10 Replies Latest reply on Jun 24, 2017 11:26 AM by Saeedfs
    Script to place small circle on a curve line with several nodes
    henum87248073
      I am using Indesign CS6 (Windows Version) and looking for a script to add small circles on a curve with several nodes on it starting from node 1 as shown in the below picture.
      The curve is single continuous line .... is there any that this can be possible...
        • 1. Re: Script to place small circle on a curve line with several nodes
          Marc Autret Level 4
          Hi henum,
          Try something like this:
          // YOUR SETTINGS
          const RADIUS = '1mm';
          const CIRCLE_PROPS = {
              fillColor:       'Black',
              strokeColor:     'None',
              // Etc... but don't change the line below.
              geometricBounds: ['-'+RADIUS,'-'+RADIUS,'+'+RADIUS,'+'+RADIUS],
          const parentSpread = function F(/*DOM*/o,  p)
          // Get the parent spread of this DOM object, or NULL.
              p = o && o.parent;
              if( (!p) || (p instanceof Document) ) return null;
              return ( (p instanceof Spread) || (p instanceof MasterSpread) ) ? p : F(p);
          (function(/*?DOM[]*/a,  o,t,u)
          // Place circles on the selected curve.
              // Check.
              if( !a || 1 != a.length ) { alert( "Please select one object!" ); return; }
              if( !('paths' in (a=a[0])) ){ alert( "Please select a spline item!" ); return; }
              if( !(o=parentSpread(a)) ){ alert( "No parent spread found!" ); return; }
              // Create the template circle at [0,0] (ruler space.)
              o = o.ovals.add(CIRCLE_PROPS);
              // Flat array of all pathpoints coordinates.
              // a[i] :: [x,y] | [[lx,ly],[x,y],[rx,ry]]
              a = [].concat.apply([],a.paths.everyItem().entirePath);
              // Duplicate the template at each point.
              for( ; t=a.pop() ; o.duplicate(u,'number'== typeof t[0] ? t : t[1]) );
              // Remove the template.
              o.remove();
          })(app.properties.selection);
          Marc
          2 people found this helpful
          • 2. Re: Script to place small circle on a curve line with several nodes
            henum87248073 Level 1
            Hi Marc
            This really works... thank you very much...
            I have one more point... though the script gives the desired result but is this possible to have the circles created on a new layer....
            thanx again....
            Rakesh
            • 3. Re: Script to place small circle on a curve line with several nodes
              Hi Marc
              Also, is there a way to set the size of the dots as the dots created using the scripts are about 2 mm each. The change in const RADIUS = '1mm';  seems does not working....
              Is there any solution to this?
              Thanx
              Rakesh
              • 4. Re: Script to place small circle on a curve line with several nodes
                Hi Rakesh,
                I tested Marc's script and cannot see that it is not working as intended.
                ( A radius of 1 mm will result in a circle of 2 mm diameter. So nothing unusual. )
                I also tested with a radius of "0.5mm". No problem.
                The result is a circle of 1 mm in diameter.
                For the layers:
                Just add appropriate code in the section that begins with //Check of Marc's code that would
                1. check if a certain layer exists by a name and
                2. if not, adds a new layer with the name
                Then add:
                itemLayer : "name of layer",
                right after line 5 of Marc's code.
                There are plenty of code examples here in the forum that check, if a layer of a specified name is there and add a layer to the active InDesign document, if the layer is not found.
                Regards,
                Uwe
                • 5. Re: Script to place small circle on a curve line with several nodes
                  Opps.... sorry
                  I just missed out the word radius and only focused on the output result which was 2 mm....
                  Your tip on layers also works.....
                  Thank you very much Laubender for correcting me...
                  Thanks Marc for all your support...
                  Rakesh
                  • 6. Re: Script to place small circle on a curve line with several nodes
                    Trevorׅ Adobe Community Professional
                    Nice one Marc,
                    A less verbose version of line 42 could be.
                    while (t = a.pop()) o.duplicate(u, t[2] ? t[1] : t);
                    Trevor
                    • 7. Re: Script to place small circle on a curve line with several nodes
                      Saeedfs Level 1
                      hi all ,
                      many thanks for Marc Laubender Trevor, i learned a lot from their participation in this forum.
                      it is nice and interesting discussion,
                      i would like to study this script,
                      first i look all over to see the assignment statement for the variables a,u
                      i could not find may any one help me
                      • 8. Re: Script to place small circle on a curve line with several nodes
                        Hi Saeedfs
                        I should leave this one to Marc but I shall put it this way
                        function addMostPeople(a,b){
                            var c;
                            if ((a === undefined) || (b === undefined)){
                                throw 'Please supply 2 arguments';
                            c = a + b;
                            return c;
                        function addMarc(a /*Num*/,b /*Num*/,   u, c){
                            if ((a === u) || (b === u)){
                            c = a + b;
                            return c;
                        The 2 examples aren't really how these functions would  be implemented either by Marc or others but they give over the idea.
                        u and c in "Marc's" function are placed in the argument list to declare them as variables.
                        As u is not assigned a value it is  undefined.
                        He has a post on this in his blog Indiscripts :: Why I Do Not Use Meaningful Variable Names (Anymore)
                        I think also part of his motives are a backup in case the jsxBlind fails ;-)
                        HTH
                        Trevor
                        • 9. Re: Script to place small circle on a curve line with several nodes
                          As for 'a' in Marc's original script that gets assigned at the last line of the script.
                          Take this example
                          (function iCallMySelf(a){alert(a);})('bar');
                          Note the whole function is wrapped  in brackets and then the function is called with the arguments provided in the brackets at the end.
                          This is the equivalent of
                          var foo = function iDoNotCallMySelf(a){alert(a);}
                          foo('bar');
                          • 10. Re: Script to place small circle on a curve line with several nodes
                            Saeedfs Level 1
                            Thank you Trevor for your quick responses.
                            i will study this
