16 Replies Latest reply on Aug 31, 2017 11:50 AM by fahipayp31090193
    [iOS] Build error “Use Legacy Swift Language Version”
    PhilippG. Level 1
      My iOS build is no working since the new XCode update.
      Check dependencies
      “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly.
      Different sources (e.g. xcode - “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use… provide a solution by editing the project.pbxproj file. This file is generated during the build process.
      Is there a way to provide updates / configuration settings to the build service?
      Thank you in advance.
