4 Replies Latest reply on Dec 25, 2016 10:44 PM by P. Raghu
    Illustrator JPEGExportOptions Object properties are missing in Object Model
    P. Raghu Level 1
      The Adobe Illustrator JPEGExportOptions Object properties are missing or mismatched in Object Model? Please advice.
        • 1. Re: Illustrator JPEGExportOptions Object properties are missing in Object Model
          o-marat Level 3
          What features do you need? Specifically.
          There are workarounds – through Photoshop...
          • 2. Re: Illustrator JPEGExportOptions Object properties are missing in Object Model
            P. Raghu Level 1
            The object properties and actual Illustrator JPEG Export Options are not equal, that is my problem, see the attached both screenshots, and i could not fix my scripting.
            Example:
            Image Color Model = CMYK,
            Options [Compression Method, Resolutions, and etc.,]
            • 3. Re: Illustrator JPEGExportOptions Object properties are missing in Object Model
              Ten A Adobe Community Professional
              Why don't you use action with Javascript like below?
              function exportJPG(pth){ //Export 300dpi CMYK jpg
                var str = "";
                for (var i=0;i<pth.length;i++) str += u16to8(pth.charCodeAt(i));
                var act = "/version 3/name [ 4 73657431]/isOpen 1"
                + "/actionCount 1/action-1 {/name [ 4 61637431]/keyIndex 0/colorIndex 0/isOpen 1/eventCount 1"
                + "/event-1 {/useRulersIn1stQuadrant 0/internalName (adobe_exportDocument)"
                + "/isOpen 0/isOn 1/hasDialog 1/showDialog 0/parameterCount 7"
                + "/parameter-1 {/key 1885434477/showInPalette 0/type (raw)"
                + "/value < 100 0a00000001000000030000000100000000002c01020000000000000001000000"
                + "69006d006100670065006d006100700000000000000000000000000000000000"
                + "0000000000000000000000000000000000000000000000000000000000000000"
                + "00000100>/size 100}" //Probably, parameter for exporter plugin
                + "/parameter-2 {/key 1851878757/showInPalette 4294967295"
                + "/type (ustring)/value [ " + str.length/2 + " " + str + "]}"
                + "/parameter-3 {/key 1718775156/showInPalette 4294967295"
                + "/type (ustring)/value [ 16 4a5045472066696c6520666f726d6174]}" // JPEG file format
                + "/parameter-4 {/key 1702392942/showInPalette 4294967295"
                + "/type (ustring)/value [ 12 6a70672c6a70652c6a706567]}" //jpg,jpe,jpeg
                + "/parameter-5 {/key 1936548194/showInPalette 4294967295/type (boolean)/value 0}"
                + "/parameter-6 {/key 1935764588/showInPalette 4294967295/type (boolean)/value 1}"
                + "/parameter-7 {/key 1936875886/showInPalette 4294967295/type (ustring)/value [ 0]}}}";
                var tmp = File(Folder.desktop + "/set1.aia");
                tmp.open('w');
                tmp.write(act);
                tmp.close();
                app.loadAction(tmp);
                app.doScript("act1", "set1", false);
                app.unloadAction("set1","");
                tmp.remove();
              function u16to8(cd) {
                var out =
                (cd < 0x80
                ? toHex2(cd)
                : (cd < 0x800
                ? toHex2(cd >> 6 & 0x1f | 0xc0)
                : toHex2(cd >> 12 | 0xe0) +
                toHex2(cd >> 6 & 0x3f | 0x80)
                ) + toHex2(cd & 0x3f | 0x80)
                return out;
              function toHex2(num) {
                var out = '0' + num.toString(16);
                return out.slice(-2);
              var pth = Folder.selectDialog("target Folder?").fsName + "/test.jpg";
              exportJPG(pth);
              2 people found this helpful
              • 4. Re: Illustrator JPEGExportOptions Object properties are missing in Object Model
                P. Raghu Level 1
                Thank you,
                I will go with actions with JS.
