2 Replies Latest reply on May 19, 2006 7:04 AM by DPSwebmaster
    Please help me with AS error
    DPSwebmaster
      I am using a class called DrawingUtilities.as and the file is placed at the same root level as my .fla file, but I get an error when testing the movie. The error is:
      **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 20: The class or interface 'actionscriptbible.drawing.DrawingUtilities' could not be loaded.
      var duDrawer rawingUtilities = new DrawingUtilities(mButton);
      Total ActionScript Errors: 1 Reported Errors: 1
      why can't it find the damn class!?
      here is the entire AS code I am using if that helps...
      import actionscriptbible.drawing.DrawingUtilities;
      var mLoginButton:MovieClip;
      var mSaveButton:MovieClip;
      makeLoginScreen();
      //the drawButton() function makes a new MovieClip object with a nested
      //label TextField object.
      function drawButton(mParent:MovieClip, sLabel:String,
      nWidth:Number, nHeight:Number):MovieClip {
      //Make a movieclip object nested in the parent object. Use a unique
      // instance name and depth.
      var nDepth:Number = mParent.getNextHighestDepth();
      var mButton:MovieClip = mParent.createEmptyMovieClip("mButton" + nDepth, nDepth);
      //Draw a rectangle in the MovieClip object
      duDrawer.beginFill(0xFFFFCC, 100);
      duDrawer.drawRectangle(nWidth, nHeight, nWidth/2, nHeight/2);
      duDrawer.endFill();
      // Add a TextField object to the MovieClip. Apply the label.
      var tLabel:TextField = mButton.createTextField("tLabel",
      mButton.getNextHighestDepth(),0,0, nWidth, nHeight);
      tLabel.Selectable = false;
      tLabel.text = sLabel;
      return mButton;
      function makeLoginScreen():Void {
      //Create the TextField and MovieClip Objects.
      this.createTextField("tUsername", this.getNextHighestDepth(), 100, 100, 200, 20);
      this.createTextField("tPassword", this.getNextHighestDepth(), 100, 140, 200, 20);
      this.createTextField("tMessage", this.getNextHighestDepth(), 100, 60, 200, 20);
      mLoginButton = drawButton(this, "Login", 100, 25);
      //Set the properties of the TextField Objects.
      tUsername.border = true;
      tPassword.border = true;
      tUserName.type = "input";
      tPassword.type = "input";
      tPassword.password = true;
      tMessage.textColor = 0xFF0000;
      //Place the button
      mLoginButton._x = 100;
      mLoginButton._y = 180;
      mLoginButton.onRelease = function():Void {
      //Check to see if the user has entered the correct username
      //and password. If so, call the login() function.
      //otherwise, display
      //a message to the user and clear the values from the login
      //TextField objects.
      if(tUserName.text =="admin" && tPassword.text =="admin") {
      login();
      else {
      tMessage.text = "Try again.";
      tUsername.text = "";
      tPassword.text = "";
      function login(): Void {
      //Remove the TextField and MovieClip objects that made up the
      //login screen.
      tUsername.removeTextField();
      tPassword.removeTextField();
      mLoginButton.removeMovieClip();
      //Create the TextField and MovieClip for the notes screen.
      this.createTextField("tNotes", this.getNextHighestDepth(), 100, 100, 350, 200);
      mSaveButton = drawButton(this, "Save", 100, 25);
      //Set the properties of the TextField Object.
      tNotes.border = true;
      tNotes.type = "input";
      //Place the button
      mSaveButton._x = 100;
      mSaveButton._y = 320;
      //Open a local shared object.
      var lsoNotes:SharedObject = SharedObject.getLocal("notes");
      // Assign the stored text, if any.
      tNotes.text = (lsoNotes.data.notes == undefined) ? "" : lsoNotes.data.notes;
      //When the user clicks and releases the button store the current
      //current notes. in the shared object
      mSaveButton.onRelease = function():Void {
      lsoNotes.data.notes = tNotes.text;
      lsoNotes.flush();
        • 1. Re: Please help me with AS error
          blemmo Level 1
          The name of the class represents the directory structure, starting from the file where it is imported. So
          should be placed in a directory 'drawing' inside a directory 'actionscriptbible' inside the directory where the main file is located.
          You could also rename the class to 'DrawingUtilities' and place it in the same directory as the root file (and probably change some other lines, if it's necessary... the compiler will tell you).
          greets,
          blemmo
          • 2. Re: Please help me with AS error
            DPSwebmaster Level 1
            thanks,
            I can get my form to dispay now, but the first input isn't alowing any text input
            here is tha code
            import DrawingUtilities;
            makeLoginScreen();
            duDrawer.endFill();
            return mButton;
            //Place the button
            login();
            else {
            //login screen.
            //Place the button
            lsoNotes.flush();
