So I'm trying to learn how to do the write-on effect on After Effects with this video by Dan Stevers as a guide. Link is below:
Write-On Magic - After Effects Tutorial - YouTube
I'm trying to copy paste a mask from Illustrator to After Effects. In the video, Dan simply uses Command + C to copy and then Command + V to paste it into After Effects. I'm trying to do the same thing but it never pastes the mask to AE. Would anyone have an idea of how to solve this? I tried to create a clipping mask from the vector file first but this didn't help either. Please help!
Try to create a new mask in After Effects (any kind of mask, a circle is fine), then add a keyframe on the mask path value, put the timeline cursor on it and press cmd-v
Let me know if it works
Select the path in Illustrator and Ctrl/Cmnd + c to copy.
Inside After Effects select a layer, select the pen tool, click anywhere with the pen tool and set the first vertex, then Ctrl/Cmnd + v to paste. You've just about got to have the path started and selected to get this to work.
Tried this method and it worked too. Thanks so much!
thank you very much Rick. This saves me a lot of time.
Thank you! Big help.
