7 Replies Latest reply on Jan 2, 2017 9:20 AM by Tooslow2007
    DNG tags/title not showing in Windows (10) File Explorer
    Tooslow2007 Level 1
      I'm sure this is an old question but having poked around for a while I can't find an answer so...
      If I export my metadata into my DNG files (not into a XMP sidecar file) then Windows File Explorer does not show tags, titles, star rating etc. I have installed a codec so File Explorer will show the image. I'm afraid I can't remember if I used the Adobe Codec or the MS one. I have no problem with JPEGs and PSE picks up the metadata, if I export it, so it is there, it's just that FE can't process it..
      Is there any way to get File Explorer to show this data, e.g. a different Codec or do I have to use a different file manager? I have seen Fastpictureviewer, Faststone and others recommended. If I have to go down this route do you have any favourites, bearing in mind that it's just File Explorer type capabilities I'm looking for?
      John
        • 1. Re: DNG tags/title not showing in Windows (10) File Explorer
          dj_paige Level 10
          I cannot duplicate this in Windows 10, the tags and other metadata are visible when I select the photo in Windows Explorer.
          • 2. Re: DNG tags/title not showing in Windows (10) File Explorer
            Tooslow2007 Level 1
            For DNG? Interesting. Do you have a Codecs installed?
            John
            • 3. Re: DNG tags/title not showing in Windows (10) File Explorer
              dj_paige Level 10
              The DNG I exported had tags and titles and GPS locations visible in the Windows 10 File Explorer. I don't believe I have ever installed any codecs.
              • 4. Re: DNG tags/title not showing in Windows (10) File Explorer
                Tooslow2007 Level 1
                That's interesting. I've sent a DNG to my laptop (which has never seen a DNG before) and the metadata shows in Windows File Explorer.
                That's reassuring, it confirms that the metadata is there, though I was pretty sure of that anyway.
                I know this sounds daft but I have the Adobe codecs installed on one pc and the MS codecs on the other (so I can see RAW files away from home). Trouble is, I can't remember which is which. So it might be that. I'll have a poke around.
                Thanks for the help dj.
                John
                • 5. Re: DNG tags/title not showing in Windows (10) File Explorer
                  johnrellis Most Valuable Participant
                  I've never found a way to list authoritatively image codecs that have been installed. Media Player will list audio and video codecs, but not image codecs.  You can go to Programs And Features, and hopefully there will be an uninstaller for the codec or codec pack listed, but you can't count on that.
                  It's certainly possible you have a codec installed for DNG that is screwing up File Explorer's access to DNG metadata.  (Codecs are responsible for providing File Explorer with access to metadata.)
                  • 6. Re: DNG tags/title not showing in Windows (10) File Explorer
                    Tooslow2007 Level 1
                    Just talking to myself here, some progress but mostly deeper into confusion. I have the Adobe codecs pack installed on my main pc, the one I'm having trouble with. The description specifically states that one of the things it does is allow File Explorer to display metadata. On my laptop I have the NEF codecs installed (not MS codecs as memory told me), so I can see NEF files. Nikon make no mention of DNG.
                    As an aside I can find conflicting reports on the MS codecs pack. One report says it is incorporated into Win 10 (seems credible) others say you have to install it and run it in compatibility mode (no thanks).
                    In an attempt to set both pcs the same I have removed the Adobe Codecs pack from my main pc. This has had no effect whatsoever. Next I removed the NEF codecs from my laptop. This had no effect on viewing DNGs or metadata in DNGs but now I can't see NEF images, so I've re-installed the NEF codecs pack.
                    Fortunately this issue is a curiosity rather than a problem. I think I'll leave it until tomorrow, see if any ideas pop into my head. Maybe re-installing the Adobe codecs pack on the main pc is the next step. Win 10 has had one or two major upgrades since it came out, one of them might have upset it. But then why is the laptop ok?  Hmm.
                    John
                    • 7. Re: DNG tags/title not showing in Windows (10) File Explorer
                      Tooslow2007 Level 1
                      Fixed!!!!!
                      I hope you will all excuse me talking to myself here but the input I've had from john & dj has really helped, in pointing out that it should work and the joy (?) of codecs.
                      The answer? I re-installed the Adobe DNG Codecs, Somewhere along the way it must have got upset. Computers eh?
                      John
