1 Reply Latest reply on Dec 14, 2016 7:13 AM by kerrishotts
    Build issue when adding plugin
    svantej81806167
      I am trying to build an app including the two plugins called cordova-plugin-qrscanner and cordova-plugin-camera-preview. I started out by including the cordova-plugin-qrscanner and the app worked fine until I added cordova-plugin-camera-preview in my config.xml. The error message I received after buiilding the app can be seen below and the app-id is 2395740. Thanks in advance.
      Build Date: 2016-12-14 11:28:22 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-qrscanner" via npm
      Installing "cordova-plugin-qrscanner" at "2.4.0" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Fetching plugin "cordova-plugin-camera-preview" via npm
      Installing "com.mbppower.camerapreview" at "0.0.8" for android
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAppcompatV72310Library
      :prepareComAndroidSupportSupportV42310Library
      :prepareComJourneyappsZxingAndroidEmbedded330Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugShaders
      :mergeDebugAssets
      :mergeDebugResources
      :processDebugManifest/project/AndroidManifest.xml:19:5-60 Error:
      Element uses-feature#android.hardware.camera at AndroidManifest.xml:19:5-60 duplicated with element declared at AndroidManifest.xml:17:5-85
      /project/AndroidManifest.xml:21:5-65 Error:
      Element uses-permission#android.permission.CAMERA at AndroidManifest.xml:21:5-65 duplicated with element declared at AndroidManifest.xml:16:5-90
      /project/AndroidManifest.xml Error:
      Validation failed, exiting
      See http://g.co/androidstudio/manifest-merger for more information about the manifest merger.
      :processDebugManifest FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugManifest'.
      > Manifest merger failed with multiple errors, see logs
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.246 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      My config.xml:
      <?xml version="1.0" encoding="UTF-8" ?>
      <widget xmlns = "http://www.w3.org/ns/widgets"
        xmlns:gap = "http://phonegap.com/ns/1.0"
        id = "com.cent21.example"
        versionCode ="1"
        version = "1.0.0">
          <preference name="android-targetSdkVersion" value="14" />
        <gap:config-file platform="ios" parent="CFBundleVersion">
        <string>1.0.0</string>
        </gap:config-file>
        <name>Example</name>
        <description>
        </description>
        <author href="https://www.21st.se" email="support@21st.se">
        21st Century Mobile
        </author>
          <gap:plugin name="cordova-plugin-qrscanner" source="npm"/>
        <gap:plugin name="cordova-plugin-camera-preview" source="npm"/>
        <gap:platform name="android" />
        <gap:platform name="ios" />
      </widget>
