2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                    0x7fff955a9000 -     0x7fff955afff7  com.apple.TCC (1.0 - 1) <787E8FD8-21A7-39E6-87D4-6AD09156C5A0> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                    0x7fff9563b000 -     0x7fff957fcff3  com.apple.TextureIO (1.35 - 1.35) <63D75E50-F3C2-3E8E-A49B-F53531C24C54> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                    0x7fff95845000 -     0x7fff9585aff3  com.apple.ToneKit (1.0 - 1) <ACFC15FF-6BB9-3D0F-B94E-617E9D1362DA> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                    0x7fff9585b000 -     0x7fff95869ffb  com.apple.ToneLibrary (1.0 - 1) <32AD3F5C-124F-351D-BC9B-63A7AEA20F31> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                    0x7fff95870000 -     0x7fff95871fff  com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                    0x7fff95872000 -     0x7fff95a01ffb  com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                    0x7fff96452000 -     0x7fff96501ff7  com.apple.ViewBridge (276 - 276) <55494F8D-A20F-3D64-826F-E136D77AFC9D> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                    0x7fff96929000 -     0x7fff9692ffff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                    0x7fff96a00000 -     0x7fff96a02ffb  com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                    0x7fff96a2e000 -     0x7fff96a55ff3  com.apple.contacts.vCard (1.0 - 2250) <443AB8FC-1C0F-3505-8C90-CDE600C9C73E> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                    0x7fff96a57000 -     0x7fff96a72ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
                    0x7fff96a73000 -     0x7fff96a7efff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
                    0x7fff96b10000 -     0x7fff96b11ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
                    0x7fff96b12000 -     0x7fff96d25fff  libFosl_dynamic.dylib (16.37) <D5551823-1E3D-3BDE-968C-BF022EE4958D> /usr/lib/libFosl_dynamic.dylib
                    0x7fff96d41000 -     0x7fff96d48fff  libMatch.1.dylib (27) <15FC6217-23E1-3DF0-A5F5-E4C67AED70B5> /usr/lib/libMatch.1.dylib
                    0x7fff96d49000 -     0x7fff96d49fff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
                    0x7fff96d4a000 -     0x7fff96d4dffb  libScreenReader.dylib (477.10.20) <B48924E9-5301-3141-9D62-ADA2852D5BAA> /usr/lib/libScreenReader.dylib
                    0x7fff96d4e000 -     0x7fff96d4fff3  libSystem.B.dylib (1238) <CFC3669C-FB44-3A51-8815-1E84A168F3C5> /usr/lib/libSystem.B.dylib
                    0x7fff96dbb000 -     0x7fff96de6ffb  libarchive.2.dylib (41.20.1) <FC116AC3-EB4A-3252-821C-4E1703879C82> /usr/lib/libarchive.2.dylib
                    0x7fff96de7000 -     0x7fff96e5bfff  libate.dylib (1.12.12) <DD989482-B873-3094-97BB-2B5AE8D3B544> /usr/lib/libate.dylib
                    0x7fff96e5f000 -     0x7fff96e5fff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
                    0x7fff96e60000 -     0x7fff96e70ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
                    0x7fff96e71000 -     0x7fff96e7fff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
                    0x7fff96e80000 -     0x7fff96ed6ff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
                    0x7fff96ed7000 -     0x7fff96f01fff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
                    0x7fff96f02000 -     0x7fff96f12ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
                    0x7fff96f13000 -     0x7fff96f28fc3  libcompression.dylib (34) <1691D6F2-46CD-3DA6-B44F-24CDD9BD0E4E> /usr/lib/libcompression.dylib
                    0x7fff96f29000 -     0x7fff96f29ff7  libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
                    0x7fff96f2a000 -     0x7fff96f2bffb  libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
                    0x7fff96fe5000 -     0x7fff970c9ff3  libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
                    0x7fff97267000 -     0x7fff972baff7  libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
                    0x7fff9730b000 -     0x7fff97312ff3  libdscsym.dylib (145) <A130C01E-AC0A-3733-B34C-71741DFFCC7E> /usr/lib/libdscsym.dylib
                    0x7fff97334000 -     0x7fff97334fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
                    0x7fff97344000 -     0x7fff97349ff7  libheimdal-asn1.dylib (498.20.2) <C9B5464F-4A2E-3E3F-B514-B0911B5CB0DA> /usr/lib/libheimdal-asn1.dylib
                    0x7fff9734a000 -     0x7fff9743cff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
                    0x7fff9743d000 -     0x7fff97662fff  libicucore.A.dylib (57132.0.1) <C8176937-9271-3F0E-829D-F3BBB9DD44B5> /usr/lib/libicucore.A.dylib
                    0x7fff97668000 -     0x7fff97669fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
                    0x7fff9766a000 -     0x7fff97683ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
                    0x7fff97684000 -     0x7fff9769aff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
                    0x7fff9769b000 -     0x7fff97945fff  libmecabra.dylib (744.2.2) <C6C3EA2C-1DC7-3DCB-8A20-C645E38524AB> /usr/lib/libmecabra.dylib
                    0x7fff97978000 -     0x7fff979f1ff3  libnetwork.dylib (856.20.4) <5012EFF3-8FF4-317D-B328-AB21E3B5CA8C> /usr/lib/libnetwork.dylib
                    0x7fff979f2000 -     0x7fff97dc2d97  libobjc.A.dylib (706) <F9AFE665-A3A2-3285-9495-19803A565861> /usr/lib/libobjc.A.dylib
                    0x7fff97dc5000 -     0x7fff97dc9fff  libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
                    0x7fff97dca000 -     0x7fff97dfaff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
                    0x7fff97e18000 -     0x7fff97e34ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
                    0x7fff97e35000 -     0x7fff97e6eff3  libsandbox.1.dylib (592.21.2) <7A698C92-CD5C-3BFF-A215-2BE2DE31F88E> /usr/lib/libsandbox.1.dylib
                    0x7fff97e6f000 -     0x7fff97e81ffb  libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
                    0x7fff97e82000 -     0x7fff97e83ff3  libspindump.dylib (229) <322AE558-5040-3F9A-8203-F64D8B0B507A> /usr/lib/libspindump.dylib
                    0x7fff97e84000 -     0x7fff97fccfff  libsqlite3.dylib (252) <FCA29CD2-E8E4-3324-8E2C-19BDC11F0338> /usr/lib/libsqlite3.dylib
                    0x7fff98028000 -     0x7fff98078fff  libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
                    0x7fff980be000 -     0x7fff980cbfff  libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
                    0x7fff980cf000 -     0x7fff981beffb  libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
                    0x7fff981bf000 -     0x7fff981e8fff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
                    0x7fff981e9000 -     0x7fff981faff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
                    0x7fff98209000 -     0x7fff9820dff7  libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
                    0x7fff9820e000 -     0x7fff98218fff  libcommonCrypto.dylib (60092.20.1) <31040F10-5E57-3B9C-8D5B-33AD87D1BEE8> /usr/lib/system/libcommonCrypto.dylib
                    0x7fff98219000 -     0x7fff98220fff  libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
                    0x7fff98221000 -     0x7fff98229fff  libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
                    0x7fff9822a000 -     0x7fff982acfdb  libcorecrypto.dylib (442.20.2) <2684CC01-087E-33E2-8219-AAA3BBD9BFD7> /usr/lib/system/libcorecrypto.dylib
                    0x7fff982ad000 -     0x7fff982dffff  libdispatch.dylib (703.20.1) <877B505D-826C-3246-84F7-0F850636039E> /usr/lib/system/libdispatch.dylib
                    0x7fff982e0000 -     0x7fff982e5ff3  libdyld.dylib (421.2) <7BFA3476-6210-3BCB-8CE8-9B952F87BD84> /usr/lib/system/libdyld.dylib
                    0x7fff982e6000 -     0x7fff982e6ffb  libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
                    0x7fff982e7000 -     0x7fff982f3ffb  libkxld.dylib (3789.21.3) <F12B5274-44AD-3268-A793-31EF351A4BD9> /usr/lib/system/libkxld.dylib
                    0x7fff982f4000 -     0x7fff982f4fff  liblaunch.dylib (972.20.3) <7AB2E2EA-8B47-3420-87CE-5EE18A4EEE49> /usr/lib/system/liblaunch.dylib
                    0x7fff982f5000 -     0x7fff982fafff  libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
                    0x7fff982fb000 -     0x7fff982fdff3  libquarantine.dylib (85) <F3E47D7C-8776-327C-9426-DD7DEB30DBDD> /usr/lib/system/libquarantine.dylib
                    0x7fff982fe000 -     0x7fff982ffffb  libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
                    0x7fff98300000 -     0x7fff98318ff7  libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
                    0x7fff98319000 -     0x7fff98319ff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
                    0x7fff9831a000 -     0x7fff983a7fef  libsystem_c.dylib (1158.20.4) <5F9531F5-EDA3-3D25-A827-3E0FD6B392BA> /usr/lib/system/libsystem_c.dylib
                    0x7fff983a8000 -     0x7fff983abffb  libsystem_configuration.dylib (888.20.5) <CDC55FCB-C1FC-350D-A919-5DBCFC835B63> /usr/lib/system/libsystem_configuration.dylib
                    0x7fff983ac000 -     0x7fff983affff  libsystem_coreservices.dylib (41.2) <5DE691C6-7EE6-3210-895D-9EA3ECBC09B4> /usr/lib/system/libsystem_coreservices.dylib
                    0x7fff983b0000 -     0x7fff983c8ffb  libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
                    0x7fff983c9000 -     0x7fff983cffff  libsystem_dnssd.dylib (765.20.4) <28E52C39-DF10-340F-A3EC-C0119AF6361F> /usr/lib/system/libsystem_dnssd.dylib
                    0x7fff983d0000 -     0x7fff983f9fff  libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
                    0x7fff983fa000 -     0x7fff9841cff7  libsystem_kernel.dylib (3789.21.3) <EC53F92A-0DFA-3027-A220-414A01F17B2E> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff9841d000 -     0x7fff98464fe7  libsystem_m.dylib (3121.4) <7F86C291-B105-31C1-9923-90EBAB22B73F> /usr/lib/system/libsystem_m.dylib
                    0x7fff98465000 -     0x7fff98483ff7  libsystem_malloc.dylib (116) <F9840080-4C2C-3F3B-8087-7C738F12A1C7> /usr/lib/system/libsystem_malloc.dylib
                    0x7fff98484000 -     0x7fff984dbff3  libsystem_network.dylib (856.20.4) <2BAFB24F-999C-3148-BDD8-F28E05F716F7> /usr/lib/system/libsystem_network.dylib
                    0x7fff984dc000 -     0x7fff984e5ff3  libsystem_networkextension.dylib (563.20.3) <971DD3AD-D17A-32FF-95DE-0A5A979E68AE> /usr/lib/system/libsystem_networkextension.dylib
                    0x7fff984e6000 -     0x7fff984efff3  libsystem_notify.dylib (165.20.1) <EAD023A2-AD3F-31C8-9489-274B9A42DA61> /usr/lib/system/libsystem_notify.dylib
                    0x7fff984f0000 -     0x7fff984f8fe7  libsystem_platform.dylib (126.1.2) <2F2D6A81-C36C-353D-B27B-A6643A32375E> /usr/lib/system/libsystem_platform.dylib
                    0x7fff984f9000 -     0x7fff98503ff7  libsystem_pthread.dylib (218.20.1) <46375095-4731-3034-9D87-396DE95FC697> /usr/lib/system/libsystem_pthread.dylib
                    0x7fff98504000 -     0x7fff98507ff7  libsystem_sandbox.dylib (592.21.2) <2D42A2BF-A7AF-352A-A821-D8F6E85A63AC> /usr/lib/system/libsystem_sandbox.dylib
                    0x7fff98508000 -     0x7fff98509fff  libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
                    0x7fff9850a000 -     0x7fff98511fff  libsystem_symptoms.dylib (532.1.1) <8FB7CA37-79EF-3651-B5B9-B5E1E0947067> /usr/lib/system/libsystem_symptoms.dylib
                    0x7fff98512000 -     0x7fff98532ff7  libsystem_trace.dylib (518.20.8) <C029B910-A65F-35F6-B194-B933B454EAB4> /usr/lib/system/libsystem_trace.dylib
                    0x7fff98533000 -     0x7fff98538ffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
                    0x7fff98539000 -     0x7fff98562ff7  libxpc.dylib (972.20.3) <85EB25FD-218F-38EE-9E69-391CC8EBE6C5> /usr/lib/system/libxpc.dylib
                External Modification Summary:
                  Calls made by other processes targeting this process:
                    task_for_pid: 1
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by this process:
                    task_for_pid: 0
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by all processes on this machine:
                    task_for_pid: 7727
                    thread_create: 0
                    thread_set_state: 0
                VM Region Summary:
                ReadOnly portion of Libraries: Total=485.4M resident=0K(0%) swapped_out_or_unallocated=485.4M(100%)
                Writable regions: Total=4.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.3G(100%)
                                                VIRTUAL   REGION
                REGION TYPE                        SIZE    COUNT (non-coalesced)
                Accelerate framework              1536K       11
                Activity Tracing                   256K        2
                CG backing stores                254.1M       26
                CG image                          7840K       85
                CoreAnimation                     64.4M       21
                CoreUI image data                 3868K       30
                CoreUI image file                  156K        4
                Foundation                          20K        3
                Image IO                         233.4M      379
                Kernel Alloc Once                    8K        2
                MALLOC                             3.7G     2525
                MALLOC guard page                   48K       10
                Memory Tag 242                      12K        2
                OpenGL GLSL                        256K        4
                SQLite page cache                   64K        2
                STACK GUARD                       56.1M       36
                Stack                             25.3M       39
                VM_ALLOCATE                       1476K       62
                __DATA                            39.4M      364
                __GLSLBUILTINS                    2588K        2
                __IMAGE                            528K        2
                __LINKEDIT                       124.5M       66
                __TEXT                           360.9M      345
                __UNICODE                          556K        2
                mapped file                       88.4M      260
                shared memory                     16.4M       18
                TOTAL                              5.0G     4276
                Model: iMac17,1, BootROM IM171.0105.B09, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.34f2
                Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe, 2048 MB
                Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
                Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
                Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
                Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1867 MHz, 0x859B, 0x43543130323436344246313836442E4D3136
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.21.171.47.1a8)
                Bluetooth: Version 5.0.1f7, 3 services, 17 devices, 1 incoming serial ports
                Network Service: Ethernet, Ethernet, en0
                Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
                Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
                USB Device: USB 3.0 Bus
                USB Device: LRW400
                USB Device: Keyboard Hub
                USB Device: Apple Optical USB Mouse
                USB Device: Apple Keyboard
                USB Device: Bluetooth USB Host Controller
                USB Device: FaceTime HD Camera (Built-in)
                USB Device: USB2.0 Hub
                USB Device: HP LaserJet 1200
                Thunderbolt Bus: iMac, Apple Inc., 28.1
                • 5. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                  Teri Bloom Level 1
                  Hi Mohit,
                  Sorry to keep bothering you -- very appreciative for your help.
                  Since the update 6.8 is still crashing when synching files in develop mode -- as a working pro photographer -- I'm concerned that my assignments and post-production work are going to super slowed down as I synch files constantly in develop mode.  Also I'm getting crashes sometimes on export, import etc. so there are a number of problems going on.
                  Question is this:  With Mac OS 10.12.1 -- can I go back to an older version of Photoshop where I was having no problems?  If I did that would there be any problems with my catalog?  Worst comes to worse I can re-install an older version of Mac OS and then put in an older version of Lightroom, assuming my catalog wouldn't be affected at all.  Would this be possible -- to regress both my Mac OS and LR to where I wasn't having these frequent crashes?  As mentioned, this is happening even when all other applications are closed, and I have no funky software installed at all, really all normal mainstream applications.
                  Thanks so much for your thoughts and best, Teri
                  • 6. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                    Mohit Goyal Adobe Employee (Admin)
                    Hi TeriBloom,
                    I really apologies for the inconvenience caused you, please turn off the graphics processor from the Lightroom preferences and check if that helps.
                    Click on Lightroom > Preferences > Performance tab > Uncheck the GPU > Restart.
                    Let us know if that helps.
                    Regards.
                    Mohit
                    • 7. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                      If In case, you really want to go back and reinstall the older version of Lightroom, you can install Lightroom 6.6.1 version and use the existing catalog with that.
                      Download link for Lightroom 6.0
                      http://trials3.adobe.com/AdobeProducts/LTRM/6/osx10/Lightroom_6_LS11.dmg?PID=2159997
                      Update link for 6.6.1 version
                      http://swupdl.adobe.com/updates/oobe/aam20/mac/AdobeLightroom-6.0/6.6.1/setup.dmg
                      Regards,
                      Mohit
                      • 8. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                        Teri Bloom Level 1
                        Thank you Mohit, but the Graphics Processor was not checked, so this is not the issue.
                        Any other ideas?  These crashes have only been happening since I upgraded to Mac OS 10.12.1 and since I upgraded LR a few weeks ago.
                        I did not add any new programs to my computer, the other changes have been the operating system upgrade and LR upgrade.
                        Super thanks and best, Teri
                        • 9. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                          Teri Bloom Level 1
                          Hi Mohit,
                          From another forum post, it appeared that I had to delete the pList preference in the Mac library --- this seems to have fixed the issue and crashed occurring.  I do very much appreciate your help and wanted to let you know this fix.  Thanks again and, best, Teri
                          • 10. Re: LR v. 6.7 crashing with Mac El Capitan v. 10.12.1
                            Hi TeriBloom,
                            Greetings,
                            Thank you so much for sharing the resolution for this problem, we really appreciate your time and patience's with us and it would be helpful for the other user as well.
                            Thanks again.
                            Regards,
                            Mohit
