0 Replies Latest reply on Dec 18, 2016 9:47 PM by alexfloriana51504904
    error with command ionic platform add android
      bonjour j'essaie d'installer ma plateforme android pour mon projet ionic2 mais j'ai  cette error:
      FAILURE: Build failed with an exception.
      * What went wrong:
      Unable to start the daemon process.
      This problem might be caused by incorrect configuration of the daemon.
      For example, an unrecognized jvm option is used.
      Please refer to the user guide chapter on the daemon at https://docs.gradle.org/2.14.1/userguide/gradle_daemon.html
      Please read the following process output to find out more:
      Error occurred during initialization of VM
      Could not reserve enough space for 2097152KB object heap
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      Failed to install 'cordova-plugin-console':Error: cmd: Command failed with exit code 1
          at ChildProcess.whenDone (C:\Users\zebaze\ionicProjets\myProjectV22\platforms\android\cordova\node_modules\cordova -common\src\superspawn.js:169:23)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:885:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      Can someone help me please...
