0 Replies Latest reply on May 17, 2006 7:13 AM by heilong
    curveTo thickness is buggy?
    heilong
      I'm developing an application to draw/graph lines and parabolas. I draw parabolas using the curveTo method, I set the thickness to a constant value using lineStyle. The problem is - the curve thickness is uneven along the curve's length, and curves with different parameters can have a big difference in their thickness.
      Screenshot: http://heilong.oceanography.ru/flash/misc/curveto_bug.jpg
      SWF file and code archive at: http://heilong.oceanography.ru/flash/misc/
      To draw parabolas in the SWF, press the mouse button anywhere inside the coordinate space and drag. Release to add the parabola. Add several of them. You can also pick up and drag existing parabolas (note that thickness changes even when dragging.
