0 Replies Latest reply on Dec 21, 2016 7:17 AM by ivoh19731683
    Unable to build android version after changing plugin version
      I was using the phonegap-plugin-barcodescanner v. 4.0.1 like this:
      But now I changed this to 6.0.4 (latest) like this:
      The github page says that I should add
      if I use Phonegap build so I did.
      But now the android build keeps failing with "Oh geez. Your build failed.".
      The end of the log looks like this:
      :compileDebugJavaWithJavacNote: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      :compileDebugNdk UP-TO-DATE
      com.android.dex.DexException: Multiple dex files define Landroid/support/v4/accessibilityservice/AccessibilityServiceInfoCompat$AccessibilityServ iceInfoVersionImpl;
      at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:591)
      at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:546)
      at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:528)
      at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:164)
      at com.android.dx.merge.DexMerger.merge(DexMerger.java:188)
      at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:504)
      at com.android.dx.command.dexer.Main.runMonoDex(Main.java:334)
      at com.android.dx.command.dexer.Main.run(Main.java:277)
      at com.android.dx.command.dexer.Main.main(Main.java:245)
      at com.android.dx.command.Main.main(Main.java:106)
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForDebug'.
      > com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/usr/lib/jvm/java-1.8.0-openjdk-'' finished with non-zero exit value 2
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      Total time: 50.769 secs
      I tried removing the app and creating it again but got to the same place.
      Anyone has an idea what is happening?
