• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Unknown Error when publishing to Sharepoint 2010
New Here ,
Dec 19, 2016 Dec 19, 2016
We are having constant issues with RoboHelp 11 when attempting to publish a Project to SharePoint 2010. The error message just states 'Unknown Error' and references an image file for a recently imported topic. As there appear to be no settings in the import function to specify how to handle image names the only remedy we have found is to manually amend the path for every image loaded during the import routine to be ../IMAGENAME rather than the full file path for the Image. In addition we have had to rename each image to avoid over writing existing images. As you can image this is extremely frustrating and time consuming.
Any assistance would be appreciated as we are getting to the point of looking for an alternative product as it is clear that RoboHelp 11 does not work well with SharePoint.
Views
524
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Dec 31, 2016 Dec 31, 2016
Unknown errors are always a pain as it's hard to find where the problem is. Are you using the publish option to SharePoint of the native sharePoint integration for HTML5?
The Publish option basically requires you to publish to a network drive that happens to be a mapped SharePoint library. Only the HTML5 native method works by talking to SharePoint directly. At least, that's my experience,.
What is the output you're creating? If it's HTML5, try to go to the SharePoint options and expand the Advanced section at the bottom of the dialog. Make sure to enable the option to 'Generate SharePiont Native output.' and try again.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 03, 2017 Jan 03, 2017
Thanks for the reply.
We are using the Responsive HTML5 output format and have the option 'Generate Share Point Native output before Publishing' flag set.
Votes
Translate
Translate
Report
Report
LEGEND ,
Too bad. We can rule that one out.
Does the output work if you manually copy it to SharePoint? Or is it broken in that case? (Quickest is by using File Explorer.)
I'm wondering about the images you mention: after amended the path: are the images in the project? Or are you referencing external images with a relative path?
As for a sanity check: if you make a copy of the project and throw out the offending topics, are you then able to publish to SP?
Votes
Translate
Translate
Report
Report
New Here ,
Jan 05, 2017 Jan 05, 2017
Having had an online discussion with Adobe it appears that we can get around the issue if the folder created when a topic is imported is renamed from 'importedfilename_images' to 'importedfilename'. We can also get the project to publish if we remove the tick from 'republish all'. This obviously helps out but ideal we need a software fix - I have asked Adobe if this will be done but not had a reply as yey.
Votes
Translate
Translate
Report
Report
LEGEND ,
Great that you have a workaround!
For the bug, please also log your issue in the Adobe Tracker: Adobe Tracker
That way you know it gets to the dev team and you can track progress.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
I'm curious as to why you would want the Republish all enabled all the time?
The beauty of the publishing process is that it saves time. And part of that is achieved by tracking what has been published and only publishing what is actually needed during subsequent publishing sessions.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
It is just a habit we have! If not publishing all gets around the current issue we will make stick with doing that. I
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
