3 Replies Latest reply: Dec 18, 2008 9:59 PM by kglad RSS
    Calling a MC from the library with a button
    nogreydes Community Member
      I have created a movie clip in the library and a button on my stage that I want to play the Movie Clip.
      I need a simple code that will call the movie clip when the button is pressed and then when the user wants to close the movie clip I want them to be able to do that via a button inside the movie clip.
      I know this is a very simple question and any help would be much much appreciated.
      Jacq =)
        • 1. Re: Calling a MC from the library with a button
          kglad CommunityMVP
          you need to assign a linkage id to your movieclip and use the movieclip method attachMovie() to instantiate your library movieclip.
          in the help files under the movieclip class, check attachMovie().
          • 2. Re: Calling a MC from the library with a button
            ok kglad I have looked that up.
            I have now attached this code to my button
            on(press){
            attachMovie("life_mcMc");
            on(release){
            play._life_mcMc
            I know it is wrong!
            I now understand how to attach the movie clip now how do i get it to show up and play on screen/stage?
            I then want to be able to close/unload movie clip via a button within the movie which I assume i would then code to be something like
            on (release) {
            _root.gotoAndPlay("brochures");
            but will that then unload/remove the movie clip from the screen/stage?
            (the movie clip I am playing is basically a simulation of a pop up screen transparent over the rest of my site)
            thanks for your help
            • 3. Re: Calling a MC from the library with a button
              kglad CommunityMVP
              that's not correct syntax for attachMovie(). at least 3 parameters are required:
              parentMC.attachMovie(linkageID,mcName,depth);
