1 Reply Latest reply on Dec 22, 2016 1:33 PM by cinziamarotta
    Correcting export steps
    whatsupdinosaur
      I'm working on someone else's design file in INDD CS6 (although they created on CC), it's in RBG but I need to convert it to CMYK and export. I changed the transparency blend space to CMYK. When I try to export I get this message: "The preset specifies source profiles that don't match the current color settings file. Profiles specified by the color settings file will be used." How do I change settings to appropriately export without color issues? I need to know the steps to export in correct cmyk settings. Thank you!
        • 1. Re: Correcting export steps
          cinziamarotta Adobe Community Professional
          The right color settings depend on the output. If you export in PDF format for professional printing use a PDF / X standard with color conversion (output tab). In InDesign you can choose the color settings from the EDIT menu > Color Settings. You'll find color settings (ICC) used in America, in Japan or in Europe.
