1 Reply Latest reply on Dec 28, 2016 9:44 PM by weik27118210
    AutoComplete get selectedItem() return null
    weik27118210
      I use autoComplete component:
      public function set selectedItem(value:Object):void {
        if (_selectedItem != value) {
            _selectedItem = value;
            _selectedItemChanged = true;
            invalidateProperties();
      public function set selectedItems(value:ArrayCollection):void {
            _initialSelectedItems = value;
           _selectedItemsChanged = true;
      [Bindable(event="change")]
         public function get selectedItem():* {
              if (_selectedItems && _selectedItems.length > 0) {
                  return _selectedItems.getItemAt(_selectedItems.length - 1);
               } else {
                  return null;
      in commitproperties function, selectedItems add item:
      override protected function commitProperties():void {
          super.commitProperties();
          var item:Object;
          if (_selectedItemChanged && _dataProvider) {
               _selectedItemChanged = false;
                if (_selectedItem) {
                    _selectedItems.addItem(_selectedItem);
          if (_selectedItemsChanged && _dataProvider) {
               _selectedItemsChanged = false;
              _selectedItems.removeAll();
              for each (var selectedItem:Object in _initialSelectedItems) {
                  var foundItem:Object = null;
                  for each (item in _dataProvider.list) {
                      if (item == selectedItem) {
                         foundItem = item;
                     } else if (item.hasOwnProperty(_keyField) && item[_keyField] == selectedItem[_keyField]) {
                         foundItem = item;
                     if (foundItem) {
                          _selectedItems.addItem(foundItem);
                          foundItem = true;
                          break;
             if (foundItem == null) {
                  _selectedItems.addItem(selectedItem);
      One Command(com.adobe.cairngorm.commands.Command) to setselectedItem:
          var ac = new AutoComplete();
          var targetItem = ...
           if (targetItem) {
                 ac.selectedItems = new ArrayCollection([targetItem]);
                 ac.selectedItem = targetItem;
      and then get ac's value:
      if (this.ac.selectedItem) {
        return this.ac.selectedItem["value"];
      } else {
         return "";
      here, this.ac.selecteditem is null, in commitproperties function, the _selectedItems add element, and in next frame, the commitproperties function be invoked
      if i get ac's value later 5 seconds after set selectedItems, the ac's vlaue is not null
      is it because i create many compontents in for loop, and the commitproperties cannot be invoked immediately, or how to make the commitproperties immediately, for example, use evt.dispatch()?
      how to make sure when i use ac.selecteditem, can return not null value?
