2 Replies Latest reply on Dec 19, 2016 7:45 AM by Saeedfs
    Definition of document variable
    Saeedfs Level 1
      Hi All,
      how i can define variable to point to a document. is
      var mySourceDocument = app.documents[0] ;
        correct?
      it produce Result:undefined.
      Regards
      Saeed
        • 1. Re: Definition of document variable
          Hi Saeed,
          I suppose you are running this line of code with the ExtendScript Toolkit (ESTK) app and you are seeing this in the JavaScript Console after running:
          Result: undefined
          That does not mean that your variable mySourceDocument is undefined.
          The whole script—that one line—is returning that to the ESTK console.
          If you would add a second line like that:
          var mySourceDocument = app.documents[0];
          mySourceDocument
          the result in the ESTK console—if a document is open—would be:
          Result: [object Document]
          The script would not return anything to the ESTK console if you would add e.g. exit() as second line:
          exit();
          Regards,
          Uwe
          • 2. Re: Definition of document variable
            Saeedfs Level 1
            Laubender,
            Thanks a lot! that is true. while waiting for the answer i tried to define the variable without var i.e
            1. mySourceDocument = app.documents[0];
            and result in the ESTK console is
            1. Result: [object Document]
