6 Replies Latest reply on Dec 21, 2016 6:06 PM by Roei Tzoref
    Kink in Velocity - Two keyframes of the same value create motion over time?
      This started appearing a few months ago for me. After 10 years of using AE, I've never encountered it, even under the same conditions.
      Position Keyframe A (linear) is copied, moved (n) seconds in time to a point later in the timeline, and pasted. There should be 0 velocity, because it's the same keyframe value, right? To be clear, both keyframes are linear... so this should behave like a hold keyframe. But motion happens? And after opening up the value graph, I can see that a kink has formed between the two key frames. The only way to smooth out the kink is to increase the distance (in time) between the two keyframes.
      Is this a bug?
      Screen shot attached.
