5 Replies Latest reply on Dec 30, 2016 7:54 AM by Karl Heinz Kremer
    Goading Acrobat Pro DC (Mac) into OCR in Edit mode
    tomkreutz
        Acrobat Pro DC for Mac 2015 Release (15.006.30244) frequently has trouble initiating OCR when I initiate Edit PDF.  Nothing happens, and the scanned image is not processed.  The text in the image is quite clear.
         I've discovered that, if I select the image, flip it upside down and then back again, and click Add Text and then Edit...Acrobat will suddenly start processing the image and (accurately) performing ORC on it.
         This appears to be an obvious bug.
         I can supply a test file that displays this behavior reproducibly.  I'm running El Capitan (OS X 10.11.6) on a mid-2015 Retina MacBook Pro.
        • 1. Re: Goading Acrobat Pro DC (Mac) into OCR in Edit mode
          Karl Heinz Kremer Adobe Community Professional
          Please report the bug here: Feature Request/Bug Report Form
          The Acrobat Forums are mainly used by users of Adobe's applications, so it's not the best way to make Adobe aware of bugs. I would upload the test file to the Document Cloud, and then share the link to the file in the bug report. Here are some instructions about sharing a file via DC: Share Documents via Adobe's Document Cloud - KHKonsulting LLC
          • 2. Re: Goading Acrobat Pro DC (Mac) into OCR in Edit mode
            tomkreutz Level 1
            Dear Karl,
              Thanks for your helpful suggestions.  I submitted a forum post because the Adobe web site said that this was my only support option.  Also, I expect that other users might benefit from my little workaround.
               The file link is: Shared Files - Acrobat.com
            Tom
            • 3. Re: Goading Acrobat Pro DC (Mac) into OCR in Edit mode
              Tom,
              this file contains "renderable text". You can see that when you try to start OCR via the Tools>Enhance Scans>Recognize Text function. You will end up with this error message:
              "Renderable text" means normal text, text that is not part of an image. Acrobat for whatever reason does not want to OCR a page that already contains "normal" text. You can see this "text" when you bring up the "Contents" pane on the left side:
              In your case, when you expand this text element, you will see that it's actually empty. This means that you can easily remove this text element without changing the document. You do this by highlighting the "Text" element, and then using the delete key, or by right-clicking and selecting to delete from the menu. Once you do that, the OCR function should be executed without a problem when you try to edit the document (at least it was here, several times in a row).
              • 4. Re: Goading Acrobat Pro DC (Mac) into OCR in Edit mode
                tomkreutz Level 1
                Dear Karl,
                  Thanks for your detailed and insightful analysis.  First, it's curious (or, rather, problematic) that entering Edit PDF mode does not engender the "This page contains renderable text" error, as one would expect; instead OCR just stalls out without any message.  (Yes, we shouldn't enter into the absurdity that an OCR program would choke when a page contains - horrors! - actual text!)  Second, one wonders why Acrobat has created this useless and debilitating empty text element while scanning.  Third, my silly (but effective) workaround apparently deletes this ghost text element when flipping the selected image (you can watch it disappear from the Content panel in real time).  Fourth, doing so does NOT trigger another OCR attempt as it does when actually deleting the text element (following your advice); I'm forced to click Add Text and then Edit.
                  In short, Acrobat is clearly buggy in a number of respects.  I submitted a bug report.
                  Thanks again for all your help!
                  Happy New Year,
                Tom
                • 5. Re: Goading Acrobat Pro DC (Mac) into OCR in Edit mode
                  Tom, only Adobe can explain we you cannot OCR a page when it already contains renderable text.
                  Here is how I see Acrobat's OCR functionality: It's a great way to OCR simple documents, the results are pretty good (and has been improved over the years), and it's built right into an application that does a ton of other stuff. However, when it comes to more challenging OCR jobs, I keep a copy of Abbyy's FineReader around (e.g. more than one language, languages not supported by Acrobat and of course pages that already contain renderable text )
