5 Replies Latest reply on Dec 29, 2016 9:31 AM by RameezKhan
    My System is crashing when I open a After Effects CC2017 Project
    bobokirk Level 1
      I have been happily working in After Effects CC2017 since purchasing the Site a month ago.  Last night everything was working superbly.  This morning my system is crashing when I load up a AE Project.  Was there an update to the software last night, or are there other potential issues I might look into?
      Thanks ...
      John
        • 1. Re: My System is crashing when I open a After Effects CC2017 Project
          RameezKhan Adobe Employee
          Hi bobokirk,
          What are your computer specs? Which OS?
          Is your computer crashing while opening all AE projects or a specific project?
          When exactly does the computer crash? Do you get any error message before the crash?
          It would be helpful if you can post a video of the issue.
          Rameez
          • 2. Re: My System is crashing when I open a After Effects CC2017 Project
            bobokirk Level 1
            Time of this report: 12/18/2016, 11:43:05
                   Machine name: BOB-PC
               Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.161007-0600)
                       Language: English (Regional Setting: English)
            System Manufacturer: ASUS
                   System Model: All Series
                           BIOS: BIOS Date: 12/10/14 16:59:21 Ver: 05.06.05
                      Processor: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz (12 CPUs), ~3.3GHz
                         Memory: 32768MB RAM
            Available OS Memory: 32670MB RAM
                      Page File: 5159MB used, 60178MB available
                    Windows Dir: C:\Windows
                DirectX Version: DirectX 11
            DX Setup Parameters: Not found
               User DPI Setting: Using System DPI
            System DPI Setting: 96 DPI (100 percent)
            Display Devices
                      Card name: NVIDIA GeForce GTX TITAN Black
                   Manufacturer: NVIDIA
                      Chip type: GeForce GTX TITAN Black
                       DAC type: Integrated RAMDAC
                     Device Key: Enum\PCI\VEN_10DE&DEV_100C&SUBSYS_37913842&REV_A1
                 Display Memory: 4095 MB
               Dedicated Memory: 3072 MB
                  Shared Memory: 1023 MB
                   Current Mode: 1920 x 1080 (32 bit) (60Hz)
            It appears to be happening when I am editing in a specific project, in which I am doing scene camera pans while viewing and moving 3D objects in my scene. There is no warning and no message at shutdown.  The system just goes black .... out!
            I was editing in the same project most of yesterday, and late into last night, and did not experience any issues at all.
            I have tested media-heavy projects in Premiere, and some AE projects with heavy Particle production, and all seems to work fine.
            • 3. Re: My System is crashing when I open a After Effects CC2017 Project
              If this happens only in a single project, try importing that project into a new one and see if it helps.
              Rameez
              • 4. Re: My System is crashing when I open a After Effects CC2017 Project
                bobokirk Level 1
                I had a friend run some system hardware diagnostics, and found that my 750W power supply was woefully inadequate for the 3D objects and particles I'm putting in my scenes now. You might want to recommend that users of CC 2017 products will need not only a lot of system and video memory, but also a good supply of power to those video cards and other components.
                With my new 1000W Powe supply, I experiencing very smooth action again.
                • 5. Re: My System is crashing when I open a After Effects CC2017 Project
                  That's interesting!
                  Thanks for the valuable information. I'll add this to my troubleshooting notes.
                  Best,
                  Rameez
