• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Jsx file hide layer style in layer palette
Engaged ,
Dec 31, 2016 Dec 31, 2016
I have a Jsx file that executes fine except that the layer style info shows through out the process.   I've been able to hide the history from showing.   I would prefer that the user not know what is going on inside the script.   Script was initially developed from an action then atn2jsx was applied.   Looks like I needed to clicked the fx arrow to hide when I built the action.
RONC
TOPICS
Actions and scripting
Views
539
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Jan 02, 2017 Jan 02, 2017
The following is from an atn2jsx run on the atn I generated in PSCC 2017 for a Pattern style applied to a layer .   See ********** on line to change.
  function step09(enabled, withDialog) {
    if (enabled != undefined && !enabled)
      return;
    var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
    var desc1 = new ActionDescriptor();
    var ref1 = new ActionReference();
    ref1.putProperty(PSClass.Property, PSClass.LayerEffects);
    ref1.putEnumerated(PSClass.Layer, PSType.Ordina
Votes
Translate
Translate
Adobe
Engaged ,
LATEST
      return;
    ref1.putEnumerated(PSClass.Layer, PSType.Ordinal, PSEnum.Target);
    desc1.putReference(PSKey.Target, ref1);
    var desc2 = new ActionDescriptor();
    desc2.putUnitDouble(PSKey.Scale, PSUnit.Percent, 416.666666666667);
    var desc3 = new ActionDescriptor();
    desc3.putBoolean(PSKey.Enabled, true);
    desc3.putBoolean(PSString.present, true);
    desc3.putBoolean(PSString.showInDialog, false);            **********   changed from true
    desc3.putEnumerated(PSKey.Mode, PSType.BlendMode, PSEnum.Multiply);
    desc3.putUnitDouble(PSKey.Opacity, PSUnit.Percent, 100);
    var desc4 = new ActionDescriptor();
    desc4.putString(PSKey.Name, "frame 4");
    desc4.putString(PSKey.ID, "8233a751-cd92-11e6-be38-c71308788234");
    desc3.putObject(PSEnum.Pattern, PSEnum.Pattern, desc4);
    desc3.putUnitDouble(PSKey.Scale, PSUnit.Percent, 100);
    desc3.putBoolean(PSKey.Alignment, true);
    var desc5 = new ActionDescriptor();
    desc5.putDouble(PSKey.Horizontal, 0);
    desc5.putDouble(PSKey.Vertical, 0);
    desc3.putObject(PSString.phase, PSClass.Point, desc5);
    desc2.putObject(PSString.patternFill, PSString.patternFill, desc3);
    desc1.putObject(PSKey.To, PSClass.LayerEffects, desc2);
    executeAction(PSEvent.Set, desc1, dialogMode);
PSClass.Layer = cTID('Lyr ');
  PSClass.LayerEffects = cTID('Lefx');
  PSClass.Point = cTID('Pnt ');
  PSClass.Property = cTID('Prpr');
  PSClass.Version = cTID('Vrsn');
  PSEnum.Multiply = cTID('Mltp');
  PSEnum.Pattern = cTID('Ptrn');
  PSEnum.Target = cTID('Trgt');
  PSEvent.Duplicate = cTID('Dplc');
  // PSEvent.Rasterize = cTID('Rstr');
  PSEvent.Rasterize = sTID('rasterizeLayer');
  // var idrasterizeLayer = stringIDToTypeID( "rasterizeLayer" );
  PSEvent.Select = cTID('slct');
  PSEvent.Set = cTID('setd');
  PSKey.Alignment = cTID('Algn');
  PSKey.Enabled = cTID('enab');
  PSKey.Horizontal = cTID('Hrzn');
  PSKey.ID = cTID('Idnt');
  PSKey.LayerID = cTID('LyrI');
  PSKey.MakeVisible = cTID('MkVs');
  PSKey.Mode = cTID('Md  ');
  PSKey.Name = cTID('Nm  ');
  PSKey.Opacity = cTID('Opct');
  PSKey.Scale = cTID('Scl ');
  PSKey.Target = cTID('null');
  PSKey.To = cTID('T   ');
  PSKey.Vertical = cTID('Vrtc');
  PSKey.What = cTID('What');
  PSString.layerStyle = sTID('layerStyle');
  PSString.patternFill = sTID('patternFill');
  PSString.phase = sTID('phase');
  PSString.present = sTID('present');
  PSString.rasterizeItem = sTID('rasterizeItem');
  PSString.showInDialog = sTID('showInDialog');
  PSType.BlendMode = cTID('BlnM');
  PSType.Ordinal = cTID('Ordn');
  PSUnit.Percent = cTID('#Prc');
Votes
Translate
Translate
Report
Report
