All of a sudden my when i finish a edit using lightroom 6 when i export it or view it in the library section, the photo seems to go back to a less edited version?
This is fairly common for going from the Develop module back to the Library module. The Library module uses a preview created by LR for displaying the image. The Develop module uses the actual image. If you zoom in 1:1 you will see your edits and at that time the preview should update.
What are your exact settings for the export that doesn't seem to be the same as what you see in the develop module.
Make sure you haven't select Original in the export dialog.
