4 Replies Latest reply on Dec 28, 2016 6:57 AM by ClayUUID
    hello guys.. i got stuck
    jjy10047048
      well hello guys
      i have some problem
      i want to include code
           if(loop=null){loop= false;}
      before  this.initialize(mode,startPosition,loop,{});
      but when i was using Animate CC to publish
      the code like below the code
      how to include the code ;;
      plz somebody help me;;
      (lib.quizSet = function(mode,startPosition,loop) {
         // timeline functions:
         this.frame_0 = function() {
             try{
                var i = QzSet();
                i.Init();
             }catch(err){
                  console.log(err)
        • 1. Re: hello guys.. i got stuck
          if(loop=null) will assign the variable loop to null.  you probably want, if(loop==null) which tests if loop is null.
          but it makes no sense to then assign it to false.  what's the point of that?
          if(loop) resolves the same way whether loop is false or null.  the if-branch doesn't execute.  if you had an else branch, it would execute when loop is false or loop is null.
          • 2. Re: hello guys.. i got stuck
            jjy10047048 Level 1
            well..
            i was thinking about moveclip run up
                   try{
                      var i = QzSet();
                      i.Init();
                   }catch(err){
                        console.log(err)
            • 3. Re: hello guys.. i got stuck
              jjy10047048 Level 1
              well..
              below source is just only run up 1st root
              when i play again the below
              it is moveclip
                     try{
                        console.log('start');
                        var i = QzSet();
                        i.Init();
                     }catch(err){
                          console.log(err)
              좋아요 (0)
              • 4. Re: hello guys.. i got stuck
                ClayUUID Adobe Community Professional
                It looks like you're wanting to modify the code generated when you publish. 99% of the time this means you're Doing it Wrong. Work with the framework, not against it.
                What, exactly, are you actually trying to accomplish here?
