6 Replies Latest reply on Dec 30, 2016 7:05 AM by kglad
    How to pass variables from .fla file to .as file in as3
    maziarser
      I have a .fla file names test.fla and I have this variable in it:
          var my_var;
          stage.addEventListener(MouseEvent.CLICK, onLoaded);
          function onLoaded(e:Event):void
         my_var = "myVariable";
         //trace(my_var);
      I have a .as file called Main.as.
      I want to pass **my_var** from test.fla to the Main.as.
      I will really appreciate, if you can help me in this matter!
      It is noticeable that I have used the method mentioned in "http://stackoverflow.com/questions/9603049/actionscript-3-pass-a-variable-from-the-main-fl a-to-external-as-file", but it does not work for me!!!
      I wrote in my Main.as:
          package
           public class Main extends Sprite
            public function Main()
          trace(root.my_var);
      Thanks in advance!
        • 2. Re: How to pass variables from .fla file to .as file in as3
          make Main your document class and have it extend the MovieClip class.
          • 3. Re: How to pass variables from .fla file to .as file in as3
            maziarser Level 1
            kglad Main is already document class and I extend to MovieClip class.
            the code is like this:
            test.fls:
                import Main;
                var my_var;
                   my_var = "Maziar";
                   //trace(my_var);
            Main.as
            package
                  import flash.display.Sprite;
                  import flash.geom.Point;
                  import flash.events.MouseEvent;
                  import flash.utils.Timer;
                  import flash.events.TimerEvent;
                  import flash.events.Event;
                  import flash.display.MovieClip;
                  public class Main extends MovieCLip
                    if (stage)
                      init();
                    else
                    addEventListener(Event.ADDED_TO_STAGE, init);
                  addEventListener(Event.ENTER_FRAME, waitForMyVar);
                 private function waitForMyVar(e:Event):void
                   if (my_var != null)
                     trace(my_var);
                     removeEventListener(Event.ENTER_FRAME, waitForMyVar);
               private function init(e:Event = null):void
                removeEventListener(Event.ADDED_TO_STAGE, init);
            I still get the errors "error: 1120: Access of undefined property my_var".
            the error is in line: if (my_var != null) and line : trace(my_var);
            • 4. Re: How to pass variables from .fla file to .as file in as3
              that couldn't have been your document class or you would have seen an error.
              anyway, use:
              test.fls:
              import Main;
              var my_var;
              my_var = "Maziar";
              dispatchEvent(new Event('varReadyE'));
              Main.as
              package
              if (stage)
                        init();
                      else
              this.addEventListener('varReadyE',waitForMyVar);
              trace(my_var);
              • 5. Re: How to pass variables from .fla file to .as file in as3
                maziarser Level 1
                Thanks again!
                But I have still this error:
                1120: Access of undefined property my_var.
                In line:
                trace(my_var);
                In Main.as
                I have changed trace(my_var) to trace ("Hello") and it does not work also.
                • 6. Re: How to pass variables from .fla file to .as file in as3
                  attach a screenshot of your properties panel that shows Main is your document class:
