2 Replies Latest reply on Jan 27, 2017 6:52 AM by easypay_mdb
    Using RH_ShowHelp() in combination with responsive HTML5 (output)
    easypay_mdb Level 1
      Hello,
      I'me using RH_2015 (trial version).
      Our intensions with RH is to call a help-page from selected places in a html-page.
      I've made a project with the use off 2 different output's:
      - 'WebHelp'
      - 'Responsive HTML5' (primary choice for our projects)
      I use the 'RH_Showhelp' function to call a help-file by the hand of map-id numbers.
      I can open the help-file with 'WebHelp' (output) perfectly.
      If I try the same with the 'Responsive HTML5' (output), I get script errors. (using F12 within Internet Explorer)
        * SCRIPT438: Object doesn't support property or method 'trim'
          File: rh.min.js, Line: 6, Column: 9763
        i=s[0].trim(), gives the error. => the value of s[0] = ""
        I noticed that 'rh.min.js' is not used with 'Webhelp' (output).
        * SCRIPT5007: Object expected
          File: common.min.js, Line: 6, Column: 910
        t=e("KEY_MERGED_PROJECT_MAP") => e = undefined
          File: layout.min.js, Line: 6, Column: 625
        n.publish(e("KEY_SHOW_TAGS") => e = undefined
        * SCRIPT438: Object doesn't support property or method 'consts'
          File: projectdata.js, Line: 6, Column: 1
        rh.consts('DEFAULT_TOPIC', encodeURI("#Algemeen.htm".substring(1)));
        => rh.consts = undefined
          File: loadprojdata.js, Line: 5, Column: 2
          File: usersettings.js, Line: 25, Column: 2
        * SCRIPT5007: Unable to get property 'publish' of undefined or null reference
          File: whtagdata.js, Line: 8, Column: 1
          File: rh.min.js, Line: 6, Column: 7614
      Do I need to change something within the function, according the used output?
      I call the function as following:
      RH_ShowHelp(0, root + $.trim(jsonData.file) + "/index.htm>" + $.trim(jsonData.scherm), HH_HELP_CONTEXT, $.trim(jsonData.mapNr));
      The used json-file:
        "swLrh":"0",
        "file":"Steekkaart_RespHTML5        ",
        "mapNr":"1        ",
        "scherm":"                    ",
        "veldId":"        ",
        "key":"001-006-001-001-001-000"
      root   => the place where the output of the projects are.
