1 Reply Latest reply on Dec 14, 2016 6:28 AM by kglad
    Keyframe and Actionscript help?
    RazethAnimation
      Hello everyone, I need some help with Animate and Actionscript and keyframing.
      I will use examples
      Frame I start on: Anim1
      End of Anim1: EAnim1
      Frame I want to transition to: Anim2
      End of Anim2: EAnim2
      Button name: AdvanceButton
      If the user clicks a button, it is set up to go directly to Anim2 on click with this command:
      import flash.events.MouseEvent;
      AdvanceButton.addEventListener(MouseEvent.CLICK, PlayAnim2);
      function PlayAnim2(event:MouseEvent):void {
          this.gotoAndPlay("Anim2")
      So that will work fine. But I want it to only go to Anim2 AFTER Anim1 is done playing. Note: Anim1 is playing in a loop. So i want it to go to Anim2 after Anim1 finishes the current loop it is on, or when the time reaches the frame named EAnim1. Only when the AdvanceButton is clicked though. It needs to play the whole loop of Anim1 or the transition to Anim2 does not look smooth. Any help?
      Actionscript 3.0
      Animate CC 2015
      EDIT:
      I was thinking if there was a way to do this (anything that i do not know how to code are in italics below)
          var buttoncounter = 1;
      then at the frame EAmin1 the script would be
      if (buttoncounter = 1)
      this.gotoAndPlay("Anim2");
      else
      this.gotoAndPlay("Anim1");
      i may have just solved my issue hold on
