0 Replies Latest reply on Dec 27, 2016 7:24 PM by systema94941566
    installation is corrupted # AWS Account ID : 828595926303- Production Issue
    systema94941566
      Hi Team,
      We are using ColdFusion Enterprise in windows server with IIS. We have setuped 3 instances in ColdFusion added to one cluster and all the websites in IIS will load from that Cluster there are almost 180 to 230 websites.
      Issue:
      All of the sudden our CF instances getting restarted when we check event logs we are seeing Below error. Again it start working normal after instance restarted its happening almost couple of times a day we having same problem with three of our servers can you help us with it .
      The description for Event ID 80 from source ColdFusion 11 Application Server CF1 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
      If the event originated on another computer, the display information had to be saved with the event.
      The following information was included with the event:
      the message resource is present but the message is not found in the string/message table
