6 Replies Latest reply on Jan 4, 2017 9:35 AM by johnpredmore
    Help Creating Cross-References Linked to Text Anchors
    johnpredmore Level 1
      Hi I'm fairly new to scripting so I'm having trouble modifying the following script. I've gotten it to do all I need to do except that I need to change the link type from URL to Text Anchor. Can you please help?
        • 1. Re: Help Creating Cross-References Linked to Text Anchors
          Here's the script if it didn't show up above for you
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = "a";
          app.findGrepPreferences.appliedCharacterStyle = myDoc.characterStyles.item("Superscript");
          app.findGrepPreferences.appliedParagraphStyle = myDoc.paragraphStyleGroups.item("Table").paragraphStyles.item("Table Title");
          var myFound1 = myDoc.findGrep();
          count = 0
          for(k=0; k<myFound1.length; k++)
          try{
              var myFind = myFound1[k];
              var myHyperlinkSource = app.activeDocument.hyperlinkTextSources.add(myFound1[k])
              var myHyperlinkURLDestination = app.activeDocument.hyperlinkURLDestinations.add(myFound1[k].contents)
              var myHyperlink = app.activeDocument.hyperlinks.add(myHyperlinkSource, myHyperlinkURLDestination, {name: myFound1[k].contents+count++})
              count++
          }catch(e){}
          alert(count/2 + " Occurrences Changed")
          • 2. Re: Help Creating Cross-References Linked to Text Anchors
            Peter Kahrel Adobe Community Professional & MVP
            It's indeed confusing that InDesign uses two different terms for the same object: text anchor and text destination.
            Change "myHyperlinkURLDestination" to "myHyperlinkTextDestination" three times, and change "myFound1[k].contents" to "myFound1[k]"
            var myHyperlinkTextDestination = app.activeDocument.hyperlinkTextDestinations.add (myFound1[k]);
            var myHyperlink = app.activeDocument.hyperlinks.add (myHyperlinkSource, myHyperlinkTextDestination, . . .);
            Peter
            • 3. Re: Help Creating Cross-References Linked to Text Anchors
              Thanks for your response Peter, is the following the code you are proposing? I'm still not getting it to work; perhaps you can see where I'm messing up.
              Thanks again!
              • 4. Re: Help Creating Cross-References Linked to Text Anchors
                Here's the script if it didn't show up above for you.
                count = 0
                try{
                    var myHyperlinkTextDestination = app.activeDocument.hyperlinkTextDestination.add(myFound1[k]);
                    var myHyperlink = app.activeDocument.hyperlinks.add (myHyperlinkSource, myHyperlinkTextDestination, {name: myFound1[k].contents+count++});
                    count++
                }catch(e){}
                alert(count/2 + " Hyperlinks Were Created!")
                • 5. Re: Help Creating Cross-References Linked to Text Anchors
                  It should be app.activeDocument.hyperlinkTextDestinations.add (. . .) (mind the 's')
                  And you need to specify the source: links are from sources to destinations. What are you trying to link? You look for 'a' in a particular character and paragraph style, then you create an anchor at the found a's, then you create a link from somewhere to that a. Where is that 'somewhere'?
                  • 6. Re: Help Creating Cross-References Linked to Text Anchors
                    Thanks for your explanation Peter; it really helped it click for me. I was trying to link to a "somewhere" (anchor tag) called "a".
                    Here's the code that worked for me based on your tip:
                    app.findGrepPreferences.findWhat = "a"; // Grep for what you need to find
                    count = 0
                    try{
                        var myHyperlinkTextDestination = app.activeDocument.hyperlinkTextDestinations.item("a"); // Name of anchor to link to
                        count++
                    }catch(e){}
                    alert(count/2 + " Hyperlink Cross-References Were Created!")
                    Thanks again Peter!
