22 Replies Latest reply on Dec 22, 2016 4:48 PM by whsprague
    Add border/outline to text
    davidm6207557
      I'm new to Premiere Elements and can't find a way to do something I'd think would be simple: add an outline or border to a text box.  I do Text / Classic / Default, and drag the text box over; I can then adjust the letters but there isn't any button or setting for a border.
      There's an option for Shapes, which can put a square around the text. From there, there might be something possible with Color Properties and/or Stroke but if even if I could figure something out, it seems enormously complex for such a simple task.
      Am I missing something?
        • 1. Re: Add border/outline to text
          whsprague Level 4
          I'm not clear on exactly what you want to achieve.
          I don't know anything within Premier Elements that you are missing.   However, anything you create in Photoshop or other graphics program, can be used by adding it as media.   Such graphics can be stacked above the video track for creative control.
          • 2. Re: Add border/outline to text
            davidm6207557 Level 1
            I want to put an outline or border around a text box; all I can see that can be done is change the colors of the letters inside the box, which means the viewer sees only the letters, not a border around them.
            When I say "Am I missing something?", I don't mean the program could be missing something, I meant am I failing to see something obvious that could put an outline or border around a text box.
            • 3. Re: Add border/outline to text
              And, to be clear, I'm talking about an outline or border which defines the text box itself, not an outline around individual letters.
              • 4. Re: Add border/outline to text
                whsprague Level 4
                Is this what you want to do?  To do it I made a simple box in Photoshop, added it as a media piece and laid it above the title.  Maybe someone else knows how to do it inside of Premier Elements. Capture.JPG
                • 5. Re: Add border/outline to text
                  That's it.  But not having Photoshop, I was hoping it could be done inside Elements.
                  • 6. Re: Add border/outline to text
                    whsprague Level 4
                    What color do you want?  I'll send you a "basic box" via DropBox that you can resize inside of Premier Elements.  (It might take until tomorrow!)
                    • 7. Re: Add border/outline to text
                      Thanks, very kind of you, but I can make a box outside Elements and import it. The problem is that I want to use a variety of outlines and borders, and it'd be so much easier to just create them inside the program. But, unless we hear from someone else, I guess that isn't possible. Thanks again...
                      • 8. Re: Add border/outline to text
                        As I show you in my books, in order to an a border (stroke) to your text, you need to first go to the Style tab on the Title Adjustments panel and apply a text style that includes a border. Then you can go back to the Text tab and apply your own font and fill and stroke colors.
                        • 9. Re: Add border/outline to text
                          This sure looks like the answer but I can't figure out how to do it. I'm going to contact you through the Movipix site. Thanks!
                          • 10. Re: Add border/outline to text
                            whsprague Level 4
                            I'm confused, which is not rare!
                            Are we trying to do a text stroke border or draw a border box around a title?
                            • 11. Re: Add border/outline to text
                              I want to have a text box with a border/outline/frame around it, which I'm now beginning to understand is called a "stroke" by Adobe. (I'm sure we all appreciate their giving an entirely obscure, unintuitive name to something so simple.)
                              Based on Steve's instructions, I think I can see through the fog a possible way of doing it. But I'm not there yet.
                              • 12. Re: Add border/outline to text
                                Do you want the stroke/border to surround the text or the box that the text appears in?
                                In either case, you need to apply a text Style with a border to either the text itself or, believe it or not, the rectangle you've drawn behind your title in order to color and widen this stroke.
                                • 13. Re: Add border/outline to text
                                  To surround the box that the text appears in.
                                  Following your instructions as best I could, I got to Style (under "Graphics" I discovered just what I want: "Flat Ribbon White") but then it all fell apart, with options grayed-out everywhere.
                                  • 14. Re: Add border/outline to text
                                    Okay, I’ll go through it step by step and hopefully you can show me where and how I’ve screwed up.
                                    I make an edit, then to add “a border (stroke) to your text, you need to first go to the Style tab on the Title Adjustments panel…”  I assume that means the right-side panel and the “Text” tab.  I also assume it isn’t critical which of the text boxes I choose, just that the Style includes a border.
                                    I double-click the text box ("Classic/Default/Default Text"), put it in a video timeline above the clip, double-click, and get the Adjustments options on the right.  I click Style and choose a font that includes a border: “Myriad Bold 60 Medium Border White Black”.  I apply the font, fill and stroke colors – all good.
                                    But then it gets problematic: “You need to apply a text Style with a border to either the text itself or, believe it or not, the rectangle you've drawn behind your title in order to color and widen this stroke.”  I believe it, I just don’t know how to do it!
                                    I click the arrow at the bottom of the Text Adjustments window and use that to “choose” the text box: it brightens and shows 8 points around its circumference so I’m pretty sure it’s active.  But I can’t figure out how to apply anything to the box itself.
                                    I left-click and get various options, more or less mimicking what’s in the Text Adjustments window.  I imagine the most significant for my purpose is Color or Color Properties, but when I open that, everything I choose is reflected in the text itself, not the box surrounding it.  In fact, the Stroke option at the top isn’t clickable; either is “Stroke weight” or the three options at the bottom.
                                    So the question is, how do I apply a text Style with a border to the rectangle?
                                    By the way, in my desperate searches through everything in the right-hand toolbar, I found the perfect “thing”; I don’t know what to call it – a Style, a Text Adjustment?, I don’t even remember where I found it: “Flat Ribbon White”.  If I could somehow use that, I wouldn’t even need a text box.
                                    Thanks so much for your help…
                                    • 15. Re: Add border/outline to text
                                      Sorry, small thing, but when I said "I left-click and get various options" I meant right-click.
                                      • 16. Re: Add border/outline to text
                                        Maybe I'm not clear on something. What do you mean when you say "text box"?
                                        Do you literally mean a box surrounding (or behind) the text, or do you mean the block of text? Are you trying to draw an outline about the box or the individual letters in the title?
                                        You sound like you might be using something other than the standard use of the words "text box".
                                        • 17. Re: Add border/outline to text
                                          A box surrounding or behind the text; an outline around the box, not around individual letters.
                                          Your instructions got me to the point of having a box around the text – I just can't find a way of making any change to the box: changning its color or width, etc.
                                          And as I mentioned, whatever effect "Flat Ribbon White" is would work too.
                                          • 18. Re: Add border/outline to text
                                            You still around, Steve?  Can you tell me what I'm missing?
                                            • 19. Re: Add border/outline to text
                                              I don't know how else to explain it other than with this illustration, David.
                                              • 20. Re: Add border/outline to text
                                                That's it! I see now the problem was that, after drawing the box and importing the Style, I went to Text rather than Shapes (which, I now realize, doesn't make sense, since what I was trying to work with was an object rather than text.)
                                                Many thanks!
                                                • 21. Re: Add border/outline to text
                                                  FWIW my book is loaded with tips like this.
                                                  Happy  moviemaking!
                                                  • 22. Re: Add border/outline to text
                                                    whsprague Level 4
                                                    Happy moviemaking!
                                                    I've not done that before and had no idea it could be done.  And it is so intuitive too!
                                                    I have your book from 11.  I should probably buck up and get the one for 15!
                                                    Bill
