• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Can't add items to dynamically created page
Guest
Dec 13, 2016 Dec 13, 2016
I'm writing a Javascript script that will take a JSON file describing several page layouts (comprising one or more of text frames) and automatically create an InDesign document from it.
The script mostly works, but has a strange bug where the items destined for the last page always get put onto the last-but-one page. Any thoughts on why this might be happening? Any thoughts would be greatly appreciated!
Here's the minimal code:
// load JSON file using a parser into jsonObj
// add the required number of pages
for (var i = 0; i < jsonObj.PageLayouts.length - 1; i++) {
  app.activeDocument.pages.add(LocationOptions.AFTER, app.activeDocument.pages);
// create text frames using JSON doc on each page
var docPages = app.activeDocument.pages;
for (var i = 0; i < jsonObj.PageLayouts.length; i++) {
  for (var j = 0; j < jsonObj.PageLayouts.Placeholders.length; j++) {
  origin_x = jsonObj.PageLayouts.Placeholders.Frame.Origin.X / 10;
  origin_y = jsonObj.PageLayouts.Placeholders.Frame.Origin.Y / 10;
  height   = jsonObj.PageLayouts.Placeholders.Frame.Size.Height / 10;
  width    = jsonObj.PageLayouts.Placeholders.Frame.Size.Width / 10;
  bottom_x = origin_x + width;
  bottom_y = origin_y + height;
  var tf = docPages.textFrames.add({
  geometricBounds: [origin_y, origin_x, bottom_y, bottom_x]
  $.writeln('  - Added rect (page ' : i + ' , rect ' + j + ')');
And here's the sample JSON, which should create 3 pages, with 1 textFrames on the first 2 pages, and 2 textFrames on the 3rd page. Instead, I get 3 textFrames on the second page, and none on the last page.
    "PageLayouts": [
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 0,
                            "Y": 0
                        "Size": {
                            "Height": 2100,
                            "Width": 2970
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 120
                        "Size": {
                            "Height": 1860,
                            "Width": 2730
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 1800
                        "Size": {
                            "Height": 200,
                            "Width": 2730
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 120
                        "Size": {
                            "Height": 1640,
                            "Width": 2730
TOPICS
Scripting
Views
313
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
This should be moved over to InDesign Scripting
Mike Witherell
Votes
Translate
Translate
Report
Report
People's Champ ,
try this:
var main = function() {
  var d = app.properties.activeDocument,
  data, pls, i = 0, n = 0;
  if ( !d) return;
  data = {
    "PageLayouts": [
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 0,
                            "Y": 0
                        "Size": {
                            "Height": 2100,
                            "Width": 2970
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 120
                        "Size": {
                            "Height": 1860,
                            "Width": 2730
            "Placeholders": [
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 1800
                        "Size": {
                            "Height": 200,
                            "Width": 2730
                    "Frame": {
                        "Origin": {
                            "X": 120,
                            "Y": 120
                        "Size": {
                            "Height": 1640,
                            "Width": 2730
  pls = data.PageLayouts;
  n = pls.length;
  while ( i<n )  {
  addPlaceHolders (d, pls, i );
  i++;
function addPlaceHolders(doc, pageLayouts, index ) {
  var phs = pageLayouts[index].Placeholders, ph, page, origins, sizes ;
  page = doc.pages[index];
  !page.isValid && page = doc.pages.add();
  while ( ph = phs.pop() ) {
  origins = ph.Frame.Origin;
  sizes = ph.Frame.Size;
  page.textFrames.add({
  geometricBounds: [origins.Y, origins.X, origins.Y+sizes.Height, origins.X+sizes.Width]
main();
HTH
Loic
http://www.ozalto.com/
Votes
Translate
Translate
Report
Report
Guest
Dec 14, 2016 Dec 14, 2016
Thanks Loic! Much nicer code than mine. However it gave the same problem.
We figured it out - it's because the "Facing Pages" option is enabled, which means that odd-numbered pages from 3 onwards are on the right side of a double-page spread, and so the origin coordinates need to be changed to account for this. (Both scripts work fine when Facing Pages is disabled.)
All the best,
Rehan
Votes
Translate
Translate
Report
Report
Guest
LATEST
Apologies for this, I'm new to the forums and didn't see the separate Scripting forum. I'll make sure I post there from now on.
Votes
Translate
Translate
Report
Report
