Dear friends,
Although i carefully followed the advice found at this post, I have no success. The find always wraps back to the first occurrence fo the items to be found.
Case 3 works fine for several months now - but why does case 4 not?
Jang obviously had the same problem in the mentioned post ...
function GetFindParameters (iType, sSearch) {
var propVal, findParams = new PropVals() ;switch (iType) {
case 3: // ---------------------------------- find marker of type sSearch, don't wrap
propVal = new PropVal() ;
propVal.propIdent.num = Constants.FS_FindWrap ;
propVal.propVal.valType = Constants.FT_Integer;
propVal.propVal.ival = 0 ;
findParams.push(propVal);
propVal.propIdent.num = Constants.FS_FindMarkerOfType;
propVal.propVal.valType = Constants.FT_String;
propVal.propVal.sval = sSearch;
return findParams;
break;case 4: // ---------------------------------- find character format sSearch, don't wrap
propVal.propIdent.num = Constants.FS_FindCharTag;
propVal.propVal.valType = Constants.FO_CharFmt;
return findParams;
break;default:
alert ("GetFindParameters:\nPgm error: case " + iType + " in switch not defined.", "GetFindParameters", true);
return null;
} //--- end GetFindParameters
Because of this my searches are not terminated and loop forever - FA_errno is not set (as described in the FDK doc).
findRange = goCurrentDoc.Find (oTextLoc, findParams);// finds text range (object pgf), lenght 1
if (FA_errno === Constants.FE_NotFound) {
return null; // no further items
What's wrong with my search parameters?
Hi Klaus,
in case 4 you are overriding "propVal.propVal.valType" (line 21) with line 25.
I think you forgot "propVal = new PropVal() ; " Insert after line 23
Hi Klaus,
As usual: to close to the screen the overview is lost...
Thank You, Klaus!
