1 Reply Latest reply on Mar 25, 2009 6:09 PM by mferchak
    The pop-up menu I added to a button disappears
      When I add a pop-up menu to a button symbol I've created, all is well until I click on "done." Then, when I click on the + sign for that button, it says "Add Pop-up Menu..." as if I hadn't added it already. When I click on "Add Pop-up Menu..." again, nothing's there.
      I'm using Fireworks CS4 for the Mac. I've used Fireworks MX on my PC for many years, and have never had this problem. Help!!
        • 1. Re: The pop-up menu I added to a button disappears
          I found a bizarre work around for the pop-up menus that will not seem to retain any changes made in the pop-up menu editor. As soon as you finish making the changes in the editor and hit Done, go to the library (either document library or common library) and double click on the symbol to which the pop-up menu is attached. Click the Edit button. Then finish the editing by hitting the left arrow at the top left of the workspace. Now the changes to the pop-up menu have been saved.
