if i want to use the liquify filter in photoshop the new windows opens and the only thing i can do is zooming and scrolling. There's only the "adobe grab hand" mouse symbol and whatever tool i select on the left side nothing happens. There is still the "hand" symbol
I have tried all tipps und tricks found on google. Switch on/off openGL and graphic card support (options>performance>hardware blabla).
Any ideas?
Are you sure the liquify Hand tool is not selected and the keyboard space bar is not stuck?
Thx JJMack for you answer.
Yes, i am sure that the space button is ok and the correct tool is selected.
I have tested other filters today like 'Adaptive Wide Angle…' and there is the same problem. Only the 'Hand' tool is selected and it is not possible to select another tool.
Bt before the last update of photoshop cc there was no problem. And i didn't change anything on my hardware/software.
Seems to be a real bug inside photoshop update.
And hey adobe i have a real project now where this feature is really needed. If there is no solution the next days we will get a real problem together.
Hello,
Just wondering if you ever found a solution for this problem. I am having the same issue.
I have the same issue. Followed the instructions in the link below to no avail. Also uninstalled and reinstalled my Wacom tablet. Updated The tablet driver. And uninstalled and reinstalled Photoshop. The problem occurs frequently and working in fashion I use liquify daily. Really would appreciate any other thoughts/solutions.
Assuming you are on OSX, let's see if a driver rollback to 6.3.15 or thereabouts helps.
Thanks so much for the quick reply. A driver rollback did not work unfortunately. Within minutes the hand tool was back and stuck while in liquify.
I'm out of ideas then. Maybe someone else here can offer other answers or if you are a CC subscriber, Adobe Support will be open tomorrow. Open a chat session with them and see if they can help.
I'm having the same problem with the liquify filter not even coming up... I press Ctrl + shift + x and literally nothing happens. Also, there is no liquify filter under the filter menu in the new 2017 update of Photoshop CC. Help!
Just go to the bottom of the properties column and disable "Show Backdrop" checkbox!
Hi, I'm having several problems too with both PS and CR.
I've followed tutorials and also tried to remove and reinstall programs and drivers several times but still the "hand tool" issue appears after few time!
I use OS X and PS to work so I'm rather disappointed by all those issues.
Moreover I find unacceptable that "Pro" app from Adobe giving problems with such important tools hasn't being fixed after several weeks.
I agree. I'm having an issue where liquefy simply freezes once I zoom into 50%+ and get 2/3 up the image. It's frozen four times now and I can't even back out of liquefy to try a different solution.
3 hours for a single image edit is unacceptable.
What freezes? What exactly are you doing and what hardware and software are you using? What are you doing in liguify?
Supply pertinent information for quicker answers
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 399
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 12
Logical processor count: 24
Processor speed: 1995 MHz
Built-in memory: 40886 MB
Free memory: 2 MB
Memory available to Photoshop: 36954 MB
Memory used by Photoshop: 70 %
History Thumbnails: Disabled.
Touch Bar: Disabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1028K
Image cache levels: 6
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-1360, bottom=768, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: False.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA Quadro 4000"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7735"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
glgpu[0].GLRendererID=1757
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um"
glgpu[0].GLDriverDate="20170501000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.1 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="Quadro 4000"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="377.35"
clgpu[0].CLBandwidth=7.47872e+10
clgpu[0].CLCompute=191.721
License Type: Subscription
Serial number: 90970090970448917498
GUIDBucket:
bucket: 235
test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
E:\, 3.64T, 3.11T free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2017/04/05-14:24:38 79.266006 79.266006
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.1
Plugin.dll Adobe Photoshop CC 2017 18.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.1
PSViews.dll Adobe Photoshop CC 2017 18.1.1
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
Camera Raw 9.10.1 - from the file “Camera Raw.8bi”
Camera Raw Filter 9.10.1 - from the file “Camera Raw.8bi”
Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
Chrome 18.1.1 - from the file “Filter Gallery.8bf”
Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Cutout 18.1.1 - from the file “Filter Gallery.8bf”
Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
Dicom 18.1.1 - from the file “Dicom.8bi”
Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Fresco 18.1.1 - from the file “Filter Gallery.8bf”
Glass 18.1.1 - from the file “Filter Gallery.8bf”
Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
Liquify 18.1.1 - from the file “Liquify.8bf”
Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 14.0 - from the file “PSDX.8bi”
Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
Plaster 18.1.1 - from the file “Filter Gallery.8bf”
Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
Save for Web 18.1.1 - from the file “Save for Web.8be”
ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
Spaces 18.1.1 - from the file “Spaces.8li”
Spatter 18.1.1 - from the file “Filter Gallery.8bf”
Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
Sponge 18.1.1 - from the file “Filter Gallery.8bf”
Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
Stamp 18.1.1 - from the file “Filter Gallery.8bf”
Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
CUR (Windows Cursor) NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
Face Control II 2.00 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FaceControl(X64).8bf”
Fine Touch 3.25 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FineTouch(X64).8bf”
FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
GREYCstoration NO VERSION - from the file “C:\Photoshop64 Plug-Ins\GreycShop_x64_LAA_2013-08-04\Greyc-x64.8bf”
HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
ICO Windows Icon/Favicon NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
Import from FastPictureViewer Codec Pack 3.8.0.96 - from the file “C:\Photoshop64 Plug-Ins\FastPictureViewerCodecPack\FastPictureViewerCodecPack.PhotoshopImport64.8ba”
JPEG XR 1, 1, 0, 0 - from the file “C:\Photoshop64 Plug-Ins\Microsoft\JPEGXR_x64.8bi”
Lazy Nezumi Pro 17.3.25.1950 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\MouseHookPro64.8li”
Luce NO VERSION - from the file “C:\Photoshop64 Plug-Ins\Luce2_64\luce_64.8bf”
Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
Nik Collection Selective Tool 2.1.28 - from the file “C:\Photoshop64 Plug-Ins\Google\Selective Tool\SelectivePalette.8li”
Reduce Noise v8 8.2.0.0 - from the file “C:\Photoshop64 Plug-Ins\NeatImage8\NeatImage8.8bf”
ScriptListener 13.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\ScriptListener.8li”
SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) - from the file “C:\Photoshop64 Plug-Ins\SGIRGB\SGIRGB.8BI”
ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
StarFilter Pro 3 3.0.5.1 - from the file “C:\Photoshop64 Plug-Ins\ProDigitalSoftware\StarFilterPro3X64.8bf”
StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
SuperPNG 2.0 - from the file “C:\Photoshop64 Plug-Ins\SuperPNG\SuperPNG.8bi”
Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
Recent Files 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Libraries 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
Start 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
com.adobe.preview.loader 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
New Document 1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html”
Device Preview 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
JSX Launcher 0.1.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html”
Installed TWAIN devices: NONEx
