6 Replies Latest reply on Dec 19, 2008 11:29 AM by Newsgroup_User
    goToAndPlay in authoring mode
    Level 7
      Does goToAndStop() work in authoring mode? I've created a simple movie with
      this function in frame 2. It has no effect. When I test a projector it
      works. Does the same also apply to goToAndPlay() and stop()?
      Brian
        • 1. Re: goToAndPlay in authoring mode
          Did you use goToAndStop or gotoAndStop? The first won't work.
          • 2. Re: goToAndPlay in authoring mode
            Level 7
            I did the wrong capitalization in the email, but not in Flash. The problem
            is not with syntax errors. I'm just asking why gotoAndPlay doesn't work in
            the IDE.
            -- Brian
            "Ideas Live" <brian@ideaslive.com> wrote in message
            news:gigbed$iu1$1@forums.macromedia.com...
            > with this function in frame 2. It has no effect. When I test a projector
            > it works. Does the same also apply to goToAndPlay() and stop()?
            > Thanks,
            > Brian
            • 3. Re: goToAndPlay in authoring mode
              Level 7
              Ideas Live,
              > The problem is not with syntax errors. I'm just asking why
              > gotoAndPlay doesn't work in the IDE.
              Make sure you select Control > Enable Simple Frame Actions, which you
              can, of course, turn off again later.
              David Stiller
              Adobe Community Expert
              Dev blog, http://www.quip.net/blog/
              "Luck is the residue of good design."
              • 4. Re: goToAndPlay in authoring mode
                Level 7
                Ok, this works after I check "enable simple frame actions". Is there a
                description of exactly what actions this choice enables?
                Brian
                "NedWebs" <webforumsuser@macromedia.com> wrote in message
                news:gigbss$jcc$1@forums.macromedia.com...
                • 5. Re: goToAndPlay in authoring mode
                  Level 7
                  Thanks, this worked. I couldn't find this in the docs though. Is there
                  documentation on exactly what the following do?
                  - Enable Simple Frame Actions
                  - Enable Simple Buttons
                  - Enable Live Preview
                  "David Stiller" <stiller@quip-remove-.net> wrote in message
                  news:gigcb1$k1b$1@forums.macromedia.com...
                  > Ideas Live,
                  > David Stiller
                  • 6. Re: goToAndPlay in authoring mode
                    Level 7
                    Ideas Live,
                    > Is there documentation on exactly what the following do?
                    Simple navigation, like play(), stop(), gotoAndPlay(), and
                    gotoAndStop().
                    Temporarily lets button symbols (and possibly movie clip "buttons") act
                    like they do in a published SWF. This can be useful for testing, but it
                    keeps you from being able to select the symbol to move it around -- so turn
                    it off again when you want to make revisions.
                    Temporarily lets some UI components respond in ways they do in a
                    published SWF.
                    David Stiller
