4 Replies Latest reply on Dec 17, 2016 7:43 AM by Geoff0409
    Why the script has to be run twice?
    Geoff0409
      I am writing a script to spell-check PDF. With reference to the official API document here, the script is copied as a js file to Acrobat javascript folder. I also add a line to insert a menu item to run the script:
      app.addMenuItem({cName: "&Spell Check All Pages", cParent: "Edit", nPos: 0, cExec: "testck();", cEnable: "event.rc = (event.target != null)"});
      function testck() {
        var ckWord, numWords;
        for (var i = 0; i < this.numPages; i++ ) {
          numWords = this.getPageNumWords(i);
          for (var j = 0; j < numWords; j++) {
            ckWord = spell.checkWord(this.getPageNthWord(i, j))
            if ( ckWord != null ) {
              this.addAnnot({
                page: i,
                type: "Squiggly",
                quads: this.getPageNthWordQuads(i, j),
                author: "A. C. Acrobat",
                contents: ckWord.toString()
      However, the strange thing I encountered is that when I click the item in the menu in first time, it doesn't complete. When I click the second time, it runs completely and show the result. Afterwards, it run completely by just one click. If I close the Acrobat and restarts, it requires a double execution. Would you please help indicate the problem? Thank you!!
      Geoff
        • 1. Re: Why the script has to be run twice?
          George_Johnson MVP & Adobe Community Professional
          Try this:
          app.addMenuItem({cName: "&Spell Check All Pages", cParent: "Edit", nPos: 0, cExec: "testck(this);", cEnable: "event.rc = (event.target != null)"});
          function testck(doc) {
            for (var i = 0; i < doc.numPages; i++ ) {
              numWords = doc.getPageNumWords(i);
                ckWord = spell.checkWord(doc.getPageNthWord(i, j))
                  doc.addAnnot({
                    page: i,
                    type: "Squiggly",
                    quads: doc.getPageNthWordQuads(i, j),
          2 people found this helpful
          • 2. Re: Why the script has to be run twice?
            JR_Boulay Adobe Community Professional
            Hi.
            Just tested: it works fine.
            (AcDC on Mac OS X)
            • 3. Re: Why the script has to be run twice?
              Geoff0409 Level 1
              Thank you. However it still requires double execution. I try to revise as follows:
              app.addMenuItem({cName: "&Spell Check All Pages", cParent: "Edit", nPos: 0, cExec: "testck(this)"});
                    app.alert(j+1 + "/" + numWords);
                    ckWord = spell.checkWord(doc.getPageNthWord(i, j));
                    app.alert("passsed");
                      this.addAnnot({
                        page: i,
                        type: "Squiggly",
                app.alert("done")
              When I click the menu item (open the document, and immediately run the item without other commands. If I click other item, it runs completely), it just show 1/14 without alerting "passed", then it stops without any notification of error. Then I click a second time, it shows 1/14-14/14 completely with "passed".
              Please help, thank you!!
              • 4. Re: Why the script has to be run twice?
                Geoff0409 Level 1
                I just found a thread with similar strange behaviour here.
                Therefore if I add this line,
                if (!spell.available) {
                app.alert("message");
                return;
                the menu item behaves as expected. Thanks everyone for investigation and testing!
