4 Replies Latest reply on May 19, 2006 12:38 PM by Xtort
    Hitting Enter Key with online form
    Xtort Level 1
      When my users hit the enter key instead of clicking on submit, it just reloads the form and doubles any url variables that I'm passing. The page reloads itself
      <cfif isDefined('form.submit')>
      Perform actions
      <cfelse>
      Display form
      </cfif>
      The url would be http://192.168.1.1/test.cfm?cfid=3455 When the use hits enter it becomes http://192.168.1.1/test.cfm?cfid=3455cfid=3455. and just keeps adding everytime the user hits enter instead of clicking submit. Is there a way to make the enter key select the submit button by default?
      Thanks!
        • 1. Re: Hitting Enter Key with online form
          drforbin1970 Level 1
          You need to catch the Enter key press and kill it or convert it. You can kill the Enter keypress or convert it with the following:
          <head>
          <script>
          function kill_enter(kc){
          if(kc==13){
          //return event.keyCode=9; //moves cursor to next input
          return false; //kills the keypress
          </script>
          </head>
          <form name="myform2">
          <input type="text" name="y" onKeyDown="return kill_enter(event.keyCode);">
          <input type="text" name="z" onKeyDown="return kill_enter(event.keyCode);">
          <input type="submit">
          </form>
          Put the onKeyDown line on each input box but not the submit button.
          • 2. Re: Hitting Enter Key with online form
            Dan Bracuk Level 5
            Strictly a guess because you are not showing your form code, but, are you using method = "get" in your form? That might be messing it up. With a normal html form, the enter key will almost always submit the form.
            • 3. Re: Hitting Enter Key with online form
              Level 7
              Do you have an action assigned to the form tag? The only time I have run
              into this situation the client didn't have an action assigned in the form
              tag.
              Bryan Ashcraft (remove brain to reply)
              Web Application Developer
              Wright Medical Technologies, Inc.
              Macromedia Certified Dreamweaver Developer
              Adobe Community Expert (DW) :: http://www.adobe.com/communities/experts/
              "Xtort" <webforumsuser@macromedia.com> wrote in message
              news:e4ihm0$g93$1@forums.macromedia.com...
              > reloads
              > itself
              > Perform actions
              > <cfelse>
              > Display form
              > </cfif>
              > The url would be <a target=_blank class=ftalternatingbarlinklarge
              > href=" http://192.168.1.1/test.cfm?cfid=3455">http://192.168.1.1/test.cfm?cfid=34
              > 55</a> When the use hits enter it becomes <a target=_blank
              > href=" http://192.168.1.1/test.cfm?cfid=3455cfid=3455.">http://192.168.1.1/test.c
              > fm?cfid=3455cfid=3455.</a> and just keeps adding everytime the user hits
              > enter
              > the
              > Thanks!
              • 4. Re: Hitting Enter Key with online form
                Xtort Level 1
                Thanks the scritp you supplied worked like a charm!!
                Sincerely,
                Pauly
