Hi
I get this error every time the playhead reaches a specific comp that has Expressions, PSD layers, TEXT layers and Shape Layers.
Since there are many thing inside, i'm having problems identifying the issue.
I cannot enter the comp, because every time i get inside (or when the playhead reaches it from any level) After Effects crashes.
I never saw that before and did not find anyone with that issue.
EDIT:
So i finally got inside the comp where there was a shape layer with one Round Rectangle that had this script inside it's "size" property:
x = content("Rectangle 1").content("Rectangle Path 1").size[0];
y = content("Rectangle 1").content("Rectangle Path 1").size[1];
txt = thisComp.layer("TYPE TEXT HERE").text.sourceText;
Y = y
if(txt.length > 35){ Y = y+40 }
if(txt.length > 60) { Y= y+50 }
[x,Y]
Basically what the script did, was to make the box bigger in height every time the Text Layer(which is a box text) had a line break.
Erasing this Expression made the problem go away.
Any clues?
Felipe
No idea, really. The error seems totally unrelated, so your expression may be the trigger, but not the actual cause. Beyond that your expression is of course somewhat crooked and may cause issues with the internal evaluation that may also cause crashes.
Mylenium
Hi Felipe,
Did you ever solve your issue? Did Mylenium's response help?
Kevin
Seems like I am the only one in the whole world facing this problem. I couldn't get it fixed.
<123145394380800> <D_PS3p_DetectVideoPSD> <1> enter psl thread func
was the crash after I scrub through the timeline. And fails my render attempts each time.
Hope to hear back really really fast.
Please provide more information like the original poster in this thread did.
