6 Replies Latest reply on Mar 10, 2017 1:28 AM by grefel
    How do I load an ICML File?
    Jens Troeger Level 1
      Hello,
      Chapter 12 of the Javascript Scripting Guide talks about loading XML files into elements of an InDesign document, and about styling them using tags-to-style mappings. Given an InCopy ICML file, however, how do I place its content in a document? Using that same XML facility, or is there another and better way of loading and placing ICML files into InDesign documents?
      Thank you,
      Jens
        • 1. Re: How do I load an ICML File?
          grefel Level 2
          You simply place the ICML-File into a Textframe:
          app.activeDocument.textFrames[0].place(icmlFile);
          // optional unlink
          dok.links.itemByName(icmlFile.name).unlink();
          • 2. Re: How do I load an ICML File?
            Hi Jens,
            you could check what placeable file extensions can be used:
            // Writes the result to the JavaScript Console of the ExtendScript Toolkit (ESTK)
            app.placeableFileExtensions.sort().join("\r");
            // Result for e.g. InDesign CS6 v8.1.0 on Mac OSX:
            AI
            AIF
            AIFF
            AU
            AVI
            BMP
            CT
            DCS
            EMF
            EPS
            F4V
            FLV
            GIF
            JPE
            JPEG
            JPG
            M15
            M1A
            M1S
            M1V
            M64
            M75
            MOV
            MP2
            MP4
            MPA
            MPEG
            MPG
            MPM
            MPV
            PCC
            PCT
            PCX
            PDD
            PIC
            PMG
            PNG
            PSD
            RLE
            SCT
            SWF
            TIF
            TIFF
            TP1
            TRP
            TXT
            WAV
            WAVE
            WMF
            doc
            doc
            docx
            icml
            idms
            incd
            incx
            indd
            inds
            indt
            joboptions
            mp3
            oam
            pdf
            pdp
            rtf
            txt
            utxt
            xls
            xlsx
            However, I did not test, if all of these will work for the Mac version.
            And InDesign will be agnostic on cases:
            E.g. myDocument.jpg and myDocument.JPG will work alike.
            Regards,
            Uwe
            • 3. Re: How do I load an ICML File?
              grefel Thank you for mentioning the TextFrame.place() method, that’s what I was looking for. It takes a File argument though, and Javascript’s File class doesn’t seem to implement a wrapper for a string or stream (which is how the ICML arrives in my case). I might be able to use a temporary file in local storage though, I shall poke around...
              I also noticed that line breaks and spaces in the ICML file are replicated exactly, including page breaks that I haven’t quite figured out where they come from.
              Thank you!
              • 4. Re: How do I load an ICML File?
                grefel Level 2
                There is no wrapper for String or Stream. I would write a temporary file to disk.
                • 5. Re: How do I load an ICML File?
                  grefel, is it possible that the place() function works differently on 2015.4 (11.4.0.90) than it does on my 12.0.0.81? I ask because a customer does not see any content of the placed ICML file, and since I don’t have that version of InDesign I can’t really test...
                  • 6. Re: How do I load an ICML File?
                    grefel Level 2
                    I'm quite sure that place() works the same way in 2015.4 (11.4.0.90) and 2017 and all the other version since I started scripting with CS3.
                    To check: Do you use the mentioned code block with unlink:
