1 Reply Latest reply on Dec 14, 2016 7:19 AM by kerrishotts
    Build Error since repo switch
    ciaranm81981752
      Hi having some issues on my first Phonegap project which now won't build. Was hoping for some help or advice.   Frustratingly was working great until I had to switch all the repos over when they switched to cordova.  Now some stuff is going wrong.
      This is my log.
      BTW I actually have that preference in the config.xml but it doesn't seem to care.  Looks like some issue with ionic keyboard too?    Any input welcome
      Build Date: 2016-12-13 20:58:23 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-battery-status" via npm
      Installing "cordova-plugin-battery-status" at "1.2.1" for android
      Fetching plugin "cordova-plugin-camera" via npm
      Installing "cordova-plugin-camera" at "2.3.1" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Fetching plugin "cordova-plugin-media-capture" via npm
      Installing "cordova-plugin-media-capture" at "1.4.1" for android
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "4.3.1" for android
      Dependent plugin "cordova-plugin-compat" already installed on android.
      The Android Persistent storage location now defaults to "Internal". Please check this plugin's README to see if your application needs any changes in its config.xml.
      If this is a new application no changes are required.
      If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
        "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
      to config.xml in order for the application to find previously stored files.
      Fetching plugin "cordova-plugin-console" via npm
      Installing "cordova-plugin-console" at "1.0.5" for android
      Fetching plugin "cordova-plugin-contacts" via npm
      Installing "cordova-plugin-contacts" at "2.2.1" for android
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "1.1.4" for android
      Fetching plugin "cordova-plugin-device-motion" via npm
      Installing "cordova-plugin-device-motion" at "1.2.3" for android
      Fetching plugin "cordova-plugin-device-orientation" via npm
      Installing "cordova-plugin-device-orientation" at "1.0.5" for android
      Fetching plugin "cordova-plugin-dialogs" via npm
      Installing "cordova-plugin-dialogs" at "1.3.1" for android
      Plugin "cordova-plugin-file" already installed on android. Making it top-level.
      Fetching plugin "cordova-plugin-file-transfer" via npm
      Installing "cordova-plugin-file-transfer" at "1.6.1" for android
      Dependent plugin "cordova-plugin-file" already installed on android.
      Fetching plugin "cordova-plugin-geolocation" via npm
      Installing "cordova-plugin-geolocation" at "2.4.1" for android
      Fetching plugin "cordova-plugin-globalization" via npm
      Installing "cordova-plugin-globalization" at "1.0.5" for android
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" at "1.5.0" for android
      Fetching plugin "cordova-plugin-media" via npm
      Installing "cordova-plugin-media" at "2.4.1" for android
      Fetching plugin "cordova-plugin-network-information" via npm
      Installing "cordova-plugin-network-information" at "1.3.1" for android
      Fetching plugin "cordova-plugin-splashscreen" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.1" for android
      Fetching plugin "cordova-plugin-vibration" via npm
      Installing "cordova-plugin-vibration" at "2.1.3" for android
      "plugman install --platform android --project /project --plugin com.ionic.keyboard": Fetching plugin "com.ionic.keyboard" via npm
      Cannot convert undefined or null to object
