I have very particular bosses. I am doing a two page spread with the photo that runs across both pages. This is for a standard 8.5 X 11 publication with a bleed (11 X 17.25 spread). Some of my publications that I submit to want it in two separate pages and not as a spread. How can I ensure the photo lines up perfectly in the middle on these split page publications when taking in consideration both the trim and bleed in the center? I generally design in PSD but would be open to learning a bit about InDesign as I have the whole Adobe Cloud Suite. Ultimately, I'm sure it will be easier in InDesign...I'm just set in my ways and hard headed. Thank you all in advance for the help.
There's no need to cut or really do anything. Just export the facing pages with or without an inside bleed. Here's PDF/X-4 with an inside bleed—ID on left Acrobat on right:
in indesign you could create 2 facing pages 8.5 x 11 and set up bleed
then place your photo across both pages in the same spread (to the edges of the bleed guides).
In this way you could have two separate pages or make two page spread
It will be.
In Photoshop to provide pages with bleeds from a full spread, you would have to manually split the spread, save out two page files, and do it again for any future edits. PS is not a page layout application.
Thank you for the input. I'm also aware that PSD is not a layout program, but it's just the one that I have been using all these years, doing it "manually" every month. I really do need to come over to indesign. Thank you very much for your input and time helping me!
Can you make screenshots? Thanks!
… Ok!
So you have spreads with images on left-right pages and you want to "cut" the image in 2!
Right?
