Hi Everyone,
I have a web app pulls details from another app using a datasource field. My entire set up works well, except my web app input form doesn't see to update itself with any web app items added after it was created.
For example this, from the web app input form...
<select name="CAT_Custom_12" id="CAT_Custom_12" class="cat_dropdown">
<option value=" ">-- Please select --</option>
<option value="13458838">Jennifer Jolin</option>
<option value="13458874">JoAnn Kelley</option>
<option value="13458920">Kim Kruth</option>
<option value="13458938">Michella Stanley</option>
<option value="13458846">Reva Ingles</option>
<option value="13458949">Robert Thompson</option>
</select>
Will not have any new names showing that were added after the form was created. What is the correct way to allow this form to automatically include items added AND items deleted at any time?
Many thanks, in advance.
Hi Teejay,
You will need to render the options with a webapps module list of items or liquid collection. Using liquid, you'll have something like:
{module_webapps render="collection" id="webappId|webappName" filter="all" sortType="ALPHABETICAL" collection="collectionName" template=""}
{% for item in collectionName.
...Copy link to clipboard
Hi Teejay,
{% for item in collectionName.items -%}
<option value="{{item.itemid}}"> {{item.name}} </option>
{% endfor -%}
</select>
This will render all the available items.
Please refer to module_webapps | Business Catalyst Developers for more insight.
You might also want to use something like Typeahead so you don't end up with a mile tall dropdown typeahead.js – examples
I hope this helps.
Hi Webmosphere!
Since I am unable to make this work. I have a few questions:
When it says id="webappId|webappName" do I put in the ID and WebAppName together like this:
id="41315|Individuals"
What does the "collectionName" refer to?
Many thanks!
Teejay
Here is the full code that I am using
{module_webapps render="collection" id="41315|Individuals" filter="all" sortType="ALPHABETICAL" collection="collectionName" template=""}
{% endfor -%}
</select>
And I am using liquid.
Hi Webmosphere!
I figured everything out except for the part where only the webApps they submitted will show. Right now all in the database show.
Thanks, Teejay
To show only items submitted by a customer, you need to use {module_webappcustomer} instead of {module_webapps}
{module_webappcustomer} is documented here: module_webappscustomer | Business Catalyst Developers
Applied this, but it is not pulling the customer's submitted apps. (See below) I have the app's Role Responsibility assigned to the USER. Am I missing something? I could see anything different in the documentation. You are my hero. Thanks for your assistance. I will keep plugging away as I await your response. - Thanks, Teejay
{module_webappcustomer render="collection" id="Individuals" filter="all" sortType="ALPHABETICAL" collection="Individuals" template=""}
{% for item in Individuals.items -%}
{% endfor -%}
</select>
Role responsible is associated with site admins. What you want is Submitted By...as indicated in the image below.
Yes, I have the set-up where members log into a secure zone, and with their identity they create web app items. I have it set for USERS to be role responsible.
Thanks Teejay
Never mind! I copied your mention of {module_webappcustomer} when I saw in the documentation that it was {module_webappscustomer}. Put the "s" in there and we have champagne!
Take care over there and thanks!
Teejay
Oops! My mistake.
Glad you figured it out.
