3 Replies Latest reply on Dec 14, 2016 7:21 PM by WobertC
    Collage disappears
    MooseDog Level 1
      I made a collage in the lightroom print module. I closed lightroom CC and returned later but all the frames were empty. Turns out you have to have the collection in which the prints for the collage are stored must be in the film strip below. Two days later after opening and closing other catalogues I went to retrieve the original collage and the frames are empty and the collection is in the film strip below. How do I get my collage back?  and then if I do, how do I save it for editing, I know about making a jpeg, I need to be able to edit the original layout with the photos in the collage collection I made.
        • 1. Re: Collage disappears
          99jon Adobe Community Professional & MVP
          Create a Saved Print. That will preserve the layout and your images in a specific collection.
          • 2. Re: Collage disappears
            MooseDog Level 1
            I have made an exported print. What is a "saved print?"  I see no new collections  in the list of collections. Sorry - do not quite understand... thanks for your replay.
            • 3. Re: Collage disappears
              WobertC Adobe Community Professional
              When you design a custom layout for a print collage, you can do two major things-
              1. Create a "Saved Print" by clicking on the tab above the window. This saves the print design AND the photos you have used as a Collection in the Collections panel. You can return to the same print at any time, or add other photos to this collection to use the same layout
              2. Save the layout as a template (for later use). This template will appear in the "Template Browser" panel and can be used with any photos you select from the Library.
              So to create prints in future you can select photos, select the template (you created) and print to printer or print to JPG as you wish.
              Creating a template like this is useful for designing your own Book Pages when you want a collage that is not available in the Book page templates.
