I am building a website for E-Learning, I am using adobe connect and I would like to sync my created event into adobe connect. I reviewed the API document but not found any API for the same. I know this is possible as I have seen paid plugins in Moodle and wordpress.
I am looking someone who can help me on this. I have sync the user, folder etc. but Event I am unable to sync in adobe connect.
Expecting your quick response.
You are looking to place Adobe Connect Events in your website? Are you using the Events module of Connect or are we just looking at placing links to meetings and ondemand assets in your website?
LMS integration is very different from API calls, so it would also help to know if you are looking for LMS integration (Moodle) or just placing the Connect objects with your website (WordPress).
Can you clarify exactly what it is you are trying to do?
I want to create the event on our portal and want to sync it in adobe
connect and then fetch it without going on adobe connect. everything should
be functional in our portal not in adobe connect. I want to post
/get/update the data from adobe connect
without redirecting to adobe connect..
I hope this make sense?
Yes, your work flow makes sense, but what are you considering an event?
I did not get any updates yet.
Can anyone will help?
thanks,
On Sun, Jan 1, 2017 at 10:32 PM, flyingj481 <forums_noreply@adobe.com>
Are you using the Events module of Connect or are we just looking at placing links to meetings and/or ondemand assets in your website?
What are you considering an event?
It still isn't clear what you are trying to achieve.
I want to create the course/event from our portal and want to sync the same
into adobe connect?
Is that possible?
I hope you got my concern now?
If you are trying to create Event using API, please refer below blog.
Event Registration using Adobe Connect API's - Adobe Connect User Community
You can create Event in your LMS and have to use above set of API's to sent it over to Connect.
Hope this helps.
Annkiit
Please let me know if it is possible or not?
Hi
I am eager to see the reply if someone could do quickly.
1/ Can I create event in my portal and then sync the same into Adobe connect?
2/ Can I fetch the created event over AdobeConnect?
Very simple question, expecting quick response.
Still waiting for response.
Can you please below blog:
If this do not help please contact us through chat or call.
A
