4 Replies Latest reply on May 25, 2006 5:14 AM by WhiteWaterRafter
    help export
    shonts Level 1
      Hello i am trying to export a png file (containing hotspots) from fireworks into a html file. I keep getting an error which reads:
      Could not complete your request file not found
      What does this mean and how can I correct.
      BTW to export I am using: File>export (and including areas without slices)
      any help appreciated
        • 1. Re: help export
          Level 7
          Make sure you save the file before you export it, and that you are
          exporting it to the same hard drive your OS is on.
          Linda Rathgeber ACE ::: PVII
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Adobe Community Expert - Fireworks
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: help export
            shonts Level 1
            Thanks for your reply, though I was doing both (saving and sending to same hardrive) any other suggestions I also created another file to test and that has same problem.
            Shontelle
            • 3. Re: help export
              shonts Level 1
              Hello,
              I still can not export from fireworks. Macromedia phone support directed me to this link with a solution to the problem
              www.adobe.com/go/18872 although it sounded promising it did not work. Strange thing is when i took a FW file from my computer to a different computer I could export file with out problem.
              Any other ideas out there?
              Thank you
              • 4. Re: help export
                WhiteWaterRafter
                Are you using a swap image behavior in your hotspots? Is it possible to upload the file?
                Are you using windows or Mac? and if which version?
                I tried reproducing this issue but couldn't get the error at any time.
