• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
When I publish it holds onto a title that I used in the past and this same title comes back every time I publish
New Here ,
Dec 28, 2016 Dec 28, 2016
When I try to publish a program it always has the same title in the title line. I override it so the right project name is saved and then it just comes back.  How do I get rid of this and make is so the program publishes the name of the file being worked on?
TOPICS
Advanced
Views
626
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 28, 2016 Dec 28, 2016
If you're referring to the Title that you enter in the Publish dialog not being saved for next publish, this has been a known issue at times with Captivate versions.
The workaround fix is to us Save As and save your CPTX project to a different folder somewhere on your PC, then edit the Title and republish (I usually also select a different folder as the publish location).  Then use Save As again to save the CPTX back in to the original folder overwriting the original CPTX.  Then republish again s
Votes
Translate
Translate
Community Expert ,
Where do you put that 'title'? In the Project Info?
Votes
Translate
Translate
Report
Report
Community Expert ,
The workaround fix is to us Save As and save your CPTX project to a different folder somewhere on your PC, then edit the Title and republish (I usually also select a different folder as the publish location).  Then use Save As again to save the CPTX back in to the original folder overwriting the original CPTX.  Then republish again selecting the publish folder of your choice.
Don't ask me WHY this works.  I found it out by accident several years ago.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 09, 2018 Apr 09, 2018
Hi Rod.
I'm unable to get your fix to work. I'm using Captivate 9 and the error persists. I've tried saving to multiple folders and then publishing to the original, then going back, re-saving and nothing changes. One user mentioned that when using a template as source file, immediately save and publish with the desired name.
This is stupidly frustrating.
Patrick
Votes
Translate
Translate
Report
Report
Community Expert ,
Are you using a CPTX or CPTL file?
Did you make sure to follow the instructions to change not just the name of the file, folder location, but also publish name?
Votes
Translate
Translate
Report
Report
New Here ,
May 05, 2020 May 05, 2020
LATEST
Since you're on the topic of file names, I would like published .MP4s to have no title displayed when the play. How can I hide the file name on playback of an MP4 video file?
Votes
Translate
Translate
Report
Report
Resources
Help resources
