5 Replies Latest reply on Dec 20, 2016 9:28 AM by KrisHunt
    The value entered does not match the format of the field
    KrisHunt Level 4
      Okay, hopefully the last question of the day...
      I've simplified my problem down to the following: I have two radio buttons that, when clicked, populate a combobox with a set of options. The first set consists of the numbers 1-5, and the second is simply the string "N/A". Then down below, a numeric Cost field will check to see if the contents of the Quantity field is not "N/A", and if it's not, it will turn the quantity string into an integer and multiply it by 10. Otherwise, if it is "N/A", it will return 0.
      The problem is that, as soon as you click on either radio button, Acrobat gives the error "The value entered does not match the format of the field [ Cost ]". So it sounds like Cost is expecting an integer and receiving a string, but I'm not sure why it would be getting a string. Other than that, it works as expected.
