I have found the following script, that does a really good job of exporting all text from an InDesign document in a chosen format. The only problem seems to be, that text from grouped objects is not exported. Could anybody help to tweak the script to handle these items as well?
if(app.documents.length != 0){
if(app.documents.item(0).stories.length != 0){
myGetFileName(app.documents.item(0).name);
//========================= FUNCTIONS ===========================
function myGetFileName(myDocumentName){
var myFilePath = File.saveDialog("Save Exported Text As:");
if(myFilePath != null){
myDisplayDialog(myDocumentName, myFilePath);
function myDisplayDialog(myDocumentName, myFilePath){
//Need to get export format, story separator.
var myExportFormats = ["Text Only", "Tagged Text", "RTF"];
var myDialog = app.dialogs.add({name:"ExportAllStories"});
with(myDialog.dialogColumns.add()){
with(dialogRows.add()){
with(dialogColumns.add()){
var myExportFormatDropdown = dropdowns.add({stringList:myExportFormats, selectedIndex:2});
var myAddSeparatorCheckbox = checkboxControls.add({staticLabel:"Add separator line", checkedState:true});
var myResult = myDialog.show();
if(myResult == true){
var myExportFormat = myExportFormats[myExportFormatDropdown.selectedIndex];
var myAddSeparator = myAddSeparatorCheckbox.checkedState;
myDialog.destroy();
myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator);
else{
myDialog.destroy();
function myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator){
var myPage, myStory;
var myExportedStories = [];
var myTempFolder = Folder.temp;
var myTempFile = File(myTempFolder + "/tempTextFile.txt");
var myNewDocument = app.documents.add();
var myDocument = app.documents.item(myDocumentName);
var myTextFrame = myNewDocument.pages.item(0).textFrames.add({geometricBounds:myGetBounds(myNewDocument, myNewDocument.pages.item(0))});
var myNewStory = myTextFrame.parentStory;
for (var i = 0; i < myDocument.pages.length; i++) {
myPage = myDocument.pages.item(i);
for (var t = 0; t < myPage.textFrames.length; t++){
myStory = myPage.textFrames
if (!IsInArray(myStory.id, myExportedStories)) {
//Export the story as tagged text.
myStory.exportFile(ExportFormat.taggedText, myTempFile);
myExportedStories.push(myStory.id);
//Import (place) the file at the end of the temporary story.
myNewStory.insertionPoints.item(-1).place(myTempFile);
//If the imported text did not end with a return, enter a return
//to keep the stories from running together.
if(i != myDocument.stories.length -1){
if(myNewStory.characters.item(-1).contents != "\r"){
myNewStory.insertionPoints.item(-1).contents = "\r";
if(myAddSeparator == true){
myNewStory.insertionPoints.item(-1).contents = "----------------------------------------\r";
} // if not exported
} // for text frames
} // for pages
switch(myExportFormat){
case "Text Only":
myFormat = ExportFormat.textType;
myExtension = ".txt"
break;
case "RTF":
myFormat = ExportFormat.RTF;
myExtension = ".rtf"
break;
case "Tagged Text":
myFormat = ExportFormat.taggedText;
break;
myNewStory.exportFile(myFormat, File(myFilePath));
myNewDocument.close(SaveOptions.no);
myTempFile.remove();
function myGetBounds(myDocument, myPage){
var myPageWidth = myDocument.documentPreferences.pageWidth;
var myPageHeight = myDocument.documentPreferences.pageHeight
if(myPage.side == PageSideOptions.leftHand){
var myX2 = myPage.marginPreferences.left;
var myX1 = myPage.marginPreferences.right;
else{
var myX1 = myPage.marginPreferences.left;
var myX2 = myPage.marginPreferences.right;
var myY1 = myPage.marginPreferences.top;
var myX2 = myPageWidth - myX2;
var myY2 = myPageHeight - myPage.marginPreferences.bottom;
return [myY1, myX1, myY2, myX2];
function IsInArray(myString, myArray) {
for (x in myArray) {
if (myString == myArray
return true;
return false;
I would ask the author of that script.
Regards,
Uwe
I certainly would, if I knew who wrote the original script 🙂
You can look at: https://forums.adobe.com/thread/733900
or change/use this part of code:
// by groups
var theGroups = myDocument.pages
.groups;
for(var g = 0, gln = theGroups.length; g < gln; g++){
var grp = theGroups
; for(var t = 0; t < grp.textFrames.length;t++){
b = grp.textFrames
; if (b instanceof TextFrame) {
// code here...
Swo
Hi Wosven,
Thank you so much for trying to help me and excuse my ignorance, but where exactly would you place the code you suggest into the following script? I keep getting errors like “
is not defined”:
"p" stand for the "page" in my original script, here, you need to replace it by "i".
Here an example with a group and a sub-level of group (a group in a group is exported too).
Text isn't exported depending on position in the page, so this script would need more tweaking, since you need to reorder exported texts.
myDialog.destroy();
else{
myDialog.destroy();
.parentStory; if (!IsInArray(myStory.id, myExportedStories)) {
// by groups
var theGroups = myDocument.pages.groups;
var grp = theGroups
; // try second level of groups (nested group)
if (grp.groups.length > 0) {
for(var g2 = 0, gln2 = grp.groups.length; g2 < gln2; g2++){
var grp2 = grp.groups[g2];
for(var t2 = 0; t2 < grp2.textFrames.length;t2++){
b2 = grp2.textFrames[t2];
if (b2 instanceof TextFrame) {
// code here...
myStory = b2.parentStory;
if (i != myDocument.stories.length -1) {
if (myNewStory.characters.item(-1).contents != "\r") {
if (myAddSeparator == true) {
} // if TextFrame
} // for grp2
} // for
} // if grp2
b = grp.textFrames
// code here...
myStory = b.parentStory;
} // for grp
} // for pages
case "Text Only":
break;
case "RTF":
break;
case "Tagged Text":
break;
else{
) { return true;
return false;
Swo
Thank you so much, Wosven! This works perfect.
The order is not important as long as you can search the full text, which you can now. Thanks again!
