• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
XD Artboards act very funnily, looking distorted
Community Beginner ,
Dec 17, 2016 Dec 17, 2016
Version: 0.6.8.6 on Windows
Any artboard I create in XD seems to be torn to pieces. Varying in zoom level alters the way the artboards are distorted, as can be seen in the screenshots I uploaded. I cannot use XD in this way.
The bug may be due to the fact that I use a HP Compaq 6710b laptop from 2008, but Ps, Ai, Id run just fine on it.
Restarting the app did not solve the problem, neither did rebooting my pc.
This might have to do with my GPU (driver)? chrome://gpu gives me the following results:
Graphics Feature Status
  • Canvas: Hardware accelerated
  • Flash: Hardware accelerated
  • Flash Stage3D: Hardware accelerated
  • Flash Stage3D Baseline profile: Hardware accelerated
  • Compositing: Hardware accelerated
  • Multiple Raster Threads: Disabled
  • Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
  • Rasterization: Software only, hardware acceleration unavailable
  • Video Decode: Software only, hardware acceleration unavailable
  • Video Encode: Hardware accelerated
  • VPx Video Decode: Software only, hardware acceleration unavailable
  • WebGL: Hardware accelerated
Driver Bug Workarounds
  • clear_uniforms_before_first_program_use
  • disable_d3d11
  • disable_discard_framebuffer
  • disable_framebuffer_cmaa
  • exit_on_context_lost
  • force_cube_complete
  • msaa_is_slow
  • scalarize_vec_and_mat_constructor_args
  • texsubimage_faster_than_teximage
Problems Detected
Version Information
Data exported17-12-2016 21:47:46
Chrome versionChrome/55.0.2883.87
Operating systemWindows NT 10.0.14393
Software rendering list version11.17
Driver bug list version9.15
ANGLE commit id4d208abb1926
2D graphics backendSkia/55 d1740f81c843c65acd58d1b571ce94b90fee99d0
Command Line ArgsFiles (x86)\Google\Chrome\Application\chrome.exe" --no-startup-window /prefetch:5 --flag-switches-begin --flag-switches-end
Driver Information
Initialization time304
In-process GPUfalse
Sandboxedfalse
GPU0VENDOR = 0x8086, DEVICE= 0x2a02 *ACTIVE*
GPU1VENDOR = 0x8086, DEVICE= 0x2a03
Optimusfalse
AMD switchablefalse
Desktop compositingAero Glass
Diagonal Monitor Size of \\.\DISPLAY215.3"
Diagonal Monitor Size of \\.\DISPLAY118.3"
Driver vendorIntel Corporation
Driver version8.15.10.2697
Driver date10-1-2012
Pixel shader version3.0
Vertex shader version3.0
Max. MSAA samples1
Machine model name
Machine model version
GL_VENDORGoogle Inc.
GL_RENDERERANGLE (Mobile Intel(R) 965 Express Chipset Family (Microsoft Corporation - WDDM 1.1) Direct3D9Ex vs_3_0 ps_3_0)
GL_VERSIONOpenGL ES 2.0 (ANGLE 2.1.0.4d208abb1926)
GL_EXTENSIONSGL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_pack_reverse_row_order GL_ANGLE_robust_client_memory GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ANGLE_texture_usage GL_ANGLE_translated_shader_source GL_CHROMIUM_bind_generates_resource GL_CHROMIUM_bind_uniform_location GL_CHROMIUM_sync_query GL_EXT_blend_minmax GL_EXT_color_buffer_half_float GL_EXT_debug_marker GL_EXT_frag_depth GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_robustness GL_EXT_shader_texture_lod GL_EXT_texture_compression_dxt1 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_storage GL_EXT_unpack_subimage GL_KHR_debug GL_NV_fence GL_NV_pack_subimage GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_depth32 GL_OES_element_index_uint GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_vertex_array_object
Disabled Extensions
Window system binding vendorGoogle Inc. (adapter LUID: 0000000000006d55)
Window system binding version1.4 (ANGLE 2.1.0.4d208abb1926)
Window system binding extensionsEGL_EXT_create_context_robustness EGL_ANGLE_d3d_share_handle_client_buffer EGL_ANGLE_surface_d3d_texture_2d_share_handle EGL_ANGLE_query_surface_pointer EGL_ANGLE_window_fixed_size EGL_NV_post_sub_buffer EGL_KHR_create_context EGL_EXT_device_query EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_renderbuffer_image EGL_KHR_get_all_proc_addresses EGL_ANGLE_flexible_surface_compatibility EGL_ANGLE_create_context_webgl_compatibility EGL_CHROMIUM_create_context_bind_generates_resource
Direct renderingYes
Reset notification strategy0x8252
GPU process crash count0
Compositor Information
Tile Update ModeOne-copy
Partial RasterEnabled
GpuMemoryBuffers Status
ATCSoftware only
ATCIASoftware only
DXT1Software only
DXT5Software only
ETC1Software only
R_8Software only
RG_88Software only
BGR_565Software only
RGBA_4444Software only
RGBX_8888Software only
RGBA_8888Software only
BGRX_8888Software only
BGRA_8888Software only
YVU_420Software only
YUV_420_BIPLANARSoftware only
UYVY_422Software only
Diagnostics
0
b3DAccelerationEnabledtrue
b3DAccelerationExiststrue
bAGPEnabledtrue
bAGPExistenceValidtrue
bAGPExiststrue
bCanRenderWindowtrue
bDDAccelerationEnabledtrue
bDriverBetafalse
bDriverDebugfalse
bDriverSignedfalse
bDriverSignedValidfalse
bNoHardwarefalse
dwBpp32
dwDDIVersion10
dwHeight768
dwRefreshRate60
dwWHQLLevel0
dwWidth1360
iAdapter0
lDriverSize5508224
lMiniVddSize0
szAGPStatusEnglishEnabled
szAGPStatusLocalizedIngeschakeld
szChipTypeMobile Intel(R) 965 Express Chipset Family
szD3DStatusEnglishEnabled
szD3DStatusLocalizedIngeschakeld
szDACTypeInternal
szDDIVersionEnglish10
szDDIVersionLocalized10
szDDStatusEnglishEnabled
szDDStatusLocalizedIngeschakeld
szDXVAHDEnglishNot Supported
szDXVAModesModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeVC1_B
szDescriptionMobile Intel(R) 965 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
szDeviceId0x2A02
szDeviceIdentifier{D7B78E66-6942-11CF-0579-CA10ADC2C535}
szDeviceName\\.\DISPLAY1
szDisplayMemoryEnglish358 MB
szDisplayMemoryLocalized358 MB
szDisplayModeEnglish1360 x 768 (32 bit) (60Hz)
szDisplayModeLocalized1360 x 768 (32 bit) (60Hz)
szDriverAssemblyVersion8.15.10.2697
szDriverAttributesFinal Retail
szDriverDateEnglish1-10-2012 1:00:00
szDriverDateLocalized10/1/2012 01:00:00
szDriverLanguageEnglishEnglish
szDriverLanguageLocalizedEngels
szDriverModelEnglishWDDM 1.1
szDriverModelLocalizedWDDM 1.1
szDriverNameigdumd64.dll,igd10umd64.dll
szDriverNodeStrongNameoem5.inf:5f63e5343c30a465:i965GM0:8.15.10.2697:pci\ven_8086&dev_2a02
szDriverSignDateUnknown
szDriverVersion8.14.0010.2697
szKeyDeviceIDEnum\PCI\VEN_8086&DEV_2A02&SUBSYS_30C0103C&REV_0C
szKeyDeviceKey\Registry\Machine\System\CurrentControlSet\Control\Video\{6A600FC6-2A9E-46D9-8A8C-733F8EF778B3}\0000
szManufacturerIntel Corporation
szMiniVddOnbekend
szMiniVddDateEnglishUnknown
szMiniVddDateLocalizedOnbekend
szMonitorMaxResUnknown
szMonitorNameGeneric PnP Monitor
szNotesEnglishNo problems found.
szNotesLocalizedGeen problemen gevonden.
szOverlayEnglishNot Supported
szRankOfInstalledDriver00E32001
szRegHelpTextUnknown
szRevisionUnknown
szRevisionId0x000C
szSubSysId0x30C0103C
szTestResultD3D7EnglishNot run
szTestResultD3D7LocalizedNiet uitgevoerd
szTestResultD3D8EnglishNot run
szTestResultD3D8LocalizedNiet uitgevoerd
szTestResultD3D9EnglishNot run
szTestResultD3D9LocalizedNiet uitgevoerd
szTestResultDDEnglishNot run
szTestResultDDLocalizedNiet uitgevoerd
szVddOnbekend
szVendorId0x8086
1
bAGPEnabledtrue
bAGPExiststrue
bDriverBetafalse
bDriverDebugfalse
bDriverSignedfalse
bNoHardwarefalse
dwBpp32
dwDDIVersion10
dwHeight800
dwRefreshRate60
dwWHQLLevel0
dwWidth1280
iAdapter1
lDriverSize5508224
lMiniVddSize0
szDACTypeInternal
szDeviceId0x2A02
szDeviceName\\.\DISPLAY2
szDisplayModeEnglish1280 x 800 (32 bit) (60Hz)
szDisplayModeLocalized1280 x 800 (32 bit) (60Hz)
szKeyDeviceKey\Registry\Machine\System\CurrentControlSet\Control\Video\{6A600FC6-2A9E-46D9-8A8C-733F8EF778B3}\0001
szMiniVddOnbekend
szRevisionUnknown
szRevisionId0x000C
szVddOnbekend
szVendorId0x8086
Log Messages
  • GpuProcessHostUIShim: The GPU process exited normally. Everything is okay.
Views
981
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Dec 19, 2016 Dec 19, 2016
Hi, wgrt-
Thanks for sending such a detailed report! As you noted, it's likely this is due to an outdated Intel driver. Could you try updating your driver here? Download Intel® Driver Update Utility
Please let us know if this works for you!
-Elaine
Votes
Translate
Translate
Adobe Employee ,
LATEST
Hi, wgrt-
-Elaine
Votes
Translate
Translate
Report
Report
