• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Audio Levels higher on DVD
Participant ,
Dec 26, 2016 Dec 26, 2016
I always have the same issue when building my dvds with Encore. On the computer project it sounds perfect but once it's burned into a DVD, it sounds way too loud on my TV. It appears that Encore raises the audio level a lot when exporting. Anyone else have the same issue?
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
This is not a common complaint. Check the audio meters in Premiere Pro before exporting.
Votes
Translate
Translate
Report
Report
Participant ,
Dec 27, 2016 Dec 27, 2016
In premiere I normally have the audio max at -3DB or -6DB. But in my tv, the dvd sounds a ot lauder than any other movie on dvd and the audio even distorts when it gets too loud.
Votes
Translate
Translate
Report
Report
LEGEND ,
Like Stan says, not a common complaint. Assuming you had exported from Premiere as MPEG-2 DVD, you will already have a .wav audio file. Take that into Adobe Audition, or even a Premiere timeline, and lower the volume. Export a new 48K stereo .wav file.
In Encore, replace the .wav with the new version with lower volume. Should take no more than a couple of minutes to do this.
EDIT: In Premiere, I never let the loudest sounds get past -6dB, the -3dB is pushing things. The average level might be more like -9 or -12
Jeff Pulera
Safe Harbor Computers
Votes
Translate
Translate
Report
Report
Community Expert ,
If you are using Dolby AC3 files it may be the dianorm metadata that is altering the playback levels.
Votes
Translate
Translate
Report
Report
Guide ,
Jan 09, 2017 Jan 09, 2017
Louder is really rare - it is normally the other way around if anything.
What are your audio files at source? It cannot be dialnorm settings as these are defaulted to -31 which is equivalent to "no attenuation" - Dialnorm will only turn your audio down & never up.
Do you have a normalization set up on the TV?
What happens if you check the disc ion a different setup - is it still too loud?
Votes
Translate
Translate
Report
Report
Community Expert ,
Yes -31 is no attenuation, but if you are comparing it with features, often -27 or broadcast usually -23ish it will sound louder
Votes
Translate
Translate
Report
Report
Guide ,
Jan 11, 2017 Jan 11, 2017
KInda depends on the mix of the feature really.
Dialnorm should always be left at -31 unless you know exactly what you are doing - this is not aimed at you Richard - and in a stereo mix this applies doubly so as there is no dialogue channel to use as a baseline. -27 is 4dB of attenuation but against what in stereo?
If a stereo mix is too loud it should be fixed in post production, not Dolby Digital encoding.
Votes
Translate
Translate
Report
Report
Community Expert ,
I say bring back line-up tone, you know where you are with a bit of 1KHz  (or 400 Hz warble if you are using Dolby)
Votes
Translate
Translate
Report
Report
New Here ,
Apr 28, 2017 Apr 28, 2017
Same problem here and I'm not even using Encore. Exported what should be decent levels out of Premier using the MPEG-2 DVD setting. Burned DVD via Toast Titanium and levels are loud and almost clipping. A real bummer as the video export turned out really nice considering I sourced from an HD project and needed to burn SD DVDs. Hadn't thought of editing the resulting wav file. Might try that.
Votes
Translate
Translate
Report
Report
Community Expert ,
Is this 5.1 sound or stereo?
Votes
Translate
Translate
Report
Report
Participant ,
May 25, 2017 May 25, 2017
LATEST
in my case, stereo
Votes
Translate
Translate
Report
Report
