5 Replies Latest reply on Dec 15, 2016 2:50 PM by George in Seattle
    Sample filename error during import
    George in Seattle Level 1
      See attached screenshot, it should be self explanatory.  This started failing after the last update. I use this feature a lot because I always like to verify the proposed filename before transferring hundreds, or thousands of shots. It used to show a sample name based on the highlighted shot.  Now, no matter what I do, it is either showing blank, or what you see underlined.  For this template it should show: shootname/YY/Julian/sequence/suffix (specifically BCOA163497819.nef)
